Is this a Yosemite thing? Has anyone else experienced this? If you fixed it, what did you do? Is there a bit of the error log that I can copy and paste in here to help diagnose? Is this just going to get fixed in the next few days?
I'm not 100% sure it's caused by Yosemite because I hadn't used ADE for many weeks prior to the update, but it's the only major thing I can think of that's changed.
In the mean time, is there any other program that can open .acsm files on a Mac running Yosemite?
Ditto......New Mac user and have been unable to open .acsm files on the Mac - with Mavericks OR Yosemite. Not even sure my public library can help.....any ideas? anyone?
I updated to 4.0.1 and still it crashes upon opening.
I actually had luck with ADE 3.0....so far, so good.....
I just retried 3.0, but nope - it still crashes about 3 seconds after it opens.
I just downloaded yet another ePub book and it worked fine - on 3.0. Perhaps a call to Apple support? Very frustrating I know!
Nahh, they'll just tell me it's a third-party app and they can't do anything about it. But thank you anyway.
It happens to me on about 80% of epub downloads. Apple says it's Adobe - Adobe sasy it's Apple. Based on track record, I'd say it's Adobe and there are complaints about this for years.
I'm having the same issue. MAC Yosemite and ADE 4.0 - crashing when I try to open a library book. Also crashing when I try to copy a book to my ereader. Very frustrating and I can't read my library books now. Might try an older version of ADE next, although uninstalling on the MAC is tricky it seems. I've uninstalled and installed and still see the same books.
I just downloaded ADE 4.0 and I am having the same problem. Every time I click on my ebook, it just crashes. Not so glad I bought this ebook that has to use this software. Unless anyone else knows of a different software program I could use. Thanks! This is extremely frustrating, especially when the book is for school.
I'm having the same problem. I have Mavericks and I've downloaded ADE 4.0, which crashes immediately when I try to open a book that I've borrowed from the library. This is very frustrating as I've been using ADE on a Mac for a few years now with no problems. My current computer is new as of this summer.
Does anyone from Adobe actually monitor these forums and try to help or are we on our own?
I can confirm this problem with the latest OS x version of ADE and Yosimite. Does Adobe have any answer for this? Is there some other means to contact them?
Can you please share some details about the crash you are facing?
Does ADE4.0 crashes on all the "acsm" files you open? or some particular one only?
Did you try to open any other e-book? If no, I will suggest that you right click on the book and open it with ADE4.0 and see if it works?
It will be really helpful if you could share the crash logs with us.
You can find crashlogs in "Console" app.
In Console App, you need to click on the "User Diagnostic Reports" in the left sidebar and then there you will find report for ADE (something like "Adobe Digital Editions_<date>_<machine-name>.crash".
I have the same.
Process: | Adobe Digital Editions [2933] |
Path: | /Applications/Adobe Digital Editions 4.0.app/Contents/MacOS/Adobe Digital Editions |
Identifier: | com.adobe.adobedigitaleditions.app |
Version: | 4.0.2 (1) |
Code Type: | X86-64 (Native) |
Parent Process: | ??? [1] |
Responsible: | Adobe Digital Editions [2933] |
User ID: | 501 |
Date/Time: | 2014-11-26 14:50:52.048 +0100 |
OS Version: | Mac OS X 10.10.1 (14B25) |
Report Version: | 11 |
Anonymous UUID: | 2A724844-1FB3-3563-841C-108DA6C0C444 |
Sleep/Wake UUID: | 53915FDA-2308-4F71-87BC-B5FB472DA143 |
Time Awake Since Boot: 21000 seconds
Time Since Wake: | 3000 seconds |
Crashed Thread: | 0 Dispatch queue: com.apple.main-thread |
Exception Type: | EXC_BAD_ACCESS (SIGSEGV) |
Exception Codes: | KERN_INVALID_ADDRESS at 0x0000000000000020 Model: MacBookAir6,1, BootROM MBA61.0099.B16, 2 processors, Intel Core i5, 1.3 GHz, 4 GB, SMC 2.12f143 Graphics: Intel HD Graphics 5000, Intel HD Graphics 5000, Built-In Memory Module: BANK 0/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A544D4C41522D4E544D Memory Module: BANK 1/DIMM0, 2 GB, DDR3, 1600 MHz, 0x80AD, 0x483943434E4E4E384A544D4C41522D4E544D AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0x117), Broadcom BCM43xx 1.0 (7.15.124.12.10) Bluetooth: Version 4.3.1f2 15015, 3 services, 27 devices, 1 incoming serial ports Network Service: Wi-Fi, AirPort, en0 Serial ATA Device: APPLE SSD TS0256F, 251 GB USB Device: BRCM20702 Hub USB Device: Bluetooth USB Host Controller Thunderbolt Bus: MacBook Air, Apple Inc., 23.6 |
Hi onoffMEDIA,
Chirag
Hi Chirag, the App is immediately crashing after start lauching. I dont see any window. I double Click the App and I get just the the crash-report.
VM Regions Near 0x20:
__TEXT 0000000106c58000-000000010745e000 [ 8216K] r-x/rwx SM=COW /Applications/Adobe Digital Editions 4.0.app/Contents/MacOS/Adobe Digital Editions
Thread 0 Crashed:: Dispatch queue: com.apple.main-thread
0 com.adobe.adobedigitaleditions.app 0x000000010716840f uft::Value::inlineSet(uft::Value const&) + 7
1 com.adobe.adobedigitaleditions.app 0x000000010715d4fc uft::Value::operator=(uft::Value const&) + 14
2 com.adobe.adobedigitaleditions.app 0x0000000106dbaae8 css::StyleHandler::verifyXMLStylesheetTree(mdom::Node const&) + 300
3 com.adobe.adobedigitaleditions.app 0x0000000106db74a7 css::StyleHandler::processXMLStylesheet(uft::URL const&, mdom::Node const&, uft::String const&) + 227
4 com.adobe.adobedigitaleditions.app 0x0000000106db73a1 css::StyleHandler::resourceDownloadComplete(mdom::Node const&, uft::String const&, uft::URL const&, uft::String const&) + 139
5 com.adobe.adobedigitaleditions.app 0x0000000106edeef3 pxf::ResourceStreamReceiver::bytesReady(unsigned long, dp::Data const&, bool) + 207
6 com.adobe.adobedigitaleditions.app 0x0000000106eb70ba rmsdk::zip::ZLibDecompressorStream::bytesReady(unsigned long, dp::Data const&, bool) + 674
7 com.adobe.adobedigitaleditions.app 0x0000000106e9566c package::AESZipDecryptor::bytesReady(unsigned long, dp::Data const&, bool) + 572
8 com.adobe.adobedigitaleditions.app 0x0000000106eb5dda rmsdk::zip::ZipEntryStream::bytesReady(unsigned long, dp::Data const&, bool) + 34
9 com.adobe.adobedigitaleditions.app 0x0000000106eb5d45 rmsdk::zip::Entry::bytesReady(unsigned long, dp::Data const&, bool) + 235
10 com.adobe.adobedigitaleditions.app 0x0000000106eb960b rmsdk::zip::Archive::bytesReady(unsigned long, dp::Data const&, bool) + 1707
11 com.adobe.adobedigitaleditions.app 0x0000000106d4d90c dpio::FileStream::requestBytes(unsigned long, unsigned long) + 392
12 com.adobe.adobedigitaleditions.app 0x0000000106eb5fa7 rmsdk::zip::Entry::requestBytes(rmsdk::zip::ZipEntryStream*, unsigned long, unsigned long) + 107
13 com.adobe.adobedigitaleditions.app 0x0000000106eb667d rmsdk::zip::ZipEntryStream::requestBytes(unsigned long, unsigned long) + 37
14 com.adobe.adobedigitaleditions.app 0x0000000106edbc0c pxf::PXFRenderer::downloadResource(mdom::Node const&, uft::URL const&) + 240
15 com.adobe.adobedigitaleditions.app 0x0000000106db6f6e css::StyleHandler::init(xda::ElementInitHost*, mdom::Node const&, unsigned int) + 350
16 com.adobe.adobedigitaleditions.app 0x0000000106da094b xda::ElementInitHost::processInsertion(xda::SourceDOMAttachment*, xda::Processor*, mdom::Node const&, bool) + 397
17 com.adobe.adobedigitaleditions.app 0x0000000106d9e700 xda::Processor::documentParsed(mdom::Reference const&) + 336
18 com.adobe.adobedigitaleditions.app 0x0000000106edbdfe pxf::PXFRenderer::documentLoaded(uft::URL const&, unsigned long) + 166
19 com.adobe.adobedigitaleditions.app 0x0000000106edea47 pxf::DOMResourceStreamReceiver::bytesReady(unsigned long, dp::Data const&, bool) + 409
20 com.adobe.adobedigitaleditions.app 0x0000000106eb70ba rmsdk::zip::ZLibDecompressorStream::bytesReady(unsigned long, dp::Data const&, bool) + 674
21 com.adobe.adobedigitaleditions.app 0x0000000106e9566c package::AESZipDecryptor::bytesReady(unsigned long, dp::Data const&, bool) + 572
22 com.adobe.adobedigitaleditions.app 0x0000000106eb5dda rmsdk::zip::ZipEntryStream::bytesReady(unsigned long, dp::Data const&, bool) + 34
23 com.adobe.adobedigitaleditions.app 0x0000000106eb5d45 rmsdk::zip::Entry::bytesReady(unsigned long, dp::Data const&, bool) + 235
24 com.adobe.adobedigitaleditions.app 0x0000000106eb960b rmsdk::zip::Archive::bytesReady(unsigned long, dp::Data const&, bool) + 1707
25 com.adobe.adobedigitaleditions.app 0x0000000106d4d90c dpio::FileStream::requestBytes(unsigned long, unsigned long) + 392
26 com.adobe.adobedigitaleditions.app 0x0000000106eb5fa7 rmsdk::zip::Entry::requestBytes(rmsdk::zip::ZipEntryStream*, unsigned long, unsigned long) + 107
27 com.adobe.adobedigitaleditions.app 0x0000000106eb667d rmsdk::zip::ZipEntryStream::requestBytes(unsigned long, unsigned long) + 37
28 com.adobe.adobedigitaleditions.app 0x0000000106edba79 pxf::PXFRenderer::requestXMLResource(uft::URL const&) + 243
29 com.adobe.adobedigitaleditions.app 0x0000000106ecd22f pxf::PXFRenderer::setURL(dp::String const&) + 345
30 com.adobe.adobedigitaleditions.app 0x0000000106e96fc5 package::Subdocument::getDocument(bool) + 733
31 com.adobe.adobedigitaleditions.app 0x0000000106ea1e87 package::Subrenderer::getRenderer(bool) + 53
32 com.adobe.adobedigitaleditions.app 0x0000000106ea4407 package::PackageRenderer::paint(int, int, int, int, dpdoc::Surface*) + 87
33 com.adobe.adobedigitaleditions.app 0x0000000106c64c4b -[Reader paint:buffer:color:] + 111
34 com.adobe.adobedigitaleditions.app 0x0000000106c7a5bb +[PNGThumbnail createThumbnail:] + 1203
35 com.adobe.adobedigitaleditions.app 0x0000000106c63827 -[ContentRecord createThumbnail:] + 380
36 com.adobe.adobedigitaleditions.app 0x0000000106c634b9 -[ContentRecord load] + 1633
37 com.adobe.adobedigitaleditions.app 0x0000000106c66d27 -[Library loadRecords] + 192
38 com.adobe.adobedigitaleditions.app 0x0000000106c69d70 -[LibraryViewController onLibraryLoaded:] + 75
39 com.adobe.adobedigitaleditions.app 0x0000000106c74e9d -[AppDelegate onCallBack:param1:param2:] + 181
40 com.adobe.adobedigitaleditions.app 0x0000000106f3d641 dplib::LibraryImpl::doSomeLoading() + 249
41 com.adobe.adobedigitaleditions.app 0x0000000106f3d500 dplib::LibraryImpl::timerFired(dptimer::Timer*) + 18
42 com.adobe.adobedigitaleditions.app 0x0000000106d49ee8 dptimer::MultiplexedTimerProvider::timerFired(dptimer::Timer*) + 74
43 com.adobe.adobedigitaleditions.app 0x0000000106cca64f -[TimerHandler timerFireMethod:] + 45
44 com.apple.Foundation 0x00007fff8a0ec023 __NSFireTimer + 95
45 com.apple.CoreFoundation 0x00007fff8a49fb44 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
46 com.apple.CoreFoundation 0x00007fff8a49f7d3 __CFRunLoopDoTimer + 1059
47 com.apple.CoreFoundation 0x00007fff8a512d9d __CFRunLoopDoTimers + 301
48 com.apple.CoreFoundation 0x00007fff8a45c268 __CFRunLoopRun + 2024
49 com.apple.CoreFoundation 0x00007fff8a45b838 CFRunLoopRunSpecific + 296
50 com.apple.HIToolbox 0x00007fff8c79d43f RunCurrentEventLoopInMode + 235
51 com.apple.HIToolbox 0x00007fff8c79d1ba ReceiveNextEventCommon + 431
52 com.apple.HIToolbox 0x00007fff8c79cffb _BlockUntilNextEventMatchingListInModeWithFilter + 71
53 com.apple.AppKit 0x00007fff8bb936d1 _DPSNextEvent + 964
54 com.apple.AppKit 0x00007fff8bb92e80 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 194
55 com.apple.AppKit 0x00007fff8bb86e23 -[NSApplication run] + 594
56 com.apple.AppKit 0x00007fff8bb722d4 NSApplicationMain + 1832
57 com.adobe.adobedigitaleditions.app 0x0000000106c5a2e4 start + 52
Thread 1:: Dispatch queue: com.apple.libdispatch-manager
0 libsystem_kernel.dylib 0x00007fff9104522e kevent64 + 10
1 libdispatch.dylib 0x00007fff8ad2da6a _dispatch_mgr_thread + 52
Thread 2:
0 libsystem_kernel.dylib 0x00007fff91044946 __workq_kernreturn + 10
1 libsystem_pthread.dylib 0x00007fff95a344a1 start_wqthread + 13
Thread 3:
Thread 4:
Thread 5:
Thread 6:: com.apple.NSURLConnectionLoader
0 libsystem_kernel.dylib 0x00007fff9103f52e mach_msg_trap + 10
1 libsystem_kernel.dylib 0x00007fff9103e69f mach_msg + 55
2 com.apple.CoreFoundation 0x00007fff8a45cb14 __CFRunLoopServiceMachPort + 212
3 com.apple.CoreFoundation 0x00007fff8a45bfdb __CFRunLoopRun + 1371
4 com.apple.CoreFoundation 0x00007fff8a45b838 CFRunLoopRunSpecific + 296
5 com.apple.CFNetwork 0x00007fff8b5e2d20 +[NSURLConnection(Loader) _resourceLoadLoop:] + 434
6 com.apple.Foundation 0x00007fff8a0edb7a __NSThread__main__ + 1345
7 libsystem_pthread.dylib 0x00007fff95a362fc _pthread_body + 131
8 libsystem_pthread.dylib 0x00007fff95a36279 _pthread_start + 176
9 libsystem_pthread.dylib 0x00007fff95a344b1 thread_start + 13
Thread 7:
Thread 8:
Thread 9:: com.apple.CFSocket.private
0 libsystem_kernel.dylib 0x00007fff910443f6 __select + 10
1 libsystem_pthread.dylib 0x00007fff95a362fc _pthread_body + 131
2 libsystem_pthread.dylib 0x00007fff95a36279 _pthread_start + 176
3 libsystem_pthread.dylib 0x00007fff95a344b1 thread_start + 13
Thread 10:
5 com.apple.AppKit 0x00007fff8bcf67a7 _NSEventThread + 137
6 libsystem_pthread.dylib 0x00007fff95a362fc _pthread_body + 131
7 libsystem_pthread.dylib 0x00007fff95a36279 _pthread_start + 176
8 libsystem_pthread.dylib 0x00007fff95a344b1 thread_start + 13
Thread 0 crashed with X86 Thread State (64-bit):
rax: 0x00007fff58fa1698 rbx: 0x00007fff58fa1698 rcx: 0x0000000000000001 rdx: 0x0000000000000001
rdi: 0x00007fff58fa1698 rsi: 0x0000000000000020 rbp: 0x00007fff58fa1650 rsp: 0x00007fff58fa1650
r8: 0x00007f9518d3b698 r9: 0x0000000000000400 r10: 0x0000000089c8dd08 r11: 0x00000000d5f9b613
r12: 0x00000001074e7840 r13: 0x00007fff58fa1801 r14: 0x00007fff58fa1740 r15: 0x00007fff58fa1808
rip: 0x000000010716840f rfl: 0x0000000000010202 cr2: 0x0000000000000020
Logical CPU: 0
Error Code: 0x00000004
Trap Number: 14
Binary Images:
0x106c58000 - 0x10745dfff +com.adobe.adobedigitaleditions.app (4.0.2 - 1) <E89E4741-12BA-3D57-A844-801324720F1C> /Applications/Adobe Digital Editions 4.0.app/Contents/MacOS/Adobe Digital Editions
0x107df2000 - 0x107ef8fff +ePub3.dylib (0) <BC2214E8-02E8-3DF9-B08B-B8CED04FDDB8> /Applications/Adobe Digital Editions 4.0.app/Contents/Frameworks/ePub3.dylib
0x107fa1000 - 0x107fb6ff7 +SimpleHTTPServer.dylib (1) <3B1B79A1-5CB2-385C-9251-F2A21E9330FB> /Applications/Adobe Digital Editions 4.0.app/Contents/Frameworks/SimpleHTTPServer.dylib
0x107fcc000 - 0x108001ff7 libssl.0.9.8.dylib (52) <70680606-475F-3C89-BB5F-E274253DC7C6> /usr/lib/libssl.0.9.8.dylib
0x10ba22000 - 0x10ba22ff5 +cl_kernels (???) <FD69E38B-4B74-460B-BFB4-2FD36DD4E09C> cl_kernels
0x10ba50000 - 0x10ba50fef +cl_kernels (???) <D29E56E3-11F8-4B11-9E1E-89DA298F1541> cl_kernels
0x10d59b000 - 0x10d681fef unorm8_bgra.dylib (2.4.5) <90797750-141F-3114-ACD0-A71363968678> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra.dylib
0x7fff6fa6c000 - 0x7fff6faa2837 dyld (353.2.1) <4696A982-1500-34EC-9777-1EF7A03E2659> /usr/lib/dyld
0x7fff89b71000 - 0x7fff89d56267 libobjc.A.dylib (646) <3B60CD90-74A2-3A5D-9686-B0772159792A> /usr/lib/libobjc.A.dylib
0x7fff89d57000 - 0x7fff89d5ffff libsystem_dnssd.dylib (561.1.1) <62B70ECA-E40D-3C63-896E-7F00EC386DDB> /usr/lib/system/libsystem_dnssd.dylib
0x7fff89d60000 - 0x7fff89d61ff7 com.apple.print.framework.Print (10.0 - 265) <3BC4FE7F-78A0-3E57-8F4C-520E7EFD36FA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x7fff89dbd000 - 0x7fff89dc2ff7 libunwind.dylib (35.3) <BE7E51A0-B6EA-3A54-9CCA-9D88F683A6D6> /usr/lib/system/libunwind.dylib
0x7fff89dc3000 - 0x7fff89de3fff com.apple.IconServices (47.1 - 47.1) <E83DFE3B-6541-3736-96BB-26DC5D0100F1> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
0x7fff89de4000 - 0x7fff89de5fff com.apple.TrustEvaluationAgent (2.0 - 25) <2D61A2C3-C83E-3A3F-8EC1-736DBEC250AB> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluationAgent
0x7fff8a073000 - 0x7fff8a07eff7 libkxld.dylib (2782.1.97) <CB1A1B57-54BE-3573-AE0C-B90ED6BAEEE2> /usr/lib/system/libkxld.dylib
0x7fff8a07f000 - 0x7fff8a084fff com.apple.DiskArbitration (2.6 - 2.6) <0DFF4D9B-2AC3-3B82-B5C5-30F4EFBD2DB9> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
0x7fff8a085000 - 0x7fff8a3b3ff7 com.apple.Foundation (6.9 - 1151.16) <18EDD673-A010-3E99-956E-DA594CE1FA80> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
0x7fff8a3cd000 - 0x7fff8a3e9ff7 libsystem_malloc.dylib (53.1.1) <19BCC257-5717-3502-A71F-95D65AFA861B> /usr/lib/system/libsystem_malloc.dylib
0x7fff8a3ea000 - 0x7fff8a780fff com.apple.CoreFoundation (6.9 - 1151.16) <F2B088AF-A5C6-3FAE-9EB4-7931AF6359E4> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
0x7fff8a79f000 - 0x7fff8a7b9ff3 com.apple.Ubiquity (1.3 - 313) <DF56A657-CC6E-3BE2-86A0-71F07127724C> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
0x7fff8a7ba000 - 0x7fff8a7bcff7 libutil.dylib (38) <471AD65E-B86E-3C4A-8ABD-B8665A2BCE3F> /usr/lib/libutil.dylib
0x7fff8a7bd000 - 0x7fff8abcaff7 libLAPACK.dylib (1128) <F9201AE7-B031-36DB-BCF8-971E994EF7C1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLAPACK.dylib
0x7fff8abcb000 - 0x7fff8ac60ff7 com.apple.ColorSync (4.9.0 - 4.9.0) <F06733BD-A10C-3DB3-B050-825351130392> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync.framework/Versions/A/ColorSync
0x7fff8acc7000 - 0x7fff8ad02fff com.apple.QD (301 - 301) <C4D2AD03-B839-350A-AAF0-B4A08F8BED77> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framework/Versions/A/QD
0x7fff8ad03000 - 0x7fff8ad06fff com.apple.IOSurface (97 - 97) <D4B4D2B2-7B16-3174-9EA6-55E0A10B452D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
0x7fff8ad07000 - 0x7fff8ad14fff com.apple.ProtocolBuffer (1 - 225.1) <2D502FBB-D2A0-3937-A5C5-385FA65B3874> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
0x7fff8ad15000 - 0x7fff8ad1eff7 libsystem_notify.dylib (133.1.1) <61147800-F320-3DAA-850C-BADF33855F29> /usr/lib/system/libsystem_notify.dylib
0x7fff8ad1f000 - 0x7fff8ad25ff7 libsystem_networkextension.dylib (167.1.10) <29AB225B-D7FB-30ED-9600-65D44B9A9442> /usr/lib/system/libsystem_networkextension.dylib
0x7fff8ad29000 - 0x7fff8ad53ff7 libdispatch.dylib (442.1.4) <502CF32B-669B-3709-8862-08188225E4F0> /usr/lib/system/libdispatch.dylib
0x7fff8ad54000 - 0x7fff8ad6dfff com.apple.openscripting (1.4 - 162) <80DFF366-B950-3F79-903F-99DA0FFDB570> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework/Versions/A/OpenScripting
0x7fff8adb6000 - 0x7fff8adb6ff7 liblaunch.dylib (559.1.22) <8A988924-8BE7-35FE-BF7D-322E90EFE49E> /usr/lib/system/liblaunch.dylib
0x7fff8aed1000 - 0x7fff8af53fff com.apple.PerformanceAnalysis (1.0 - 1) <2FC0F303-B672-3E64-A978-AB78EAD98395> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAnalysis
0x7fff8af54000 - 0x7fff8afc8fff com.apple.ApplicationServices.ATS (360 - 375) <62828B40-231D-3F81-8067-1903143DCB6B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x7fff8afc9000 - 0x7fff8aff2ffb libxslt.1.dylib (13) <AED1143F-B848-3E73-81ED-71356F25F084> /usr/lib/libxslt.1.dylib
0x7fff8b51d000 - 0x7fff8b541fef libJPEG.dylib (1231) <3F87A0CA-14FA-3034-A332-DD57A092B08F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x7fff8b542000 - 0x7fff8b745ff3 com.apple.CFNetwork (720.1.1 - 720.1.1) <A82E71B3-2CDB-3840-A476-F2304D896E03> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
0x7fff8b746000 - 0x7fff8b7e7ff7 com.apple.Bluetooth (4.3.1 - 4.3.1f2) <EDC78AEE-28E7-324C-9947-41A0814A8154> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
0x7fff8b80e000 - 0x7fff8b816ffb libcopyfile.dylib (118.1.2) <0C68D3A6-ACDD-3EF3-991A-CC82C32AB836> /usr/lib/system/libcopyfile.dylib
0x7fff8b817000 - 0x7fff8b894fff com.apple.CoreServices.OSServices (640.3 - 640.3) <28445162-08E9-3E24-84E4-617CE5FE1367> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framework/Versions/A/OSServices
0x7fff8b895000 - 0x7fff8b89affb libheimdal-asn1.dylib (398.1.2) <F9463B34-AAF5-3488-AD0C-85937C81FC5E> /usr/lib/libheimdal-asn1.dylib
0x7fff8b89b000 - 0x7fff8b89bfff com.apple.CoreServices (62 - 62) <9E4577CA-3FC3-300D-AB00-87ADBDDA2E37> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x7fff8ba11000 - 0x7fff8ba7dfff com.apple.framework.CoreWLAN (5.0 - 500.35.2) <ACBAAB0A-BCC7-37CF-AAFB-2DA1733F2682> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
0x7fff8baa6000 - 0x7fff8baa8ff7 com.apple.securityhi (9.0 - 55006) <B1E09986-7AF0-3BD1-BAA1-B5514DFB7CD1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Versions/A/SecurityHI
0x7fff8baa9000 - 0x7fff8baabfff libCVMSPluginSupport.dylib (11.0.7) <29D775BB-A11D-3140-A478-2A0DA1A87420> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dylib
0x7fff8baac000 - 0x7fff8baf2ffb libFontRegistry.dylib (134) <01B8034A-45FD-3360-A347-A1896F591363> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontRegistry.dylib
0x7fff8baf3000 - 0x7fff8bb14fff com.apple.framework.Apple80211 (10.0.1 - 1001.57.4) <E449B57F-1AC3-3DF1-8A13-4390FB3A05A4> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
0x7fff8bb5c000 - 0x7fff8bb6eff7 com.apple.ImageCapture (9.0 - 9.0) <7FB65DD4-56B5-35C4-862C-7A2DED991D1F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x7fff8bb6f000 - 0x7fff8c6b0fff com.apple.AppKit (6.9 - 1343.16) <C98DB43F-4245-3E6E-A4EE-37DAEE33E174> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
0x7fff8c6b1000 - 0x7fff8c6dcfff com.apple.DictionaryServices (1.2 - 229) <6789EC43-CADA-394D-8FE8-FC3A2DD136B9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryServices.framework/Versions/A/DictionaryServices
0x7fff8c76f000 - 0x7fff8ca71fff com.apple.HIToolbox (2.1.1 - 756) <9DD121B5-B7EB-3C43-8155-61A4417F8E9A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Versions/A/HIToolbox
0x7fff8ca72000 - 0x7fff8ca83fff libcmph.dylib (1) <46EC3997-DB5E-38AE-BBBB-A035A54AD3C0> /usr/lib/libcmph.dylib
0x7fff8ca84000 - 0x7fff8cab4fff libsystem_m.dylib (3086.1) <1E12AB45-6D96-36D0-A226-F24D9FB0D9D6> /usr/lib/system/libsystem_m.dylib
0x7fff8cbb8000 - 0x7fff8cbcfff7 libLinearAlgebra.dylib (1128) <E78CCBAA-A999-3B65-8EC9-06DB15E67C37> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libLinearAlgebra.dylib
0x7fff8cbd0000 - 0x7fff8cc59fff com.apple.CoreSymbolication (3.1 - 56072) <8CE81C95-49E8-389F-B989-67CC452C08D0> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolication
0x7fff8cc5a000 - 0x7fff8cc5bfff libSystem.B.dylib (1213) <DA954461-EC6A-3DF0-8551-6FC810627627> /usr/lib/libSystem.B.dylib
0x7fff8cc5c000 - 0x7fff8cc5cfff com.apple.Accelerate (1.10 - Accelerate 1.10) <C7278843-2462-32F6-B0E3-D33C681399A2>
/System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
0x7fff8cf82000 - 0x7fff8d236ff7 com.apple.WebKit (10600 - 10600.1.25) <84496A10-D8E5-3E8C-93B1-98D5AE790922> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
0x7fff8d350000 - 0x7fff8d373fff com.apple.Sharing (328.3 - 328.3) <FDEE49AD-8804-3760-9C14-8D1D10BBEA37> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
0x7fff8d43e000 - 0x7fff8d442fff libcache.dylib (69) <45E9A2E7-99C4-36B2-BEE3-0C4E11614AD1> /usr/lib/system/libcache.dylib
0x7fff8d497000 - 0x7fff8d505ffb com.apple.Heimdal (4.0 - 2.0) <B852ACA1-4C64-3E2A-A9D3-6D4C80AD9429> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
0x7fff8d506000 - 0x7fff8d597fff com.apple.cloudkit.CloudKit (259.2.3 - 259.2.3) <6F955140-D522-32B3-B34B-BD94C5D94E7A> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
0x7fff8d5ba000 - 0x7fff8d64efff com.apple.ink.framework (10.9 - 213) <8E029630-1530-3734-A446-13353F0E7AC5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/A/Ink
0x7fff8d64f000 - 0x7fff8d669ff7 com.apple.Kerberos (3.0 - 1) <7760E0C2-A222-3709-B2A6-B692D900CEB1> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
0x7fff8d696000 - 0x7fff8d7d2ffb com.apple.WebKitLegacy (10600 - 10600.1.25) <EE3A7515-AC7B-30D3-A4DC-EB0D36E88E4B> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebKitLegacy.framework/Versions/A/WebKitLegacy
0x7fff8d7d3000 - 0x7fff8d822ff7 com.apple.opencl (2.4.2 - 2.4.2) <6AE26E08-6EFC-3E1B-B202-EFA9C3E5B9D4> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
0x7fff8d823000 - 0x7fff8d82bff7 com.apple.AppleSRP (5.0 - 1) <01EC5144-D09A-3D6A-AE35-F6D48585F154> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
0x7fff8d956000 - 0x7fff8d97effb libRIP.A.dylib (772) <9262437A-710A-397D-8E34-1CBFEA1FC5E1> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
0x7fff8d97f000 - 0x7fff8daa1ff7 com.apple.LaunchServices (644.12 - 644.12) <D7710B20-0561-33BB-A3C8-463691D36E02> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.framework/Versions/A/LaunchServices
0x7fff8daa2000 - 0x7fff8db16ff3 com.apple.securityfoundation (6.0 - 55126) <E7FB7A4E-CB0B-37BA-ADD5-373B2A20A783> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x7fff8db1f000 - 0x7fff8db44fff libPng.dylib (1231) <759DF465-B08C-3E97-9A07-3CD447F84F78> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
0x7fff8db45000 - 0x7fff8db72fff com.apple.CoreVideo (1.8 - 145.1) <18DB07E0-B927-3260-A234-636F298D1917> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
0x7fff8db73000 - 0x7fff8db73fff libOpenScriptingUtil.dylib (162) <EFD79173-A9DA-3AE6-BE15-3948938204A6> /usr/lib/libOpenScriptingUtil.dylib
0x7fff8dbb5000 - 0x7fff8dca9ff7 libFontParser.dylib (134) <506126F8-FDCE-3DE1-9DCA-E07FE658B597> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libFontParser.dylib
0x7fff8dce3000 - 0x7fff8dce5ff7 libsystem_coreservices.dylib (9) <41B7C578-5A53-31C8-A96F-C73E030B0938> /usr/lib/system/libsystem_coreservices.dylib
0x7fff8e409000 - 0x7fff8f3adffb com.apple.WebCore (10600 - 10600.1.25.2) <B4FEC5E3-C0A9-3E91-93F5-548C001C560E> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versions/A/WebCore
0x7fff8f3b8000 - 0x7fff8f42efe7 libcorecrypto.dylib (233.1.2) <E1789801-3985-3949-B736-6B3378873301> /usr/lib/system/libcorecrypto.dylib
0x7fff8f58b000 - 0x7fff8f598ff7 libxar.1.dylib (254) <CE10EFED-3066-3749-838A-6A15AC0DBCB6> /usr/lib/libxar.1.dylib
0x7fff8f599000 - 0x7fff8f5b6ffb libresolv.9.dylib (57) <26B38E61-298A-3C3A-82C1-3B5E98AD5E29> /usr/lib/libresolv.9.dylib
0x7fff8f5b7000 - 0x7fff8f5b7fff com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <01E92F9F-EF29-3745-8631-AEA692F7F29C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/vecLib
0x7fff8f5b8000 - 0x7fff8f5bcfff libpam.2.dylib (20) <E805398D-9A92-31F8-8005-8DC188BD8B6E> /usr/lib/libpam.2.dylib
0x7fff8f5bd000 - 0x7fff8f5c1ff7 com.apple.TCC (1.0 - 1) <AFC32F8F-BCD5-313C-B66E-5AB8591EC066> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
0x7fff8f5c2000 - 0x7fff8f5c5fff com.apple.help (1.3.3 - 46) <CA4541F4-CEF5-355C-8F1F-EA65DC1B400F> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions/A/Help
0x7fff8f5c6000 - 0x7fff8f5c8fff com.apple.CoreDuetDebugLogging (1.0 - 1) <9A6E5710-EA99-366E-BF40-9A65EC1B46A1> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebugLogging
0x7fff8f5c9000 - 0x7fff8f6b9fef libJP2.dylib (1231) <FEAF6F38-736E-35A8-A983-F4531C8A821C> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
0x7fff8f73c000 - 0x7fff8f7a3ff7 com.apple.datadetectorscore (6.0 - 396.1) <5D348063-1528-3E2F-B587-9E82970506F9> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCore
0x7fff8f810000 - 0x7fff8f822ff7 com.apple.CoreDuetDaemonProtocol (1.0 - 1) <CE9FABB4-1C5D-3F9B-9BB8-5CC50C3E5E31> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDaemonProtocol
0x7fff8f828000 - 0x7fff8f82afff com.apple.loginsupport (1.0 - 1) <35A2A071-606C-39A5-8C11-E4CAF98D934C> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.framework/Versions/A/loginsupport
0x7fff8f8d4000 - 0x7fff8f9b7fff libcrypto.0.9.8.dylib (52) <7208EEE2-C090-383E-AADD-7E1BD1321BEC> /usr/lib/libcrypto.0.9.8.dylib
0x7fff8f9cf000 - 0x7fff8f9d1fff com.apple.EFILogin (2.0 - 2) <F0269EE2-3686-3A8A-8B83-F86974E35E90> /System/Library/PrivateFrameworks/EFILogin.framework/Versions/A/EFILogin
0x7fff8f9d2000 - 0x7fff8f9d8fff com.apple.speech.recognition.framework (5.0.9 - 5.0.9) <BB2D573F-0A01-379F-A2BA-3C454EDCB111> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.framework/Versions/A/SpeechRecognition
0x7fff8f9d9000 - 0x7fff8faafff3 com.apple.DiskImagesFramework (10.10 - 389.1) <7DE2208C-BD55-390A-8167-4F9F11750C4B> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
0x7fff8fab0000 - 0x7fff8facbff7 libCRFSuite.dylib (34) <D64842BE-7BD4-3D0C-9842-1D202F7C2A51> /usr/lib/libCRFSuite.dylib
0x7fff8facc000 - 0x7fff8faf4fff libxpc.dylib (559.1.22) <9437C02E-A07B-38C8-91CB-299FAA63083D> /usr/lib/system/libxpc.dylib
0x7fff8faf5000 - 0x7fff8fb3bff7 libauto.dylib (186) <A260789B-D4D8-316A-9490-254767B8A5F1> /usr/lib/libauto.dylib
0x7fff8fb3c000 - 0x7fff8fbadff7 com.apple.framework.IOKit (2.0.2 - 1050.1.21) <ED3B0B22-AACC-303B-BFC8-20ECD1AF6BA2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
0x7fff8fbd3000 - 0x7fff8fbd9fff libsystem_trace.dylib (72.1.3) <A9E6B7D8-C327-3742-AC54-86C94218B1DF> /usr/lib/system/libsystem_trace.dylib
0x7fff8fcad000 - 0x7fff8fcb2ff7 libmacho.dylib (862) <126CA2ED-DE91-308F-8881-B9DAEC3C63B6> /usr/lib/system/libmacho.dylib
0x7fff8fde6000 - 0x7fff8ff51ff7 com.apple.audio.toolbox.AudioToolbox (1.12 - 1.12) <5C6DBEB4-F2EA-3262-B9FC-AFB89404C1DA> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x7fff8ff83000 - 0x7fff8ff83fff com.apple.ApplicationServices (48 - 48) <5BF7910B-C328-3BF8-BA4F-CE52B574CE01> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
0x7fff8ff84000 - 0x7fff8ff91ff7 libbz2.1.0.dylib (36) <2DF83FBC-5C08-39E1-94F5-C28653791B5F> /usr/lib/libbz2.1.0.dylib
0x7fff8ffd1000 - 0x7fff900e0ffb com.apple.desktopservices (1.9 - 1.9) <6EDAC73F-C42C-3FF7-B67D-FCCA1CFC5405> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x7fff900ec000 - 0x7fff90100ff7 com.apple.ProtectedCloudStorage (1.0 - 1) <52CFE68A-0663-3756-AB5B-B42195026052> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedCloudStorage
0x7fff90101000 - 0x7fff90179ff7 com.apple.SystemConfiguration (1.14 - 1.14) <C269BCFD-ACAB-3331-BC7C-0430F0E84817> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
0x7fff9017a000 - 0x7fff90185fff libGL.dylib (11.0.7) <C53344AD-8CE6-3111-AB94-BD4CA89ED84E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
0x7fff90186000 - 0x7fff90245fff com.apple.backup.framework (1.6.1 - 1.6.1) <A7BBE57D-D5E7-39DD-812C-31190159F679> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
0x7fff90246000 - 0x7fff9026cff7 com.apple.ChunkingLibrary (2.1 - 163.1) <3514F2A4-38BD-3849-9286-B3B991057742> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
0x7fff9026d000 - 0x7fff902aefff libGLU.dylib (11.0.7) <8037342E-1ECD-385F-B4C3-545CE97B76AE> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
0x7fff902af000 - 0x7fff90517ffb com.apple.security (7.0 - 57031.1.35) <96141D1F-614E-32C4-8AC2-F47481F23F43> /System/Library/Frameworks/Security.framework/Versions/A/Security
0x7fff907e6000 - 0x7fff907eefe7 libcldcpuengine.dylib (2.4.5) <DF810F9A-1755-3283-82C3-D8192BCD8016> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
0x7fff90a88000 - 0x7fff90aa2ff7 liblzma.5.dylib (7) <1D03E875-A7C0-3028-814C-3C27F7B7C079> /usr/lib/liblzma.5.dylib
0x7fff90aa3000 - 0x7fff90aa7fff com.apple.CommonPanels (1.2.6 - 96) <F9ECC8AF-D9CA-3350-AFB4-5113A9B789A5> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/Versions/A/CommonPanels
0x7fff90ac7000 - 0x7fff90b18ff7 com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <AF72B06E-C6C1-3FAE-8B47-AF461CAE0E22> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
0x7fff90b19000 - 0x7fff90c40fff com.apple.coreui (2.1 - 305) <BB430677-D1F7-38DD-8F05-70E54352B8B5> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
0x7fff90c41000 - 0x7fff90c7cfff com.apple.Symbolication (1.4 - 56045) <D64571B1-4483-3FE2-BD67-A91360F79727> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
0x7fff90c7d000 - 0x7fff90c7ffff libsystem_configuration.dylib (699.1.5) <9FBA1CE4-97D0-347E-A443-93ED94512E92> /usr/lib/system/libsystem_configuration.dylib
0x7fff9102e000 - 0x7fff9104bfff libsystem_kernel.dylib (2782.1.97) <93E0E0A9-75B6-3904-BB4E-4BC7C05F4B6B> /usr/lib/system/libsystem_kernel.dylib
0x7fff91a09000 - 0x7fff91a40ffb com.apple.LDAPFramework (2.4.28 - 194.5) <4CFE8010-CE3F-35EC-90BA-529B74321029> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
0x7fff91b7a000 - 0x7fff91b84ff7 com.apple.CrashReporterSupport (10.10 - 629) <EC97EA5E-3190-3717-A4A9-2F35A447E7A6> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporterSupport
0x7fff91b85000 - 0x7fff91c77ff7 libiconv.2.dylib (42) <2A06D02F-8B76-3864-8D96-64EF5B40BC6C> /usr/lib/libiconv.2.dylib
0x7fff91c78000 - 0x7fff91e06fff libBLAS.dylib (1128) <497912C1-A98E-3281-BED7-E9C751552F61> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libBLAS.dylib
0x7fff91e07000 - 0x7fff91e2ffff libsystem_info.dylib (459) <B85A85D5-8530-3A93-B0C3-4DEC41F79478> /usr/lib/system/libsystem_info.dylib
0x7fff91f03000 - 0x7fff91fb2fe7 libvMisc.dylib (512) <AFBA45DE-7F55-3E4E-B8DF-5E8E21C407AD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Versions/A/libvMisc.dylib
0x7fff91fb3000 - 0x7fff9225aff7 com.apple.RawCamera.bundle (6.01 - 766) <A98D8BA2-EC64-36C2-8B71-CF5B8CDBFC97> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
0x7fff9225b000 - 0x7fff92293ffb libsystem_network.dylib (411) <C0B2313D-47BE-38A9-BEE6-2634A4F5E14B> /usr/lib/system/libsystem_network.dylib
0x7fff9240f000 - 0x7fff926deff3 com.apple.CoreImage (10.0.33) <6E3DDA29-718B-3BDB-BFAF-F8C201BF93A4> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework/Versions/A/CoreImage
0x7fff926df000 - 0x7fff92959fff com.apple.CoreData (110 - 526) <AEEDAF00-D38F-3A15-B3C9-73732940CC55> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
0x7fff9295a000 - 0x7fff92963ff3 com.apple.CommonAuth (4.0 - 2.0) <F4C266BE-2E0E-36B4-9DE7-C6B4BF410FD7> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
0x7fff92964000 - 0x7fff92977ff7 com.apple.CoreBluetooth (1.0 - 1) <FA9B43B3-E183-3040-AE25-66EF9870CF35> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
0x7fff9297f000 - 0x7fff929bffff com.apple.CloudDocs (1.0 - 280.1.2) <49E75BC1-6556-36B4-804A-E49BC41241CF> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
0x7fff92a3d000 - 0x7fff92d70ff7 libmecabra.dylib (666.1) <CAFBC813-4894-3352-9B22-FFF116773A06> /usr/lib/libmecabra.dylib
0x7fff92deb000 - 0x7fff92deffff libsystem_stats.dylib (163.1.4) <1DB04436-5974-3F16-86CC-5FF5F390339C> /usr/lib/system/libsystem_stats.dylib
0x7fff9300d000 - 0x7fff9305bfff libcurl.4.dylib (83.1.2) <337A1FF8-E8B1-3173-9F29-C0D4C851D8E1> /usr/lib/libcurl.4.dylib
0x7fff9305c000 - 0x7fff9305eff7 libquarantine.dylib (76) <DC041627-2D92-361C-BABF-A869A5C72293> /usr/lib/system/libquarantine.dylib
0x7fff9305f000 - 0x7fff93073ff7 com.apple.MultitouchSupport.framework (260.30 - 260.30) <28728A7D-E048-3B14-9932-839A87D381FE> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSupport
0x7fff93074000 - 0x7fff9308dff7 com.apple.CFOpenDirectory (10.10 - 187) <0ECA5D80-A045-3A2C-A60C-E1605F3AB6BD> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory.framework/Versions/A/CFOpenDirectory
0x7fff9308e000 - 0x7fff93096ff7 com.apple.icloud.FindMyDevice (1.0 - 1) <D198E170-3610-3727-BC87-73AD249CA097> /System/Library/PrivateFrameworks/FindMyDevice.framework/Versions/A/FindMyDevice
0x7fff93097000 - 0x7fff930a6fff com.apple.LangAnalysis (1.7.0 - 1.7.0) <D1E527E4-C561-352F-9457-E8C50232793C> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalysis.framework/Versions/A/LangAnalysis
0x7fff9333e000 - 0x7fff9333eff7 libunc.dylib (29) <5676F7EA-C1DF-329F-B006-D2C3022B7D70> /usr/lib/system/libunc.dylib
0x7fff943f7000 - 0x7fff94422ff3 libarchive.2.dylib (30) <8CBB4416-EBE9-3574-8ADC-44655D245F39> /usr/lib/libarchive.2.dylib
0x7fff94423000 - 0x7fff94425ffb libCGXType.A.dylib (772) <7CB71BC6-D8EC-37BC-8243-41BAB086FAAA> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
0x7fff9442b000 - 0x7fff94746fcf com.apple.vImage (8.0 - 8.0) <1183FE6A-FDB6-3B3B-928D-50C7909F2308> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Versions/A/vImage
0x7fff9475b000 - 0x7fff94f94ff3 com.apple.CoreGraphics (1.600.0 - 772) <936D081F-37B3-3DA3-B725-118D0B07DDD2> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
0x7fff9507a000 - 0x7fff95085ff7 com.apple.speech.synthesis.framework (5.2.6 - 5.2.6) <9434AA45-B6BD-37F7-A866-172196A7F91B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynthesis.framework/Versions/A/SpeechSynthesis
0x7fff95086000 - 0x7fff950e0ff7 com.apple.LanguageModeling (1.0 - 1) <ACA93FE0-A0E3-333E-AE3C-8EB7DE5F362F> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
0x7fff950e1000 - 0x7fff950e1ff7 libkeymgr.dylib (28) <77845842-DE70-3CC5-BD01-C3D14227CED5> /usr/lib/system/libkeymgr.dylib
0x7fff9512b000 - 0x7fff9525bfff com.apple.UIFoundation (1.0 - 1) <8E030D93-441C-3997-9CD2-55C8DFAC8B84> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
0x7fff95274000 - 0x7fff952acfff com.apple.RemoteViewServices (2.0 - 99) <C9A62691-B0D9-34B7-B71C-A48B5F4DC553> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServices
0x7fff952ad000 - 0x7fff952b4fff libCGCMS.A.dylib (772) <E64DC779-A6CF-3B1F-8E57-C09C0B10670F> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGCMS.A.dylib
0x7fff952b5000 - 0x7fff952b6fff libDiagnosticMessagesClient.dylib (100) <2EE8E436-5CDC-34C5-9959-5BA218D507FB> /usr/lib/libDiagnosticMessagesClient.dylib
0x7fff952b7000 - 0x7fff952b7fff com.apple.audio.units.AudioUnit (1.12 - 1.12) <76EF1C9D-DEA4-3E55-A134-4099B2FD2CF2> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
0x7fff952b8000 - 0x7fff952bbfff com.apple.xpc.ServiceManagement (1.0 - 1) <7E9E6BB7-AEE7-3F59-BAC0-59EAF105D0C8> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
0x7fff95743000 - 0x7fff9574aff7 libcompiler_rt.dylib (35) <BF8FC133-EE10-3DA6-9B90-92039E28678F> /usr/lib/system/libcompiler_rt.dylib
0x7fff9574b000 - 0x7fff9574eff7 libdyld.dylib (353.2.1) <19FAF435-C165-3374-9DEF-D7BBA7D61DB6> /usr/lib/system/libdyld.dylib
0x7fff9574f000 - 0x7fff95769ff7 com.apple.AppleVPAFramework (1.0.30 - 1.0.30) <D47A2125-C72D-3298-B27D-D89EA0D55584> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
0x7fff95786000 - 0x7fff95a32fff com.apple.GeoServices (1.0 - 982.4.10) <8A7FE04A-2785-30E7-A6E2-DC15D170DAF5> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
0x7fff95a33000 - 0x7fff95a3cfff libsystem_pthread.dylib (105.1.4) <26B1897F-0CD3-30F3-B55A-37CB45062D73> /usr/lib/system/libsystem_pthread.dylib
0x7fff95a3d000 - 0x7fff95a45fff libsystem_platform.dylib (63) <64E34079-D712-3D66-9CE2-418624A5C040> /usr/lib/system/libsystem_platform.dylib
0x7fff95a46000 - 0x7fff95a5cff7 libsystem_asl.dylib (267) <F153AC5B-0542-356E-88C8-20A62CA704E2> /usr/lib/system/libsystem_asl.dylib
0x7fff95a5d000 - 0x7fff95ae9fff libsystem_c.dylib (1044.1.2) <C185E862-7424-3210-B528-6B822577A4B8> /usr/lib/system/libsystem_c.dylib
0x7fff96638000 - 0x7fff96663fff libc++abi.dylib (125) <88A22A0F-87C6-3002-BFBA-AC0F2808B8B9> /usr/lib/libc++abi.dylib
0x7fff9677c000 - 0x7fff96787fff libcommonCrypto.dylib (60061) <D381EBC6-69D8-31D3-8084-5A80A32CB748> /usr/lib/system/libcommonCrypto.dylib
0x7fff96788000 - 0x7fff96843ff7 com.apple.DiscRecording (9.0 - 9000.4.1) <F70E600E-9668-3DF2-A3A8-61813DF9E2EE> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
0x7fff96850000 - 0x7fff96883ff7 com.apple.MediaKit (16 - 757) <345EDAFE-3E39-3B0F-8D84-54657EC4396D> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
0x7fff96884000 - 0x7fff9688fff7 libcsfde.dylib (471) <797691FA-FC0A-3A95-B6E8-BDB75AEAEDFD> /usr/lib/libcsfde.dylib
0x7fff968fb000 - 0x7fff968fdfff com.apple.OAuth (25 - 25) <EE765AF0-2BB6-3689-9EAA-689BF1F02A0D> /System/Library/PrivateFrameworks/OAuth.framework/Versions/A/OAuth
0x7fff96902000 - 0x7fff96912ff7 libbsm.0.dylib (34) <A3A2E56C-2B65-37C7-B43A-A1F926E1A0BB> /usr/lib/libbsm.0.dylib
0x7fff96913000 - 0x7fff96941fff com.apple.CoreServicesInternal (221.1 - 221.1) <51BAE6D2-84F3-392A-BFEC-A3B47B80A3D2> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesInternal
0x7fff9694c000 - 0x7fff9694eff7 libsystem_sandbox.dylib (358.1.1) <DB9962EF-8898-31CC-9B87-E01F8CE74C9D> /usr/lib/system/libsystem_sandbox.dylib
0x7fff969ff000 - 0x7fff96bafff7 com.apple.QuartzCore (1.10 - 361.11) <7382E4A9-10B0-3877-B9D7-FA84DC71BA55> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
0x7fff96bb0000 - 0x7fff96bb1ff7 libsystem_blocks.dylib (65) <9615D10A-FCA7-3BE4-AA1A-1B195DACE1A1> /usr/lib/system/libsystem_blocks.dylib
0x7fff96c0d000 - 0x7fff96c61fff libc++.1.dylib (120) <1B9530FD-989B-3174-BB1C-BDC159501710> /usr/lib/libc++.1.dylib
0x7fff96c62000 - 0x7fff96c6bfff libGFXShared.dylib (11.0.7) <EC449E3A-D9D2-3494-8B6C-DEB7B11EEDAB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x7fff96cab000 - 0x7fff96d12ff7 com.apple.framework.CoreWiFi (3.0 - 300.4) <19269C1D-EB29-384A-83F3-7DDDEB7D9DAD> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
0x7fff96dc9000 - 0x7fff96e68df7 com.apple.AppleJPEG (1.0 - 1) <9BB3D7DF-630A-3E1C-A124-12D6C4D0DE70> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
0x7fff96e76000 - 0x7fff96fbcfef libsqlite3.dylib (168) <8B78BED1-7B9B-3943-80DC-0871015AEAC4> /usr/lib/libsqlite3.dylib
0x7fff96fbd000 - 0x7fff96fdcfff com.apple.CoreDuet (1.0 - 1) <36AA9FD5-2685-314D-B364-3FA4688D86BD> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
0x7fff96fdd000 - 0x7fff970cffff libxml2.2.dylib (26) <B834E7C8-EC3E-3382-BC5A-DA38DC4D720C> /usr/lib/libxml2.2.dylib
0x7fff970f1000 - 0x7fff9711efff com.apple.Accounts (113 - 113) <3145FCC2-D297-3DD1-B74B-9E7DBB0EE33C> /System/Library/Frameworks/Accounts.framework/Versions/A/Accounts
0x7fff9711f000 - 0x7fff97123ff7 libGIF.dylib (1231) <B3D2DF96-A67D-31EA-9A1B-E870B54855EE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x7fff97124000 - 0x7fff9716dff3 com.apple.HIServices (1.22 - 519) <59D78E07-C3F1-3272-88F1-876B836D5517> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x7fff9716e000 - 0x7fff97681ff3 com.apple.JavaScriptCore (10600 - 10600.1.17) <CE5255CC-E13F-3694-B6DD-5285356BFCC0> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
0x7fff97682000 - 0x7fff9768affb com.apple.CoreServices.FSEvents (1210 - 1210) <782A9C69-7A45-31A7-8960-D08A36CBD0A7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framework/Versions/A/FSEvents
0x7fff976bd000 - 0x7fff976c1fff libCoreVMClient.dylib (79) <FC4E08E3-749E-32FF-B5E9-211F29864831> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
0x7fff976c2000 - 0x7fff976ccff7 com.apple.NetAuth (5.0 - 5.0) <B9EC5425-D38D-308C-865F-207E0A98BAC7> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
0x7fff9785d000 - 0x7fff97879fff com.apple.GenerationalStorage (2.0 - 209.11) <9FF8DD11-25FB-3047-A5BF-9415339B3EEC> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalStorage
0x7fff97881000 - 0x7fff97882ffb libremovefile.dylib (35) <3485B5F4-6CE8-3C62-8DFD-8736ED6E8531> /usr/lib/system/libremovefile.dylib
0x7fff978a7000 - 0x7fff978c2ff7 com.apple.aps.framework (4.0 - 4.0) <9955CAFD-D56B-36E9-BB41-6F7F73317EB5> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
0x7fff978c3000 - 0x7fff97cf3fff com.apple.vision.FaceCore (3.1.6 - 3.1.6) <C3B823AA-C261-37D3-B4AC-C59CE91C8241> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
0x7fff97d42000 - 0x7fff97d7cffb com.apple.DebugSymbols (115 - 115) <6F03761D-7C3A-3C80-8031-AA1C1AD7C706> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
0x7fff97d7d000 - 0x7fff97eb7ff7 com.apple.ImageIO.framework (3.3.0 - 1038) <AB3C40DB-FCBE-3315-B7B2-4E16522E20CB> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
0x7fff97eb8000 - 0x7fff97ec6ff7 com.apple.opengl (11.0.7 - 11.0.7) <B5C4DF85-37BD-3984-98D1-90A5043DA984> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x7fff97efa000 - 0x7fff97f69fff com.apple.SearchKit (1.4.0 - 1.4.0) <BFD6D876-36BA-3A3B-9F15-3E2F7DE6E89D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framework/Versions/A/SearchKit
0x7fff97f6a000 - 0x7fff97f6bfff libsystem_secinit.dylib (18) <581DAD0F-6B63-3A48-B63B-917AF799ABAA> /usr/lib/system/libsystem_secinit.dylib
0x7fff97f6c000 - 0x7fff97f86ff7 libextension.dylib (55.1) <ECBDCC15-FA19-3578-961C-B45FCC994BAF> /usr/lib/libextension.dylib
0x7fff97fb6000 - 0x7fff98011fef libTIFF.dylib (1231) <115791FB-8C49-3410-AC23-56F4B1CFF124> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
Thanks onoffMEDIA for the details and crashlog information.
We will look at the crashlog and will try to address this issue as soon as possible.
Regarding ADE crashing as soon as you double click on the ADE,
It is happening becaus you got the crash in ADE and when you launch ADE (by double clicking on it). ADE is trying to open the same book and hence getting crashed again and again.
We will address this issue as well in our coming releases.
As a workaround to resolve this, you can try to open any epub file directly by right-click on the file and open-with ADE option.
ADE should be able to open the book correctly.
Please let us know if it does not work for you.
Also crashing for me trying to open a library book, or trying to send it to my ereader.
Using Mavericks and 4.0.2.103411
And people wonder why DRM gets a bad rap.... SO frustrating.
Are you suggesting that it works fine and you can't duplicate the error? This has been going on for years.. it's intermittant (only on most books) which leans me to beleive it's Adobe.
AE keeps crashing on my computer as well. Help please!! It crashes when I try to open a acsm file... I have tried many books and the same thing happens.
Process: Adobe Digital Editions [437]
Path: /Applications/Adobe Digital Editions 4.0.app/Contents/MacOS/Adobe Digital Editions
Identifier: com.adobe.adobedigitaleditions.app
Version: 4.0.2 (1)
Code Type: X86-64 (Native)
Parent Process: launchd [158]
Responsible: Adobe Digital Editions [437]
User ID: 501
Date/Time: 2014-12-08 18:32:42.560 -0500
OS Version: Mac OS X 10.9.5 (13F34)
Report Version: 11
Anonymous UUID: 8A2BF1EF-E920-3971-6DF6-11480F8335F5
Sleep/Wake UUID: 6ED9B205-CC93-4257-8924-C2362F53813B
Crashed Thread: 0 Dispatch queue: com.apple.main-thread
Exception Type: EXC_BAD_ACCESS (SIGSEGV)
Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
I managed to do a work around, as crashing every time meant I was not able to read my books. I uninstalled ADE 4.0 and installed an older version, 3.0. Then when I downloaded the books, I did not doubleclick on the ascm file. Instead, I opened ADE and selected Library > Add file. I found the ascm file in the folder then added it to the library. This was successful. I then opened the book in ADE library. I'm doing all of this on a MacBook Air with borrowed books from the public library.
It is unfortunate that ADE4 kept crashing for you. I will strongly recommend you to use ADE4 as it comes up some good features and support for epub3 format.
Regarding the crash issue, We are working on addressing this issue in coming releases.
As I suggested before, If ADE crashes on for you on launch. Please open any other epub/pdf file directly and ADE should work fine then.
