2. Re: Font Title Not Displaying in Character Panel > Font Menu
Jacob Bugge Oct 19, 2014 8:51 AM (in response to fonts not displaying)fonts, björn,
Have you reinstalled CS5 after upgrading to Yosemite?
If the issue persists, I am afraid there are quite a few mismatches between Yosemite and multiple versions of Illy, so I believe the sorting is for Apple rather than Adobe.
3. Re: Font Title Not Displaying in Character Panel > Font Menu
Monika Gause Oct 19, 2014 8:57 AM (in response to bjornericsson)Try and check "Show Font names in English" in Preferences > Type.
4. Re: Font Title Not Displaying in Character Panel > Font Menu
bjornericsson Oct 19, 2014 9:45 AM (in response to Jacob Bugge)Hi Jacob,
I have not yet tried re-installing CS5 after the Yosemite upgrade but if all else fails, that's probably the only way to go.
Other applications in the Suite, like Indesign, works just fine, as it should; only Illustrator being stubborn
5. Re: Font Title Not Displaying in Character Panel > Font Menu
bjornericsson Oct 19, 2014 9:50 AM (in response to Monika Gause)Thanks for the advice Monika.
I tried your suggestion but it was of little use, the problem still persists.
Might be as Jacob said, a reinstallation of all the software is the only way to go?
6. Re: Font Title Not Displaying in Character Panel > Font Menu
Monika Gause Oct 19, 2014 10:05 AM (in response to bjornericsson)Do you by chance have any font management running?
7. Re: Font Title Not Displaying in Character Panel > Font Menu
fonts not displaying Oct 19, 2014 10:29 AM (in response to Jacob Bugge)Jacob,
Thanks for reinstall suggestion. Going to try that.
8. Re: Font Title Not Displaying in Character Panel > Font Menu
fonts not displaying Oct 19, 2014 10:33 AM (in response to Monika Gause)Monika,
Tried selecting "Show Font names in English" with no resolution as well. Not running any font management software. Going to try a reinstall
10. Re: Font Title Not Displaying in Character Panel > Font Menu
Jacob Bugge Oct 20, 2014 4:31 AM (in response to fonts not displaying)fonts, björn, scott,
Unless three step reinstallation helps, you may wish to roll back from Yosemite and wait to see whether the issues will be solved and reported as such.
Weeding out in older plugins seems to have helped some in some cases. It also seems that JAVA Runtime may be involved, for some it seems to help to roll back to an ealier version, for others to update to the newest.
All the above is more or less hearsay so far, with no definite final confirmation.
In any case, there is something to be sorted out by someone.
11. Re: Font Title Not Displaying in Character Panel > Font Menu
ConorM Oct 21, 2014 12:37 AM (in response to Jacob Bugge)Experiencing the same problem here. Font titles not being displayed.
I tried re-installing but it did not resolve the issue.
I do wonder if I re-installed correctly. I did not remove the original install of Illustrator (CS5.1). I only ran the installer again, selecting Illustrator to be installed.
Is it better to remove it first before re-installing? And if so what is the best practice for removing it?
12. Re: Font Title Not Displaying in Character Panel > Font Menu
markdelfs Oct 23, 2014 10:10 AM (in response to fonts not displaying)I think I have the answer! Adobe Illustrator CS5 Font Menu Display Fix in OSX Yosemite
Report back if this works and pass it on if it does--it worked for me the moment I hit the checkbox.
13. Re: Font Title Not Displaying in Character Panel > Font Menu
fonts not displaying Oct 23, 2014 1:05 PM (in response to markdelfs)@markdelfs Boom! That did the trick for me! All is well now
14. Re: Font Title Not Displaying in Character Panel > Font Menu
bjornericsson Oct 23, 2014 1:37 PM (in response to markdelfs)That worked for me too!
Open the Mac OS X System Preferences and head to ‘Accessibility.’ Once you are in there, select ‘Display’ from the left-hand list and then check the checkbox that says “Reduce transparency.”
Apple's OS X Yosemite eye-candy with transparency was the culprit here!
Great find, thanks@markdelfs
15. Re: Font Title Not Displaying in Character Panel > Font Menu
legendary singer Nov 22, 2014 1:29 AM (in response to bjornericsson)it works for me as well...:)
16. Re: Font Title Not Displaying in Character Panel > Font Menu
CLee Nov 28, 2014 2:34 PM (in response to fonts not displaying)Yes, works perfectly. Thanks.
