1. Re: Error Executing Database Query
WolfShade Oct 17, 2014 5:52 AM (in response to mega_L)I have never used CFSTOREDPROC, so can't really comment on this. But, I'd check the Adobe CF docs on CFSTOREDPROC and check if anything has changed between CF8 and CF10.
V/r,
^_^
2. Re: Error Executing Database Query
BKBK Oct 17, 2014 8:25 AM (in response to mega_L)mega_L wrote:
SELECT case trim(to_char(SYSDATE, 'DAY')) WHEN 'MONDAY' then '1' else '2' end AS TodaysDate from dual
SELECT Count(other_id) AS NoRecFound FROM gl_dup_ids_ssns WHERE Trim(create_date) =
SELECT Count(other_id) AS NoRecFound FROM gl_dup_ids_ssns WHERE Trim(create_date) = CF codes to Stop the process and email admin
Surely, that cannot be the actual SQL, as it is obviously invalid.
3. Re: Error Executing Database Query
mega_L Oct 20, 2014 8:03 AM (in response to BKBK)I looked at the CF administrator application log and see a better error message: Error Executing Database Query. Executing stored procedures is not allowed Is there a setting in the administrator where I can enable and disable ColdFusion to use CFSTOREPROC? if there is, I can't find it. For BKBK:
That query is actually working because I can see it got run in the debug screen
4. Re: Error Executing Database Query
mega_L Oct 20, 2014 8:26 AM (in response to mega_L)I found the answer! In case someone out there also facing the same issue. In the administrator, Datasource Advance setting, go down and find: Allowed SQL where there are checkboxes for Select, Update,Delete,Insert and one of them is store procedure checkbox. My checkbox was not checked that's why ColdFusion can't call a store procedure. I Checked and saved it and I'm good to go.
5. Re: Error Executing Database Query
BKBK Oct 20, 2014 9:54 AM (in response to mega_L)Curious solution! Thanks, Mega_L, for sharing it with us.
