How to handle Coldfusion SOAP Web Service Errors
HaroonTyagi Oct 19, 2014 3:42 AMHi,
I have just created simple wsdl example:
My Component:
<cfcomponent displayname="mytest">
<cffunction name="service_login_authentication" access="remote" output="true" returntype="any" hint="Returns login">
<cfargument name="login" type="string" required="yes">
<cfargument name="password" type="string" required="yes">
<cfif #arguments.login# eq "abcdef" and #arguments.password# eq "123456">
<cfxml variable="soapRes">
<kps_response>
<message>OK</message>
<token>354dfdffsdf</token>
</kps_response>
</cfxml>
<cfelse>
<cfthrow type="MyException" message="INVALID LOGIN" errorcode="1000" />
</cfif>
<cfreturn soapRes >
</cffunction>
</cfcomponent>
Its generating wsdl and no problem with response but when generating any error like username and password does not match then it's generating fault code like this:
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
<soapenv:Body>
<soapenv:Fault>
<faultcode>soapenv:Server.userException</faultcode>
<faultstring>coldfusion.xml.rpc.CFCInvocationException: [coldfusion.runtime.CustomException : INVALID LOGIN. ]</faultstring>
<detail>
<ns1:hostname xmlns:ns1="http://xml.apache.org/axis/">HOST_NAME</ns1:hostname>
</detail>
</soapenv:Fault>
</soapenv:Body>
</soapenv:Envelope>
But I want customize Fault Code like this:
<soapenv:Body>
<soapenv:Fault>
<faultcode>1000</faultcode>
<faultstring>INVALID LOGIN</faultstring>
</soapenv:Fault>
</soapenv:Body>
</soapenv:Envelope>
Fault Code and Fault String should be customize and I don't want detail tag completely. In old ColdFusion version like ColdFusion 8 displaying detail tag with <ns1:stackTrace xmlns:ns1="http://xml.apache.org/axis/"> coldfusion.xml.rpc.CFCInvocationException: and so on.
Any suggestions on how to create customize faultcode and faultstring is very helpful.
Thanks!!
