I'm currently creating an interactive module where the learner will need to drag and drop grey squares to the correct area on the screen. If you see my picture below, I have a possible 20 grey squares needing to be dragged and dropped for each terminal that's on the lower right of the screen capture. I've created a shared action that shows different wires moving for each of the 20 grey squares moving from the upper image to the lower right image of the screen. This is painstakingly time consuming, but worth the effect. The problem I have stems from the drag and drop's "reset" button. The "reset" button helps set the grey squares that are my drag sources to their original positions, but it does not reset the shared actions that correspond to the movement of each grey square. Is there any way I can reset not only the drag sources, but also the shared actions associated with the drag sources? Any help is truly appreciated.
