Bookmarks are working in chm, but not in Webhelp output
Oct 23, 2014 Oct 23, 2014
I have one project that I have output both as a chm and as a webhelp project.  One one of the pages, I have some image maps linked to bookmarks on the same page.  These work fine in the CHM, but in the Webhelp, when I click on the image map area, nothing happens.  Am I missing a setting for Webhelp that makes these links work?
kb
(RH10)
288
Hi there
Check the bookmark name. Is there a space in it? If so, eliminate the space and re-link it.
Cheers... Rick
Oct 24, 2014 Oct 24, 2014
oh, Rick... I was so sure this MUST be the answer... but alas... it is not... no spaces... at least i don't see one via Design or HTML views... see below:
All 4 of the bookmarks above are on the same page as the image that is mapped... See anything else I am missing?
Hello again
Hmmmm, out of curiosity, is the page long enough that it is able to scroll to the bookmarked spot? Sometimes you have to position the insertion point at the end of the topic by pressing Ctrl+End, and press the Enter key 20 or 30 times so that you insert enough space for the page to scroll and position to the bookmark.
Cheers... Rick
It seems to be and they DO work in the CHM output which is puzzling to
me...
Ok... Here's one tidbit that might make a difference...
I have the book marks in drop down text... Now mind you, this works easily
in Flare... And when you click on the link, it not only takes you to the
drop down text, it OPENS the dd. However, with rh, the link takes you
only to the DD hotspot (heading) without expanding the DD (acceptable
because there's no other choice in RH). Again, this works fine in the CHM,
but not in the webhelp output.
OK... APPARENTLY... in Webhelp, bookmarks within drop down text won't
work...
After i sent the previous response i decided to try it out and see if that
might be the problem... and it so far seems to be.. need to publish the
files for our developers to try in the app... then I'll know for sure...
but for now, it's working in my Webhelp test output.
So sorry for the disturbance!
RoboHelp Documentation
Download Adobe RoboHelp
