1. Re: How can I align multiple titles in Premiere Pro?
Trevor_Asq Oct 23, 2014 1:14 PM (in response to bstoneking)TThere's a number of ways you can do this but easiest is probably to build the final title, with all bullets lined up as you want them to look in ONE title Over your background video.
Now copy your background video to V3 and V4
DIsable V4 copy
Crop or mask V3 copy so first bullet revealed and add transition to reveal V3
enable V4 clip
Roll edit point of V4 to where you want 2nd bullet to appear
crop/mask V4 clip to reveal first two bullet points
add transition to V4
you can repeat this to reveal the rest
(v3 is now covered by v4 so you can add an edit underneath )
its it's easier than it sounds...
2. Re: How can I align multiple titles in Premiere Pro?
Meg The Dog Oct 23, 2014 1:52 PM (in response to bstoneking)This technique will only work with current versions of PPro - it looks harder to do than it actually is:
Create the title with all the bullet points, aligned as you wish, in the Title Tool.
Exit the title tool, the title you just created will appear in your project.
Click on the title to select it (if it is not already selected) and then go to the menu Edit > Duplicate.
Repeat the duplication process to make as many copies as number of bullet points you want to transition on.
Place the first copy of the title where you want the Title to appear in your video.
Double click on the clip of the title on the timeline to re-open the Title Tool. Delete all the text except the first line.
Now place the second copy where you want it to appear in the video.
Double click on it to re-enter the Title Tool, and delete all the text except the first two lines.
Repeat this process for as many bullet points as you have, delating one fewer bullet point each time. You can add transitions at the cut points between the titles (such as a dissolve) to make the next bullet point appear as you wish.
If you try to to this using an early version of PPro this will not work as the titles and its copies are linked - so if you change one of the copies, it changes all the other titles. Fortunately this has been fixed in the current version.
MtD
3. Re: How can I align multiple titles in Premiere Pro?
shooternz Oct 23, 2014 2:18 PM (in response to bstoneking)Create a Single title with everything on it.
Use a Linear wipe Effect with key frames to reveal bullet point by bullet point.
Easy.
4. Re: How can I align multiple titles in Premiere Pro?
Trevor_Asq Oct 23, 2014 2:52 PM (in response to bstoneking)
