Product: RoboHelp 11 (TCS 5)
Menu location: Review > Create PDF for Review
Issue: The default output from the menu location results in output that is unusable: e.g., styles aren't mapping correctly, making the document difficult to read and review. Is there a default print layout or some other control available?
Ultimate objectives: Track changes, perform shared reviews, import comments from the generated PDF, and so forth.
Secondary questions: Can I import comments/markup from a shared review if I generated the PDF using the print layout, instead of the Review > Create PDF for Review menu option? If so, will I then be able to manage comments from the Review pane and perform other related-reviewing functions?
I believe it maps via CSS. I don't believe you can change this behaviour.
If you generate printed documentation, it is NOT possible to import the review comments.
Kind regards,
Willam
