1. Re: Setting sequences to render "work area" as a batch process in AME
mojareeves1 Oct 22, 2014 5:28 PM (in response to mojareeves1)I have to render out 750 videos this month and I do not wish to go through each sequence and set it to render the work area. In the last version of AME, render work area was default. Please let me know how I can set this as a batch process so I dont have to spend a whole day clicking through them one by one.
Thanks, Moja.
2. Re: Setting sequences to render "work area" as a batch process in AME
thnord Oct 22, 2014 8:47 PM (in response to mojareeves1)In CC 2014 the default is to render the sequence in/out. There is no way to change that setting on multiple sources at the same time. What I would recommend is setting the sequence in/out point instead of the work area and then you will get the behavior you desire. You could also submit a feature request for a more flexible solution. The feature request form can be found here: Adobe - Feature Request/Bug Report Form
3. Re: Setting sequences to render "work area" as a batch process in AME
mojareeves1 Oct 23, 2014 10:14 PM (in response to thnord)Thanks Thomas,
Ill submit a request and hopefully something will come of it. Previously, the work area was the default export setting which is why I used it over the in and out point. Its too much work for me to go through 750 sequences and set the in and out point so I'll have to change the setting on each sequence in AME.
