Hello,
Hopefully this is an easy issue that someone may be able to help me with. I am working on a WebHelp_Pro project (primary layout) and have created a new skin and modified it to my liking. However it does not appear that in the edit skins menu I can remove things I do not want on the toolbar (i.e. Glossary). It seems that in the Windows properties section that I can choose which items I want and where to position them. So when I get things in the order I want them and generate it does not show the items on the toolbar in the order I would prefer (custom logo, contents, index, search) and I also do not want the additional search box in the upper right. Any insight into what I can do to fix this would be appreciated.
Robohelp HTML 11
You’re creating the “Pro” flavour because you’re sending it to a RoboHelp Server instance, right?
Yes, we are using Robohelp Server 9.
HI there
I'll have to leave it to others to perhaps explain why the items aren't respecting the order of arrangement. But for the search in the toolbar, have you tried manipulating the following option?
Cheers... Rick
Hello again
In thinking of the skin stuff, I do recall when the option of the "Pro" stuff first appeared, folks would publish multiple projects to the server and the server would handle the merging. And it was possible to nominate one project as being the "Master", which meant that whatever skin selections were configured would override any other skin selections.
I'll have to leave it to John or Colum or another person that is well versed in the server bit to advise if this is still possible or an issue and how to address it.
Cheers... Rick
Yeah I've tried that both checked an unchecked and nothing changes.
