1 Reply Latest reply: Oct 25, 2014 2:48 PM by try67 RSS
    Save and Close the PDF form
    vijayk Community Member
      I've created PDF Form (Acrobat XI standard) with various field and button for sending the link of document location by outlook mail. I need the adobe java script for save the document in same location and close the document while i use the button for sending the link.
        • 1. Re: Save and Close the PDF form
          try67 CommunityMVP
          You can only save the file to a specific location if you can install a script on the local machine where the file is used.
          Otherwise the best you can do is cause the Save As dialog to open, but you can't force the file to be saved.
