2 Replies Latest reply: Oct 26, 2014 3:02 AM by 112jason RSS
    Premiere Pro Effect Mask Tracking problem
    112jason Community Member
      I love this new feature, when you just choose the elpise o square and blur out the licence plate for example
      but how to apply multiple masks and how to delete the mask for example when you do not need it, if the subject you want to mask out moves..
      now the mask is travelling around when the subject is out of frame and blurs other stuff that is not needed
      i hope you understand what I want to know
      so first
      1. how to delete the mask at specific frame
      2. how to change opacity of the mask to 0% after keyframe ( I created keyframe, changed the opacity to 0% but this then works for the whole clip not only after the keyframe)
        • 1. Re: Premiere Pro Effect Mask Tracking problem
          Trevor_Asq Community Member
          Not sure you can delete a mask at a specific frame - but you can move it offscreen / make it transparent - which would have the same effect.
          Opacity keyframes are seperate from movement keyframes - so to have opacity change you need to have at least 2 opacity keyframes
          • 2. Re: Premiere Pro Effect Mask Tracking problem
            I tried to play with opacity inside the mask, and setting ot to 100 % and to 0% but it changes all the clips
            So you are saying I should try the opacity settings that is above the blur opacity?
            Yes for now I am dragging the last keyframe outside but it is just time consuming....
            It took me like 2 hours to clean up easy car licence plate blur
            I will play with opacity later and report how it goes
