Every time when I paste a graphic into Edge Animate, the application swiftly suggests a name for the imported graphic. But the selection includes the file extension as well, which in most cases will need to remain the same. It would be easier (and safer) if the user could just start typing over the selected name part, without inadvertently forgetting or altering the extension, or needing to re-select just the name part. A small improvement for a better use of the application !
EDIT: I just noticed – in a daring mood – that if I just type anything without adding or leaving an extension, Edge Animate will suffix the proper extension anyway. Nevertheless, a more careful user like me is uncertain about the consequences and doesn't trust software as much...
