Attempting to install Flash player on a mac. System requirements are met; old versions uninstalled. I keep getting this error message "Install Adobe Flash Player" is damaged and can't be opened. You should eject the disk image.
Under System Preferences > Security and Privacy
Set Allow Apps Downloaded From:
App Store and Identified Developers
can you try installing from this zip file? http://download.macromedia.com/pub/flashplayer/installers/archive/fp_11.7.700.203_archive.zip
I tried; but got the same error message - "... damaged and can't be opened. You should eject (or close)..."
can you try following these instructions to bypass the gatekeepr functionality? http://avid.force.com/pkb/articles/en_US/Troubleshooting/Gatekeeper-blocking-installer
This worked for me thanks! I'm on : Mac Pro running OSX 10.10 Yosemite. I guess the upgrade reverted my Gatekeeper settings.
Solved the problem.
Open 'Terminal Mode', which is in the Users Library. (You have to pres 'Alt' to see the Users Library.) Then type in to 'Terminal':
xattr -c /Users/******/Downloads/InDesign_7_5_LS1.dmg (make sure that is the correct path to the correct installation file you are having problems with.)
I did this twice, because once did nothing (spelling error?).
Anyway, now Adobe InDesign is happily installing.
Happy Days..... 😉
didn't work for me
This post was from 2013. It's probably not the same thing...
I'd recommend starting a new post and describing the issue thoroughly.
Here's a guide:
https://forums.adobe.com/thread/1195540
Also, so that the people that posted on this in 2013 don't continue to get email updates, I'm locking this thread.
