Locked
1
flash won't install on Mac 10.10
Oct 28, 2014 Oct 28, 2014
My mac is OS X yosemite version 10.10 and saying flash was out of date so I followed instructions to update didn't work tried all the trouble shooting (including uninstalling flash and try reinstalling it) didn't work. It goes there the whole download process then toward the end it starts installing then says general installation error.
4.6K
Adobe Employee ,
Hello,
Please try the offline/standalone installer posted at the bottom of this page, Installation problems | Flash Player | Mac.
Maria
Like I said I already tried all the trouble shooting nothing worked, but I tried again and nothing just like the last 20 times I've done it.  just says installation failed
Adobe Employee ,
Please provide the last several install attempt entries from the ~/Library/Logs/FlashPlayerInstallManager.log file (users' Library, not system Library).  Entries begin and end as follows:
--- log started ---
some information
--- log end ---
DO you mean all this mumbo gumbo
2013-08-18 01:00:59 +0000 ---------- log start ----------
2013-08-18 01:00:59 +0000 All install checks pass
2013-08-18 01:00:59 +0000 [install started]
2013-08-18 01:01:10 +0000 [install succeeded]
2013-08-18 01:01:13 +0000 ----------  log end  ----------
2013-08-18 01:01:12 +0000 Changing update mode to 0
2013-09-16 14:58:06 +0000 ---------- log start ----------
2013-09-16 14:58:06 +0000 1214
2013-09-16 14:58:07 +0000 1214
2013-09-16 14:58:45 +0000 18133029
2013-09-16 14:58:45 +0000 verifySignatureWithData : Message Verified!
2013-09-16 14:58:51 +0000 ----------  log end  ----------
2013-09-16 14:58:56 +0000 ---------- log start ----------
2013-09-16 14:58:56 +0000 All install checks pass
2013-09-16 17:45:01 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-09-16 17:45:52 +0000 [install started]
dyld: DYLD_ environment variables being ignored because main executable (/var/folders/7j/dsxkdzd903l4318tmmlx0_440000gn/T/FPInstallHelper) is setuid or setgid
dyld: DYLD_ environment variables being ignored because main executable (/System/Library/PrivateFrameworks/Install.framework/Resources/runner) is setuid or setgid
installer: Package name is PlugIn
installer: Upgrading at base path /
installer: The upgrade was successful.
sudo: no tty present and no askpass program specified
2013-09-16 17:46:03 +0000 [install completed]
2013-09-16 17:46:03 +0000 [install succeeded]
2013-09-16 17:48:15 +0000 ----------  log end  ----------
2013-09-16 17:48:14 +0000 Changing update mode to 0
2013-11-18 15:17:38 +0000 ---------- log start ----------
2013-11-18 15:17:38 +0000 1389
2013-11-18 15:17:39 +0000 1389
2013-11-18 15:17:47 +0000 ----------  log end  ----------
2013-11-18 15:28:59 +0000 ---------- log start ----------
2013-11-18 15:28:59 +0000 All install checks pass
2013-11-18 15:29:00 +0000 [install started]
2013-11-18 15:29:11 +0000 [install succeeded]
2013-11-18 15:29:11 +0000 ----------  log end  ----------
2014-01-14 21:37:38 +0000 ---------- log start ----------
2014-01-14 21:37:38 +0000 1386
2014-01-14 21:37:39 +0000 1386
2014-01-14 21:37:44 +0000 ----------  log end  ----------
2014-01-27 04:20:11 +0000 ---------- log start ----------
2014-01-27 04:20:11 +0000 1386
2014-01-27 04:20:13 +0000 1386
2014-02-07 21:45:40 +0000 ----------  log end  ----------
2014-02-04 19:48:31 -0600   IM: All install checks pass
2014-02-04 19:48:31 -0600   IM: [install started]
2014-02-04 19:48:36 -0600 FIN: [finalizer started]
2014-02-04 19:48:36 -0600 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-04 19:48:36 -0600 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-04 19:48:38 -0600 FIN: Unable to create directory '(null)'.
2014-02-04 19:48:38 -0600 FIN: [finalizer failed]
installer: Package name is Adobe Flash Player
2014-02-04 19:48:44 -0600   IM: [install succeeded]
2014-02-04 19:48:44 -0600   IM: ----------  log end  ----------
2014-02-21 18:13:55 -0600   IM: ---------- log start ----------
2014-02-21 18:13:55 -0600   IM: All install checks pass
2014-02-21 18:13:55 -0600   IM: [install started]
2014-02-21 18:14:00 -0600 FIN: [finalizer started]
2014-02-21 18:14:00 -0600 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-21 18:14:00 -0600 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-21 18:14:02 -0600 FIN: Unable to create directory '(null)'.
2014-02-21 18:14:02 -0600 FIN: [finalizer failed]
2014-02-21 18:14:07 -0600   IM: [install succeeded]
2014-02-21 18:14:07 -0600   IM: ----------  log end  ----------
2014-03-07 22:39:50 -0600 SAU: End SAU run with exit code: 2002
2014-03-12 23:21:23 -0500   IM: ---------- log start ----------
2014-03-12 23:21:23 -0500   IM: All install checks pass
2014-03-12 23:21:23 -0500   IM: [install started]
2014-03-12 23:21:27 -0500 FIN: [finalizer started]
2014-03-12 23:21:27 -0500 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-03-12 23:21:27 -0500 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-03-12 23:21:30 -0500 FIN: Unable to create directory '(null)'.
2014-03-12 23:21:30 -0500 FIN: [finalizer failed]
2014-03-12 23:21:35 -0500   IM: [install succeeded]
2014-03-12 23:21:35 -0500   IM: ----------  log end  ----------
2014-03-28 21:16:46 -0500 SAU: End SAU run with exit code: 2002
2014-04-12 10:34:10 -0500   IM: ---------- log start ----------
2014-04-12 10:34:10 -0500   IM: 1387
2014-04-12 10:34:11 -0500   IM: 1387
2014-04-12 10:34:16 -0500   IM: ----------  log end  ----------
2014-04-16 23:37:35 -0500   IM: ---------- log start ----------
2014-04-16 23:37:35 -0500   IM: All install checks pass
2014-04-16 23:37:35 -0500   IM: [install started]
2014-04-16 23:37:39 -0500 FIN: [finalizer started]
2014-04-16 23:37:39 -0500 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-16 23:37:39 -0500 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-16 23:37:41 -0500 FIN: Unable to create directory '(null)'.
2014-04-16 23:37:41 -0500 FIN: [finalizer failed]
2014-04-16 23:37:47 -0500   IM: [install succeeded]
2014-04-16 23:37:47 -0500   IM: ----------  log end  ----------
2014-04-29 09:49:02 -0500   IM: ---------- log start ----------
2014-04-29 09:49:02 -0500   IM: All install checks pass
2014-04-29 09:49:02 -0500   IM: [install started]
2014-04-29 09:49:07 -0500 FIN: [finalizer started]
2014-04-29 09:49:07 -0500 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-29 09:49:07 -0500 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-29 09:49:09 -0500 FIN: Unable to create directory '(null)'.
2014-04-29 09:49:09 -0500 FIN: [finalizer failed]
2014-04-29 09:49:14 -0500   IM: [install succeeded]
2014-04-29 09:49:14 -0500   IM: ----------  log end  ----------
2014-05-14 14:42:38 -0500   IM: ---------- log start ----------
2014-05-14 14:42:38 -0500   IM: All install checks pass
2014-05-14 14:42:38 -0500   IM: [install started]
2014-05-14 14:42:43 -0500 FIN: [finalizer started]
2014-05-14 14:42:43 -0500 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-05-14 14:42:43 -0500 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-05-14 14:42:44 -0500 FIN: Unable to create directory '(null)'.
2014-05-14 14:42:44 -0500 FIN: [finalizer failed]
2014-05-14 14:42:51 -0500   IM: [install succeeded]
2014-05-14 14:42:51 -0500   IM: ----------  log end  ----------
2014-06-19 09:48:21 -0500   IM: ---------- log start ----------
2014-06-19 09:48:21 -0500   IM: 1387
2014-06-19 09:48:23 -0500   IM: 1387
2014-06-25 11:54:35 -0500 SAU: End SAU run with exit code: 2002
2014-07-01 10:22:37 -0500   IM: ----------  log end  ----------
2014-07-08 16:45:48 -0500   IM: ---------- log start ----------
2014-07-08 16:45:48 -0500   IM: All install checks pass
2014-07-08 16:45:48 -0500   IM: [install started]
2014-07-08 16:45:52 -0500 FIN: [finalizer started]
2014-07-08 16:45:52 -0500 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-07-08 16:45:52 -0500 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-07-08 16:45:54 -0500 FIN: Unable to create directory '(null)'.
2014-07-08 16:45:54 -0500 FIN: [finalizer failed]
2014-07-08 16:46:00 -0500   IM: [install succeeded]
2014-07-08 16:46:00 -0500   IM: ----------  log end  ----------
2014-08-14 01:12:09 -0500   IM: ---------- log start ----------
2014-08-14 01:12:10 -0500   IM: 1407
2014-08-14 01:12:13 -0500   IM: ----------  log end  ----------
2014-08-21 10:41:04 -0500   IM: ---------- log start ----------
2014-08-21 10:41:05 -0500   IM: 1407
2014-08-21 10:41:07 -0500   IM: ----------  log end  ----------
2014-08-28 12:30:28 -0500   IM: ---------- log start ----------
2014-08-28 12:30:28 -0500   IM: 1407
2014-08-28 12:30:29 -0500   IM: 1407
2014-08-28 12:30:33 -0500   IM: ----------  log end  ----------
2014-09-06 16:08:36 -0500   IM: ---------- log start ----------
2014-09-06 16:08:36 -0500   IM: 1407
2014-09-06 16:08:37 -0500   IM: 1407
2014-09-06 16:08:42 -0500   IM: ----------  log end  ----------
2014-09-09 23:55:42 -0500   IM: ---------- log start ----------
2014-09-09 23:55:42 -0500   IM: All install checks pass
2014-09-09 23:55:42 -0500   IM: [install started]
2014-09-09 23:55:46 -0500 FIN: [finalizer started]
2014-09-09 23:55:46 -0500 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-09-09 23:55:46 -0500 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-09-09 23:55:48 -0500 FIN: Unable to create directory '(null)'.
2014-09-09 23:55:48 -0500 FIN: [finalizer failed]
2014-09-09 23:55:54 -0500   IM: [install succeeded]
2014-09-09 23:55:54 -0500   IM: ----------  log end  ----------
2014-10-09 18:56:30 -0500 SAU: End SAU run with exit code: 2002
2014-10-15 13:55:14 -0500   IM: ---------- log start ----------
2014-10-15 13:55:14 -0500   IM: 1407
2014-10-15 13:55:15 -0500   IM: 1407
2014-10-15 17:33:01 -0500   IM: ----------  log end  ----------
2014-10-22 15:49:57 -0500   IM: ---------- log start ----------
2014-10-22 15:49:58 -0500   IM: 1387
2014-10-24 15:51:17 -0500   IM: ----------  log end  ----------
2014-10-26 12:18:59 -0500   IM: ---------- log start ----------
2014-10-26 12:18:59 -0500   IM: All install checks pass
2014-10-26 12:18:59 -0500   IM: Unexpected umask value for process: 0
2014-10-26 12:18:59 -0500   IM: User has 1 process that needs to be closed.
2014-10-26 12:18:59 -0500   IM: Install failed with error code: 17.
2014-10-26 12:18:59 -0500   IM: ----------  log end  ----------
2014-10-26 12:20:20 -0500   IM: ---------- log start ----------
2014-10-26 12:20:20 -0500   IM: All install checks pass
2014-10-26 12:20:20 -0500   IM: Unexpected umask value for process: 0
2014-10-26 12:20:20 -0500   IM: User has 1 process that needs to be closed.
2014-10-26 12:20:20 -0500   IM: Install failed with error code: 17.
2014-10-26 12:20:20 -0500   IM: ----------  log end  ----------
2014-10-26 12:20:27 -0500   IM: ---------- log start ----------
2014-10-26 12:20:27 -0500   IM: All install checks pass
2014-10-26 12:20:27 -0500   IM: Unexpected umask value for process: 0
2014-10-26 12:20:28 -0500   IM: User has 1 process that needs to be closed.
2014-10-26 12:20:28 -0500   IM: Install failed with error code: 17.
2014-10-26 12:20:28 -0500   IM: ----------  log end  ----------
2014-10-26 12:20:40 -0500   IM: ---------- log start ----------
2014-10-26 12:20:40 -0500   IM: All install checks pass
2014-10-26 12:20:40 -0500   IM: Unexpected umask value for process: 0
2014-10-26 12:20:40 -0500   IM: User has 1 process that needs to be closed.
2014-10-26 12:20:40 -0500   IM: Install failed with error code: 17.
2014-10-26 12:20:40 -0500   IM: ----------  log end  ----------
2014-10-26 12:20:50 -0500   IM: ---------- log start ----------
2014-10-26 12:20:50 -0500   IM: All install checks pass
2014-10-26 12:20:50 -0500   IM: Unexpected umask value for process: 0
2014-10-26 12:20:50 -0500   IM: User has 1 process that needs to be closed.
2014-10-26 12:20:50 -0500   IM: Install failed with error code: 17.
2014-10-26 12:20:50 -0500   IM: ----------  log end  ----------
2014-10-26 12:20:57 -0500   IM: ---------- log start ----------
2014-10-26 12:20:57 -0500   IM: All install checks pass
2014-10-26 12:20:57 -0500   IM: Unexpected umask value for process: 0
2014-10-26 12:20:58 -0500   IM: User does not have any processes that need to be closed.
2014-10-26 12:20:58 -0500   IM: [install started]
installer: Error trying to locate volume at /
2014-10-26 12:20:59 -0500   IM: [install failed: 1]
2014-10-26 12:20:59 -0500   IM: Install failed with error code: 1.
2014-10-26 12:20:59 -0500   IM: ----------  log end  ----------
2014-10-28 00:09:20 -0500   IM: ---------- log start ----------
2014-10-28 00:09:20 -0500   IM: All install checks pass
2014-10-28 00:09:20 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:09:20 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 00:09:20 -0500   IM: Install failed with error code: 17.
2014-10-28 00:09:20 -0500   IM: ----------  log end  ----------
2014-10-28 00:12:16 -0500   IM: ---------- log start ----------
2014-10-28 00:12:16 -0500   IM: All install checks pass
2014-10-28 00:12:16 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:12:17 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 00:12:17 -0500   IM: Install failed with error code: 17.
2014-10-28 00:12:17 -0500   IM: ----------  log end  ----------
2014-10-28 00:12:25 -0500   IM: ---------- log start ----------
2014-10-28 00:12:25 -0500   IM: All install checks pass
2014-10-28 00:12:25 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:12:25 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 00:12:25 -0500   IM: Install failed with error code: 17.
2014-10-28 00:12:25 -0500   IM: ----------  log end  ----------
2014-10-28 00:12:26 -0500   IM: ---------- log start ----------
2014-10-28 00:12:26 -0500   IM: All install checks pass
2014-10-28 00:12:26 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:12:26 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 00:12:26 -0500   IM: Install failed with error code: 17.
2014-10-28 00:12:26 -0500   IM: ----------  log end  ----------
2014-10-28 00:12:27 -0500   IM: ---------- log start ----------
2014-10-28 00:12:27 -0500   IM: All install checks pass
2014-10-28 00:12:27 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:12:27 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 00:12:27 -0500   IM: Install failed with error code: 17.
2014-10-28 00:12:27 -0500   IM: ----------  log end  ----------
2014-10-28 00:12:28 -0500   IM: ---------- log start ----------
2014-10-28 00:12:28 -0500   IM: All install checks pass
2014-10-28 00:12:28 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:12:28 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 00:12:28 -0500   IM: Install failed with error code: 17.
2014-10-28 00:12:28 -0500   IM: ----------  log end  ----------
2014-10-28 00:12:40 -0500   IM: ---------- log start ----------
2014-10-28 00:12:40 -0500   IM: All install checks pass
2014-10-28 00:12:40 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:12:40 -0500   IM: User does not have any processes that need to be closed.
2014-10-28 00:12:40 -0500   IM: [install started]
2014-10-28 00:12:41 -0500   IM: [install failed: 1]
2014-10-28 00:12:41 -0500   IM: Install failed with error code: 1.
2014-10-28 00:12:41 -0500   IM: ----------  log end  ----------
2014-10-28 00:14:03 -0500   IM: ---------- log start ----------
2014-10-28 00:14:03 -0500   IM: All install checks pass
2014-10-28 00:14:03 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:14:04 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 00:14:04 -0500   IM: Install failed with error code: 17.
2014-10-28 00:14:04 -0500   IM: ----------  log end  ----------
2014-10-28 00:14:18 -0500   IM: ---------- log start ----------
2014-10-28 00:14:18 -0500   IM: All install checks pass
2014-10-28 00:14:18 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:14:18 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 00:14:18 -0500   IM: Install failed with error code: 17.
2014-10-28 00:14:18 -0500   IM: ----------  log end  ----------
2014-10-28 00:25:44 -0500   IM: ---------- log start ----------
2014-10-28 00:25:44 -0500   IM: All install checks pass
2014-10-28 00:25:44 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:25:45 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 00:25:45 -0500   IM: Install failed with error code: 17.
2014-10-28 00:25:45 -0500   IM: ----------  log end  ----------
2014-10-28 00:26:08 -0500   IM: ---------- log start ----------
2014-10-28 00:26:08 -0500   IM: All install checks pass
2014-10-28 00:26:08 -0500   IM: Unexpected umask value for process: 0
2014-10-28 00:26:09 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 00:26:09 -0500   IM: Install failed with error code: 17.
2014-10-28 00:26:09 -0500   IM: ----------  log end  ----------
2014-10-28 10:09:49 -0500   IM: ---------- log start ----------
2014-10-28 10:09:49 -0500   IM: All install checks pass
2014-10-28 10:09:49 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:09:50 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:09:50 -0500   IM: Install failed with error code: 17.
2014-10-28 10:09:50 -0500   IM: ----------  log end  ----------
2014-10-28 10:10:38 -0500   IM: ---------- log start ----------
2014-10-28 10:10:38 -0500   IM: All install checks pass
2014-10-28 10:10:38 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:10:39 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:10:39 -0500   IM: Install failed with error code: 17.
2014-10-28 10:10:39 -0500   IM: ----------  log end  ----------
2014-10-28 10:10:48 -0500   IM: ---------- log start ----------
2014-10-28 10:10:48 -0500   IM: All install checks pass
2014-10-28 10:10:48 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:10:48 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:10:48 -0500   IM: Install failed with error code: 17.
2014-10-28 10:10:48 -0500   IM: ----------  log end  ----------
2014-10-28 10:10:51 -0500   IM: ---------- log start ----------
2014-10-28 10:10:51 -0500   IM: All install checks pass
2014-10-28 10:10:51 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:10:51 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:10:51 -0500   IM: Install failed with error code: 17.
2014-10-28 10:10:51 -0500   IM: ----------  log end  ----------
2014-10-28 10:10:52 -0500   IM: ---------- log start ----------
2014-10-28 10:10:52 -0500   IM: All install checks pass
2014-10-28 10:10:52 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:10:52 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:10:52 -0500   IM: Install failed with error code: 17.
2014-10-28 10:10:52 -0500   IM: ----------  log end  ----------
2014-10-28 10:10:53 -0500   IM: ---------- log start ----------
2014-10-28 10:10:53 -0500   IM: All install checks pass
2014-10-28 10:10:53 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:10:53 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:10:53 -0500   IM: Install failed with error code: 17.
2014-10-28 10:10:53 -0500   IM: ----------  log end  ----------
2014-10-28 10:10:54 -0500   IM: ---------- log start ----------
2014-10-28 10:10:54 -0500   IM: All install checks pass
2014-10-28 10:10:54 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:10:54 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:10:54 -0500   IM: Install failed with error code: 17.
2014-10-28 10:10:54 -0500   IM: ----------  log end  ----------
2014-10-28 10:10:55 -0500   IM: ---------- log start ----------
2014-10-28 10:10:55 -0500   IM: All install checks pass
2014-10-28 10:10:55 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:10:55 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:10:55 -0500   IM: Install failed with error code: 17.
2014-10-28 10:10:55 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:10 -0500   IM: ---------- log start ----------
2014-10-28 10:11:10 -0500   IM: All install checks pass
2014-10-28 10:11:10 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:10 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:10 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:10 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:11 -0500   IM: ---------- log start ----------
2014-10-28 10:11:11 -0500   IM: All install checks pass
2014-10-28 10:11:11 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:11 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:11 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:11 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:16 -0500   IM: ---------- log start ----------
2014-10-28 10:11:16 -0500   IM: All install checks pass
2014-10-28 10:11:16 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:16 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:16 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:16 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:17 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:17 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:17 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:17 -0500   IM: ---------- log start ----------
2014-10-28 10:11:17 -0500   IM: All install checks pass
2014-10-28 10:11:17 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:18 -0500   IM: ---------- log start ----------
2014-10-28 10:11:18 -0500   IM: All install checks pass
2014-10-28 10:11:18 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:18 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:18 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:18 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:19 -0500   IM: ---------- log start ----------
2014-10-28 10:11:19 -0500   IM: All install checks pass
2014-10-28 10:11:19 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:19 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:19 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:19 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:20 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:20 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:20 -0500   IM: ---------- log start ----------
2014-10-28 10:11:20 -0500   IM: All install checks pass
2014-10-28 10:11:20 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:20 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:21 -0500   IM: ---------- log start ----------
2014-10-28 10:11:21 -0500   IM: All install checks pass
2014-10-28 10:11:21 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:21 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:21 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:21 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:22 -0500   IM: ---------- log start ----------
2014-10-28 10:11:22 -0500   IM: All install checks pass
2014-10-28 10:11:22 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:22 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:22 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:22 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:23 -0500   IM: ---------- log start ----------
2014-10-28 10:11:23 -0500   IM: All install checks pass
2014-10-28 10:11:23 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:23 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:23 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:23 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:24 -0500   IM: ---------- log start ----------
2014-10-28 10:11:24 -0500   IM: All install checks pass
2014-10-28 10:11:24 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:24 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:24 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:24 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:25 -0500   IM: ---------- log start ----------
2014-10-28 10:11:25 -0500   IM: All install checks pass
2014-10-28 10:11:25 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:25 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:25 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:25 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:26 -0500   IM: ---------- log start ----------
2014-10-28 10:11:26 -0500   IM: All install checks pass
2014-10-28 10:11:26 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:26 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:26 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:26 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:27 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:27 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:27 -0500   IM: ---------- log start ----------
2014-10-28 10:11:27 -0500   IM: All install checks pass
2014-10-28 10:11:27 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:27 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:28 -0500   IM: ---------- log start ----------
2014-10-28 10:11:28 -0500   IM: All install checks pass
2014-10-28 10:11:28 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:28 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:28 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:28 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:29 -0500   IM: All install checks pass
2014-10-28 10:11:29 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:29 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:29 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:29 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:29 -0500   IM: ---------- log start ----------
2014-10-28 10:11:43 -0500   IM: ---------- log start ----------
2014-10-28 10:11:43 -0500   IM: All install checks pass
2014-10-28 10:11:43 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:43 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:43 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:43 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:45 -0500   IM: ---------- log start ----------
2014-10-28 10:11:45 -0500   IM: All install checks pass
2014-10-28 10:11:45 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:45 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:45 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:45 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:46 -0500   IM: ---------- log start ----------
2014-10-28 10:11:46 -0500   IM: All install checks pass
2014-10-28 10:11:46 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:46 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:46 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:46 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:47 -0500   IM: ---------- log start ----------
2014-10-28 10:11:47 -0500   IM: All install checks pass
2014-10-28 10:11:47 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:47 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:47 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:47 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:48 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:48 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:48 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:48 -0500   IM: ---------- log start ----------
2014-10-28 10:11:48 -0500   IM: All install checks pass
2014-10-28 10:11:48 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:49 -0500   IM: ---------- log start ----------
2014-10-28 10:11:49 -0500   IM: All install checks pass
2014-10-28 10:11:49 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:49 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:49 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:49 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:50 -0500   IM: ---------- log start ----------
2014-10-28 10:11:50 -0500   IM: All install checks pass
2014-10-28 10:11:50 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:50 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:50 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:50 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:51 -0500   IM: ---------- log start ----------
2014-10-28 10:11:51 -0500   IM: All install checks pass
2014-10-28 10:11:51 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:51 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:51 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:51 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:52 -0500   IM: ---------- log start ----------
2014-10-28 10:11:52 -0500   IM: All install checks pass
2014-10-28 10:11:52 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:52 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:52 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:52 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:53 -0500   IM: ---------- log start ----------
2014-10-28 10:11:53 -0500   IM: All install checks pass
2014-10-28 10:11:53 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:53 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:53 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:53 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:54 -0500   IM: ---------- log start ----------
2014-10-28 10:11:54 -0500   IM: All install checks pass
2014-10-28 10:11:54 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:54 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:54 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:54 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:55 -0500   IM: ---------- log start ----------
2014-10-28 10:11:55 -0500   IM: All install checks pass
2014-10-28 10:11:55 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:55 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:55 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:55 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:56 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:56 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:56 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:56 -0500   IM: ---------- log start ----------
2014-10-28 10:11:56 -0500   IM: All install checks pass
2014-10-28 10:11:56 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:57 -0500   IM: ---------- log start ----------
2014-10-28 10:11:57 -0500   IM: All install checks pass
2014-10-28 10:11:57 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:57 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:57 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:57 -0500   IM: ----------  log end  ----------
2014-10-28 10:11:58 -0500   IM: ---------- log start ----------
2014-10-28 10:11:58 -0500   IM: All install checks pass
2014-10-28 10:11:58 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:11:58 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:11:58 -0500   IM: Install failed with error code: 17.
2014-10-28 10:11:58 -0500   IM: ----------  log end  ----------
2014-10-28 10:12:30 -0500   IM: ---------- log start ----------
2014-10-28 10:12:30 -0500   IM: All install checks pass
2014-10-28 10:12:30 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:12:30 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:12:30 -0500   IM: Install failed with error code: 17.
2014-10-28 10:12:30 -0500   IM: ----------  log end  ----------
2014-10-28 10:12:31 -0500   IM: ---------- log start ----------
2014-10-28 10:12:31 -0500   IM: All install checks pass
2014-10-28 10:12:31 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:12:31 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:12:31 -0500   IM: Install failed with error code: 17.
2014-10-28 10:12:31 -0500   IM: ----------  log end  ----------
2014-10-28 10:12:32 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:12:32 -0500   IM: Install failed with error code: 17.
2014-10-28 10:12:32 -0500   IM: ----------  log end  ----------
2014-10-28 10:12:32 -0500   IM: ---------- log start ----------
2014-10-28 10:12:32 -0500   IM: All install checks pass
2014-10-28 10:12:32 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:12:33 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:12:33 -0500   IM: Install failed with error code: 17.
2014-10-28 10:12:33 -0500   IM: ----------  log end  ----------
2014-10-28 10:12:33 -0500   IM: ---------- log start ----------
2014-10-28 10:12:33 -0500   IM: All install checks pass
2014-10-28 10:12:33 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:12:34 -0500   IM: ---------- log start ----------
2014-10-28 10:12:34 -0500   IM: All install checks pass
2014-10-28 10:12:34 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:12:34 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:12:34 -0500   IM: Install failed with error code: 17.
2014-10-28 10:12:34 -0500   IM: ----------  log end  ----------
2014-10-28 10:12:35 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:12:35 -0500   IM: Install failed with error code: 17.
2014-10-28 10:12:35 -0500   IM: ----------  log end  ----------
2014-10-28 10:12:35 -0500   IM: ---------- log start ----------
2014-10-28 10:12:35 -0500   IM: All install checks pass
2014-10-28 10:12:35 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:14:27 -0500   IM: ---------- log start ----------
2014-10-28 10:14:27 -0500   IM: All install checks pass
2014-10-28 10:14:37 -0500   IM: User has 1 process that needs to be closed before the Flash Player can be installed.
2014-10-28 10:14:45 -0500   IM: [install started]
2014-10-28 10:14:46 -0500   IM: [install completed]
2014-10-28 10:14:46 -0500   IM: [install failed]
2014-10-28 10:15:05 -0500   IM: ----------  log end  ----------
2014-10-28 10:15:14 -0500   IM: ---------- log start ----------
2014-10-28 10:15:14 -0500   IM: All install checks pass
2014-10-28 10:15:21 -0500   IM: User has 1 process that needs to be closed before the Flash Player can be installed.
2014-10-28 10:15:38 -0500   IM: [install started]
2014-10-28 10:15:38 -0500   IM: [install completed]
2014-10-28 10:15:38 -0500   IM: [install failed]
2014-10-28 10:15:40 -0500   IM: ----------  log end  ----------
2014-10-28 10:15:56 -0500   IM: ---------- log start ----------
2014-10-28 10:15:56 -0500   IM: All install checks pass
2014-10-28 10:16:04 -0500   IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2014-10-28 10:16:05 -0500   IM: [install started]
2014-10-28 10:16:05 -0500   IM: [install completed]
2014-10-28 10:16:05 -0500   IM: [install failed]
2014-10-28 10:18:24 -0500   IM: ----------  log end  ----------
2014-10-28 10:18:36 -0500   IM: ---------- log start ----------
2014-10-28 10:18:36 -0500   IM: All install checks pass
2014-10-28 10:18:42 -0500   IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2014-10-28 10:18:43 -0500   IM: [install started]
2014-10-28 10:18:43 -0500   IM: [install completed]
2014-10-28 10:18:43 -0500   IM: [install failed]
2014-10-28 10:18:51 -0500   IM: ----------  log end  ----------
2014-10-28 10:19:36 -0500   IM: ---------- log start ----------
2014-10-28 10:19:36 -0500   IM: All install checks pass
2014-10-28 10:19:36 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:19:36 -0500   IM: User does not have any processes that need to be closed.
2014-10-28 10:19:36 -0500   IM: [install started]
2014-10-28 10:19:37 -0500   IM: [install failed: 1]
2014-10-28 10:19:37 -0500   IM: Install failed with error code: 1.
2014-10-28 10:19:37 -0500   IM: ----------  log end  ----------
2014-10-28 10:22:44 -0500   IM: ---------- log start ----------
2014-10-28 10:22:53 -0500   IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2014-10-28 10:22:53 -0500   IM: Uninstall Started
2014-10-28 10:22:53 -0500   IM: [uninstall start]
2014-10-28 10:22:53 -0500   IM: user authorized
2014-10-28 10:22:53 -0500   IM: [file removal start]
2014-10-28 10:22:53 -0500   IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-10-28 10:22:54 -0500   IM: Removed file: '/Library/Internet Plug-Ins/Flash Player.plugin'
2014-10-28 10:22:54 -0500   IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-10-28 10:22:54 -0500   IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-10-28 10:22:54 -0500   IM: Removed file: '/Library/Internet Plug-Ins/flashplayer.xpt'
2014-10-28 10:22:54 -0500   IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-10-28 10:22:54 -0500   IM: Did not find file '/Users/Schremmer/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-10-28 10:22:54 -0500   IM: Did not find file '/Users/Schremmer/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2014-10-28 10:22:54 -0500   IM: Did not find file '/Users/Schremmer/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-10-28 10:22:54 -0500   IM: Did not find file '/Users/Schremmer/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-10-28 10:22:54 -0500   IM: Did not find file '/Users/Schremmer/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2014-10-28 10:22:54 -0500   IM: Did not find file '/Users/Schremmer/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-10-28 10:22:54 -0500   IM: Removed file: '/Library/LaunchDaemons/com.adobe.fpsaud.plist'
2014-10-28 10:22:54 -0500   IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-10-28 10:22:54 -0500   IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml'
2014-10-28 10:22:54 -0500   IM: Did not find bundle receipt to remove.
2014-10-28 10:23:00 -0500   IM: Removed file: '/Library/PreferencePanes/Flash Player.prefPane'
2014-10-28 10:23:00 -0500   IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2014-10-28 10:23:00 -0500   IM: [file removal end]
2014-10-28 10:23:00 -0500   IM: [uninstall end]
2014-10-28 10:23:01 -0500   IM: Uninstall Ended
2014-10-28 10:23:04 -0500   IM: ----------  log end  ----------
2014-10-28 10:23:14 -0500   IM: ---------- log start ----------
2014-10-28 10:23:14 -0500   IM: All install checks pass
2014-10-28 10:23:22 -0500   IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2014-10-28 10:23:22 -0500   IM: [install started]
2014-10-28 10:23:23 -0500   IM: [install completed]
2014-10-28 10:23:23 -0500   IM: [install failed]
2014-10-28 10:23:28 -0500   RA: Unable to execute privileged task '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-10-28 10:23:28 -0500   IM: ----------  log end  ----------
2014-10-28 10:24:21 -0500   IM: ---------- log start ----------
2014-10-28 10:24:21 -0500   IM: All install checks pass
2014-10-28 10:24:21 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:24:21 -0500   IM: User does not have any processes that need to be closed.
2014-10-28 10:24:21 -0500   IM: [install started]
2014-10-28 10:24:22 -0500   IM: [install failed: 1]
2014-10-28 10:24:22 -0500   IM: Install failed with error code: 1.
2014-10-28 10:24:22 -0500   IM: ----------  log end  ----------
2014-10-28 10:27:02 -0500   IM: ---------- log start ----------
2014-10-28 10:27:02 -0500   IM: All install checks pass
2014-10-28 10:27:10 -0500   IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2014-10-28 10:27:10 -0500   IM: [install started]
2014-10-28 10:27:11 -0500   IM: [install completed]
2014-10-28 10:27:11 -0500   IM: [install failed]
2014-10-28 10:31:19 -0500   RA: Unable to execute privileged task '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-10-28 10:31:19 -0500   IM: ----------  log end  ----------
2014-10-28 10:33:20 -0500   IM: ---------- log start ----------
2014-10-28 10:33:20 -0500   IM: All install checks pass
2014-10-28 10:33:20 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:33:20 -0500   IM: User has 1 process that needs to be closed.
2014-10-28 10:33:20 -0500   IM: Install failed with error code: 17.
2014-10-28 10:33:20 -0500   IM: ----------  log end  ----------
2014-10-28 10:33:28 -0500   IM: ---------- log start ----------
2014-10-28 10:33:28 -0500   IM: All install checks pass
2014-10-28 10:33:28 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:33:28 -0500   IM: User does not have any processes that need to be closed.
2014-10-28 10:33:28 -0500   IM: [install started]
2014-10-28 10:33:29 -0500   IM: [install failed: 1]
2014-10-28 10:33:29 -0500   IM: Install failed with error code: 1.
2014-10-28 10:33:29 -0500   IM: ----------  log end  ----------
2014-10-28 10:38:00 -0500   IM: ---------- log start ----------
2014-10-28 10:38:00 -0500   IM: All install checks pass
2014-10-28 10:38:00 -0500   IM: Unexpected umask value for process: 0
2014-10-28 10:38:00 -0500   IM: User does not have any processes that need to be closed.
2014-10-28 10:38:00 -0500   IM: [install started]
2014-10-28 10:38:01 -0500   IM: [install failed: 1]
2014-10-28 10:38:01 -0500   IM: Install failed with error code: 1.
2014-10-28 10:38:01 -0500   IM: ----------  log end  ----------
2014-10-28 13:13:37 -0500   IM: ---------- log start ----------
2014-10-28 13:13:37 -0500   IM: All install checks pass
2014-10-28 13:13:51 -0500   IM: User does not have any processes that need to be closed before the Flash Player can be installed.
2014-10-28 13:13:52 -0500   IM: [install started]
2014-10-28 13:13:52 -0500   IM: [install completed]
2014-10-28 13:13:52 -0500   IM: [install failed]
2014-10-28 13:13:58 -0500   RA: Unable to execute privileged task '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-10-28 13:13:58 -0500   IM: ----------  log end  ----------
2014-10-28 16:00:45 -0500   IM: ---------- log start ----------
2014-10-28 16:00:45 -0500   IM: All install checks pass
2014-10-28 16:00:45 -0500   IM: Unexpected umask value for process: 0
2014-10-28 16:00:45 -0500   IM: User does not have any processes that need to be closed.
2014-10-28 16:00:45 -0500   IM: [install started]
2014-10-28 16:00:46 -0500   IM: [install failed: 1]
2014-10-28 16:00:46 -0500   IM: Install failed with error code: 1.
2014-10-28 16:00:46 -0500   IM: ----------  log end  ----------
I'm also seeing install failure on 10.10. fails at the 75% mark on the progress bar… MBP 2011, newest OS / safari / ect.
Nov 03, 2014 Nov 03, 2014
Still unable to download flash do we know why?
Dec 17, 2014 Dec 17, 2014
I, too, have experience this problem. Have also tried all the fixes mentioned (see codyrjohnson's answer).
Dear Maria,
as far as I can see the topic has not yet been solved by Adobe.
Since more than one months many people cannot see flash content due to this problem.
Do you have information about a plan when Adobe will solve it?
Guest
I had this problem and tried all the suggested clean installs.  But then the light came on and I realized that I never run my computer at the admin or root level.  Flash is not loaded in the browser for the current user.  You need to be signed into an Admin account to load flash.  I wish Flash would give a useful message when it fails.  All it would do is get to about 90% and then fail.  I hope this helps.  I am running Safari on a Mac with system 10.10.1
I think Adobe needs to take a serious look at their tech support. A  forum is neither timely nor the best option of solving issues.
I am quite happy I am not the only one having a problem with this... I have exactly the same problem, tried all alternatives, cleaned all directories, uninstall the previous versions etc. Infact I can't use flash anymore at the moment, there is no poss to even instal the previous version.
mbp 13''late 2011 / OSX 10.10
Guest
I'm having the exact same issue on 10.9.4.
Having the same problem. I've read about different fixes but couldn't figure them out; I'm not a pro at Terminal. Tried downloading the installer suggested in a previous reply to this and still got the installation error. Adobe, help!
Has there been any resolution with this issue?  I am experiencing the same problem.  Mac OS 10.10.1, I keep getting notices that my flash player is out of date.  When I go through the installation process it gets to ~40% of the download then won't progress any farther.
Mar 19, 2015 Mar 19, 2015
I have a OS X YOSEMITE Version 10.10.2 and having same issue no one has given me a solution... Any further instruction on how to get these issues resolved?
Adobe Employee ,
Mar 20, 2015 Mar 20, 2015
Hi perlam72202013,
Please don't post the same thing to multiple threads. Posting to multiple threads won't help you get your issue resolved sooner.  You have a thread at Im unable to install flash player? that has been locked because it's a duplicate of I am unable to install Adoble flash? which is were people are helping you at.  Please stick to that thread so that reponses to your issue stay in one location which may help other users in the future.
Maria
Mar 30, 2015 Mar 30, 2015
I am having the same issue. It is ridiculous. It has proved impossible to install Flash on my MacBook Air running Yosemite 10.10.2, and this after multiple tried, uninstalls--all the trouble shooting suggestions. Is anything being done?
