When i run the adobe flash player download/install app it won't get further than 30%! Then it says; "Connection lost.. Trying to reconnect.." so i can't install it on my MacBook and i really need it! Can anybody help me please?
Alternate download link http://fpdownload.macromedia.com/pub/flashplayer/current/support/install_flash_player_osx.dmg
Mine is doing the exact same thing! Does anybody know what could be causing this?
Mine says "plug-in blocked". I have now lost YouTube. I thought I was just installing a newer version. Now I do not have anything on my older MacBook (MacOS 10.6.8). Is there anyway I can get rid of what I tried to install (maybe Flash Player 15.0.0) & just go back to what I had? I've gone through all the helpful steps,but to no avail. Thank you!!
I got it to work! Thanks for the great discussions.
Mine is doing the same thing too! it made me try to update flash after I updated to Yosemite.
Same here on a MacBook Air running OS X 10.10! I changed the security setting in System Prefs, also adjusted security settings in safari but no luck. Attempted to download the full installer following the "in case of emergency" aka "Still having problems?" but no luck as multiple browsers say they can't connect to the server
ADOBE please lift your game and resolve this.!!!!!!!
Thank you so much Pat! The alternate download link worked a treat. Downloaded and installed smoothly. I am one happy camper!
Thank you so so so so so much Pat! The alternate download worked for me!
Ok... so I tried this and it still hangs up at 95% complete.... help... I am running 10.9.5
This still doesn't work for me. I have tried everything. The Apple support person said that maybe there are some Adobe files I need to delete? I have done an uninstall and can't think of anything else. Any ideas?
Then try this: http://helpx.adobe.com/flash-player/kb/uninstall-flash-player-mac-os.html
If that does not help, please provide your install log files: https://forums.adobe.com/thread/985831
did the uninstall and here are the logs.
There are a bunch (since I have tried so much) with this:
2014-10-04 17:04:05 -0500
Some say:
2014-10-24 16:16:22 -0500 IM: ---------- log start ----------
2014-10-24 16:16:22 -0500 IM: All install checks pass
2014-10-24 16:16:25 -0500 IM: User does not have any processes that need to be closed.
2014-10-24 16:16:25 -0500 IM: [install started]
2014-10-24 16:31:16 -0500 IM: ---------- log start ----------
2014-10-24 16:31:16 -0500 IM: All install checks pass
2014-10-24 16:31:18 -0500 IM: User does not have any processes that need to be closed.
Some say: (but may be safari I needed to close)...
2014-10-25 07:25:56 -0500 IM: ---------- log start ----------
2014-10-25 07:25:56 -0500 IM: All install checks pass
2014-10-25 07:25:59 -0500
2014-10-25 07:25:59 -0500 IM: ---------- log end ----------
This is from the uninstall;
2014-10-28 07:32:22 -0500 IM: ---------- log start ----------
2014-10-28 07:32:28 -0500 IM: User does not have any processes that need to be closed before the Flash Player can be uninstalled.
2014-10-28 07:32:28 -0500 IM: Uninstall Started
2014-10-28 07:32:28 -0500 IM: [uninstall start]
2014-10-28 07:32:28 -0500 IM: user authorized
2014-10-28 07:32:28 -0500 IM: [file removal start]
2014-10-28 07:32:28 -0500 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-10-28 07:32:28 -0500 IM: Removed file: '/Library/Internet Plug-Ins/Flash Player.plugin'
2014-10-28 07:32:28 -0500 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-10-28 07:32:28 -0500 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-10-28 07:32:29 -0500 IM: Removed file: '/Library/Internet Plug-Ins/flashplayer.xpt'
2014-10-28 07:32:29 -0500 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-10-28 07:32:29 -0500 IM: Did not find file '/Users/jacqmill/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-10-28 07:32:29 -0500 IM: Did not find file '/Users/jacqmill/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2014-10-28 07:32:29 -0500 IM: Did not find file '/Users/jacqmill/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-10-28 07:32:29 -0500 IM: Did not find file '/Users/jacqmill/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-10-28 07:32:29 -0500 IM: Did not find file '/Users/jacqmill/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2014-10-28 07:32:29 -0500 IM: Did not find file '/Users/jacqmill/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-10-28 07:32:29 -0500 IM: Removed file: '/Library/LaunchDaemons/com.adobe.fpsaud.plist'
2014-10-28 07:32:29 -0500 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud' to remove.
2014-10-28 07:32:29 -0500 IM: Did not find file '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml' to remove.
2014-10-28 07:32:29 -0500 IM: Did not find bundle receipt to remove.
2014-10-28 07:32:30 -0500 IM: Removed file: '/Library/PreferencePanes/Flash Player.prefPane'
2014-10-28 07:32:30 -0500 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2014-10-28 07:32:30 -0500 IM: [file removal end]
2014-10-28 07:32:30 -0500 IM: [uninstall end]
Do you see anything that I may need to do? Thanks in advance!!
Try using the offline installer http://download.macromedia.com/pub/flashplayer/current/support/install_flash_player_osx.dmg
thanks.
I got running now
