1. Re: Ignore Warnings in ES3
Varun_Nohria Sep 24, 2014 4:03 PM (in response to teknix2)Below are the properties which you can modify to get rid of WBP-105 abd WBP-104
-Dcom.adobe.workbench.process.validation.warn.numactions=50
-Dcom.adobe.workbench.process.validation.warn.numvars=20
Hope this helps
-Varun
2. Re: Ignore Warnings in ES3
teknix2 Sep 25, 2014 7:29 AM (in response to Varun_Nohria)Hi Varun,
Thanks for the suggestions, they were not part of my post but I had already tried these too. Also, I managed to contact people at Adobe through another channel and they confirmed that there is a problem. If you ask me, I think the whole ini file isn't being loaded up.
Nic
3. Re: Ignore Warnings in ES3
TundraSteve Oct 28, 2014 4:50 AM (in response to teknix2)The ini file is being loaded, if you make the changes to the ini file and restart workbench you can right click on a process and select validate and items such as numvars will be honored.
4. Re: Ignore Warnings in ES3
teknix2 Oct 29, 2014 4:53 AM (in response to TundraSteve)Well something else is not right then because I have the following lines set in my workbench.ini:
-Dcom.adobe.workbench.process.validation.warn.numactions=100
-Dcom.adobe.workbench.process.validation.warn.numvars=100
And I am still getting:
[WBP-104] Count of declared variables 32 exceeds recommendation.[WBP-105] Count of declared activities 67 exceeds recommendation.
Doing validate on my process does not help. I always see the same thing in the validation report.
I am modifying the workbench.ini in this folder "C:\Program Files (x86)\Adobe LiveCycle Workbench ES3\workbench". Is this right?
