OS 10.10, MBP 2011 i7, latest updates. I ran the installer by opening up the app package and invoking the install via terminal. at the 75% mark ( download finishes ) the installer fails. in the terminal I got this maybe helpful error message. any idea on getting flash to install ? its worse because I've run the uninstaller so parts of various websites don't work now
S
ok, its a permissions error because the installer isn't at the right run level, even asking for my admin password. if I do
sudo Install Adobe Flash Player.app
[enter password]
Installer now runs. it generates a bunch of error messages in the terminal
Install Adobe Flash Player[744:19476] Error loading /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder: dlopen(/Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder, 262): Library not loaded: /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
Referenced from: /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder
Reason: image not found
——— does this about 10 times ending like this -------
2014-10-28 22:03:10.831 Install Adobe Flash Player[744:19476] Error loading /Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder: dlopen(/Library/QuickTime/DivX Decoder.component/Contents/MacOS/DivX Decoder, 262): Library not loaded: /Library/Frameworks/DivX Toolkit.framework/Versions/A/DivX Toolkit
2014-10-28 22:03:47.190 Adobe Flash Player Install Manager[764:19989] Install failed with error code: 17.
the install actually finishes though and flash is working… YAH ! but only a semi uber geek would ever figure this out or think to try it. please fix the installer as its got a problem under 10.10
Hi Steven,
What installer are you using to install via terminal? Is this the shim installer downloaded from get.adobe.com/flashplayer, or the offline/standalone installer (e.g. downloaded from Installation problems | Flash Player | Mac)? In either case, the OS requires the admin password to install Flash Player. However, I'm interested to find out which installer is returning the output you're seeing. Also, what's the command-line argument you're using to install from terminal?
Maria
Hi Maria,
I downloaded from the automatic update link. it started the 3 step process. it appears to be the installer which downloads the actual flash components from the web. the file name is AdobeFlashPlayerInstaller_15_ltrosxd_amc_aih.dmg 1.2mb but I also got AdobeFlashPlayerInstaller_15_ltrosxd_aaa_aih.dmg the first time I downloaded it. just a random hash at the end ? either way my regular normal account is an admin account, other installers aka VISE work fine, other admin tasks work with my account.
I opened the installer package, navigated to contents/macos/install adobe flash player and ran it via SUDO.
sudo /Volumes/Adobe\ Flash\ Player\ Installer/Install\ Adobe\ Flash\ Player.app/Contents/MacOS/Install\ Adobe\ Flash\ Player
[password]
error msgs about divx
completes error code 17
S
