1. Re: [newbie] direct connection to a database?
WASIL Oct 29, 2014 11:39 PM (in response to visert)The PDF form could also be submitted inside Adobe Reader/Reader plugin inside browser, over a REST HTTP endpoint, pointing to a LiveCycle process, which could process this form.
Wasil
2. Re: [newbie] direct connection to a database?
visert Oct 30, 2014 2:36 PM (in response to WASIL)Hi Wasil
Thank for your suggestion. But what do youmean exactly for "could"?
Do you mean "already proved or do you mean a possibility?
Are there demo that show this king of deployment?
Thank you in advance.
Regards
visert
3. Re: [newbie] direct connection to a database?
WASIL Oct 30, 2014 6:08 PM (in response to visert)I used "could" in the context of designer. This type of process/workflow can be designed and have been designed.I've seen multiple such PDF forms which are submitted inside Reader/Browser e.g. https://wsr.pearsonvue.com/vouchers/asiapac_form.pdf
Such forms are submitted over REST endpoint, data either sent as XML or PDF and processed on the server.
Wasil
4. Re: [newbie] direct connection to a database?
visert Nov 1, 2014 3:08 PM (in response to visert)Hi Wasil
I saw your link and it's interesting.
Do you think that is possibile also manage/insert:
- flowable text field
- image fields
- pre-fill data (my user fill form in many days of work...so they need to re-open a form and find data inserted past days).
- high quality DPI final PDF (to print on paper).
- and finally. .. generally more "beauty" form? :-)
thank you a lot.
v
5. Re: [newbie] direct connection to a database?
WASIL Nov 1, 2014 8:41 PM (in response to visert)Yes, I believe it is.
Wasil
