Show 2 replies
1. Re: Slide duration
Captiv8r Oct 30, 2014 10:30 AM (in response to akaskens)Hi there
What objects are on the slide? Normally when you are unable to adjust slide duration it is because you have an object on the slide that is timed such that you cannot make the slide shorter.
Bottom line here is to check duration of objects on the slide.
Cheers... Rick
2. Re: Slide duration
akaskens Oct 31, 2014 8:01 AM (in response to Captiv8r)Thank you Rick - I was able to fix it, thanks to your answer!
