Show 2 replies
1. Re: Please assist with image style question....
Captiv8r Oct 30, 2014 2:56 PM (in response to kdeuler)HI Kurt
I could be wrong here, but what you shared shows the image "smooshed against" the LEFT side not the right.
I'm wondering if the issue here is your naming of the style. I note there seems to be a period in it. You might try again and ensure the style name doesn't contain a period. I'm thinking that may be confusing things.
Cheers... Rick
2. Re: Please assist with image style question....
kdeuler Oct 30, 2014 3:02 PM (in response to Captiv8r)Rick-
- Yes, thank you. I meant "left" side.
- You were spot-on! The period was indeed the problem. Of course, I re-discovered an issue I found long ago: When the user Renames a style, the style is removed from all entities that it was formerly applied to, without warning (and, I believe, without undo). Luckily, I was only doing a test.
Thanks again!
-Kurt
