4 Replies Latest reply: Oct 31, 2014 6:42 AM by QuadrantProductions RSS
    Concatenate a loaded JSON URL
    QuadrantProductions Community Member
      If you have a JSON file that's being loaded (no problems there), and one of the JSON variables is named "thelink"  with a value of "http://www.somewebsite.com"
      How would you concatenate that in Animate.  Although the following syntax gave me back no error, it didn't work on a click.
      $.getJSON(myjson, function(data){
                  sym.getSymbol("taboption2").click(function(){
              window.open((data[0].thelink), "_parent");})
        • 1. Re: Concatenate a loaded JSON URL
          My syntax appears to be off, but I cant tell where?
          window.open("('"+data[0].thelink+"')", "_parent")});
          The URL is in a JSON file that's being loaded as the JSON variable thelink
          Heres the full block.
                  var s1 = sym.getSymbol("taboption1");
                  s1.getSymbol("holder").$("placehere").css({"background-image":"url('"+data[0].image+"')"} );
                  s1.$("thename").html(data[0].thename);
                  //start mouse events//
                sym.getSymbol("taboption1").click(function(){
          • 2. Re: Concatenate a loaded JSON URL
            vivekuma Adobe Employee
            I assume you have included the jQuery already.
            Syntax for window.open is wrong, it should be like this:
               window.open("'"+data[0].thelink+"''", "_parent");
            and while adding click event, you should do like like:
                 sym.getSymbol("taboption1").getSymbolElement().click(function(){
            hth,
            Vivekuma
            • 3. Re: Concatenate a loaded JSON URL
              resdesign CommunityMVP
              I think for the click event you might want to use:
                sym.getSymbol("taboption1").getSymbolElement().bind("click",function() {
              • 4. Re: Concatenate a loaded JSON URL
                Thanks vivekuma,
                Close! There were a couple of extra ' in your string.  Also the correction on the click event didn't work.  The click on the entire symbol as per my original block of code did.  Just the sym.getSymbol("taboption1").click(function(){
                The final syntax that worked at getting the data object from the JSON was as follows.  The only difference was I removed the ''s inside the " that were in your text.
                window.open(""+data[0].thelink+"", "_parent");
                Thanks so much for your help!  Much appreciated.
