2 Replies Latest reply: Nov 3, 2014 5:19 AM by Wickedhand RSS
    Javascript written in Dreamweaver behaves different when inserted in Muse
    Wickedhand Community Member
      I have a simple javascript list that is written in Dreamweaver and works as expected but when I copy & paste that exact javascript into the -Object-insert html section in Muse the outcome is different.
      Is there a place I can go to research on what I need to do different for that code to behave properly in Muse? I am not understanding what I need to change or do different.
      Below is the code I got to work in Dreamweaver:
      <!doctype html>
      <html>
      <head>
      <meta charset="utf-8">
      <title>list</title>
      <script type="text/javascript">
      function fixTheList(){
      var msg = "";
      var msg = "";
      if (document.getElementById("appleQty").value > 0) {
      msg += "Apples   ";
      msg +=document.getElementById("appleQty").value;
      msg += "<br>";
      if (document.getElementById("orangesQty").value > 0) {
      msg += "Oranges   ";
      msg +=document.getElementById("orangesQty").value;
      msg += "<br>";
      if (document.getElementById("tangerineQty").value > 0) {
      msg += "Tangerines   ";
      msg +=document.getElementById("tangerineQty").value;
      msg += "<br>";
      if (document.getElementById("kiwiQty").value > 0) {
      msg += "Kiwis   ";
      msg +=document.getElementById("kiwiQty").value;
      msg += "<br>";
      if (document.getElementById("pearsQty").value > 0) {
      msg += "Pears   ";
      msg +=document.getElementById("pearsQty").value;
      msg += "<br>";
      if (document.getElementById("grapesQty").value > 0) {
      msg += "Grapes   ";
      msg +=document.getElementById("grapesQty").value;
      msg += "<br>";
      if (document.getElementById("canteloupeQty").value>0) {
      msg += "Canteloupes   ";
      msg+=document.getElementById("canteloupeQty").value;
      msg += "<br>";
      if (document.getElementById("strawberryQty").value>0) {
      msg += "Strawberry   ";
      msg+=document.getElementById("strawberryQty").value;
      msg += "<br>";
      document.getElementById("outputDiv").innerHTML = msg;
      </script>
      </head>
      <body>
      <div id="outputDiv">
      <table>
        <tr>
        <td>Item</td>
        <td>Quantity</td>
        </tr>
        <tr>
        <td>Apples</td>
        <td><input type="text" size="3" id="appleQty"></td>
        </tr>
        <tr>
        <td>Oranges</td>
        <td><input type="text" size="3" id="orangesQty"></td>
        </tr>
        <tr>
        <td>Tangerines</td>
        <td><input type="text" size="3" id="tangerineQty"></td>
        </tr>
        <tr>
        <td>Kiwi</td>
        <td><input type="text" size="3" id="kiwiQty"></td>
        </tr>
        <tr>
        <td>Pears</td>
        <td><input type="text" size="3" id="pearsQty"></td>
        </tr>
        <tr>
        <td>Grapes</td>
        <td><input type="text" size="3" id="grapesQty"></td>
        </tr>
        <tr>
        <td>Cantaloupe</td>
        <td>
        <input type="text" size="3" id="canteloupeQty">
        </td>
        </tr>
        <tr>
        <td>Strawberry</td>
        <td><input type="text" size="3" id="strawberryQty">
        </td>
        </tr>
        </table>
        <input type="button" value="Stack" onclick="fixTheList();">
      </div>
      </body>
      </html>
        • 1. Re: Javascript written in Dreamweaver behaves different when inserted in Muse
          VivekPassan Adobe Employee
          Hello,
          Only difference I see is with the CSS properties of Input tag.
          You can define the style for these tag by adding few lines of code right below <title> tag in the code you are pasting in Object > Insert HTML.
          For an example you can add codes mentioned below
          <style type="text/css">
            input {
              border: thin solid #AAA2A3;
              margin-bottom: 7px;
              margin-left: 9px;
            </style>
          As per your requirement you can edit them.
          One more advice. Break your codes in to 3 part, Scripts tag, Style tag and Div tag in body.
          Insert Div tag in body in Object > Insert HTML
          Insert Scripts tag, Style tag in Page > Page Properties >Metadata > HTML for <head>
          This will help you avoid any unexpected behavior in preview when you have more stuff inserted in Muse Page.
          1. Script tag (Insert it in Page > Page Properties >Metadata > HTML for <head>)
          var msg = "";
          var msg = "";
          msg += "Apples   ";
          msg += "<br>";
          msg += "Oranges   ";
          msg += "<br>";
          msg += "<br>";
          msg += "Kiwis   ";
          msg += "<br>";
          msg += "Pears   ";
          msg += "<br>";
          msg += "Grapes   ";
          msg += "<br>";
          msg += "<br>";
          msg += "<br>";
          </script>
          2. Style Tag (Insert it in Page > Page Properties >Metadata > HTML for <head>)
            input {
              margin-bottom: 7px;
              margin-left: 9px;
            </style>
          3. Div tag in body (Insert in Object > Insert HTML)
          <table>
            <tr>
            <td>Item</td>
            <td>Quantity</td>
            </tr>
            <tr>
            <td>Apples</td>
            </tr>
            <tr>
            <td>Oranges</td>
            </tr>
            <tr>
            <td>Tangerines</td>
            </tr>
            <tr>
            <td>Kiwi</td>
            </tr>
            <tr>
            <td>Pears</td>
            </tr>
            <tr>
            <td>Grapes</td>
            </tr>
            <tr>
            <td>Cantaloupe</td>
            <td>
            </td>
            </tr>
            <tr>
            <td>Strawberry</td>
            </td>
            </tr>
            </table>
          </div>
          Regards
          Vivek
