1. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
_durin_ Oct 8, 2014 9:10 AM (in response to Edcotty)I haven't yet seen any reports specifically like you describe, but let's see what we can find out. Probably the simplest method to troubleshoot this would be to provide a crash dump file to our development team. If you are able to follow these steps the next time Audition crashes or when you have a few minutes, it would be very helpful.
1. When Audition crashes, immediately launch Windows Task Manager. You can do this easily by pressing SHIFTCTRLESC simultaneously.
2. Click the "More Details" toggle, if needed, then right-click on the Adobe Audition CC process and select "Create Dump File"
3. When this is complete, it should provide a path to the saved dump file, for example, C:\Users\labuser\AppData\Local\Temp\PDapp.DMP Please locate this file and share it to audbugs@adobe.com via Dropbox or a similar service. (If you do not have a service available, please let me know and I'll see if I can send a link that will enable you to share it easily.)
I'll forward the file to an engineer and they should be better able to debug the application state and see what caused the crash to occur.
Thank you.
2. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
Edcotty Oct 8, 2014 9:53 AM (in response to _durin_)Cool will do thanks
3. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
billysurfmartin Oct 9, 2014 1:52 PM (in response to Edcotty)Same issue! Just installed new CC version and it crashes when I highlight (or try to edit). I sent dump file to audbugs@adobe.com
4. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
_durin_ Oct 9, 2014 2:17 PM (in response to billysurfmartin)Thanks for the crash file, Billy. I'm downloading it now and will add it to the bug report. Can you let me know which version of Windows you're running, and what video card and driver version you have installed?
Thanks.
5. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
billysurfmartin Oct 9, 2014 3:23 PM (in response to _durin_)Thanks for the quick reply. Windows 7 Service pack 1 64 bit. GeForce GTX 660 Ti. Driver version 340.52
6. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
philwell Oct 10, 2014 6:18 AM (in response to _durin_)It's happening to me. I'm a VO artist and I make my living off this program. What happened? I'll get the dump file ASAP. I'm using OSX v10.9.5 (Mavericks) and haven't had any trouble at all prior to this release.
Not only is it crashing on me when I move the playhead or copy/paste... it's also cutting off the last 10 or so seconds of my recording if Audition isn't the active window and I switch back to stop the recording after I've completed my script.
7. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
_durin_ Oct 10, 2014 8:15 AM (in response to philwell)Hi Phil,
Yours is the first report of this behavior on OS X. There is a very comprehensive crash report that OS X generates that would be very helpful.
When the application crashes, please launch /Applications/Utilities/Console.app and then open the "User Diagnostic Reports" item. You can drag the most recent Audition crash report listed there as an email attachment and send it to audbugs@adobe.com I'll make sure it is shared with the developers and added to the bug report. (It may also give us some more immediate guidance on what's happening.)
Thanks.
8. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
Scott.Couchman Oct 13, 2014 11:06 AM (in response to Edcotty)I'm having a similar issue. When I am highlighting audio and move the mouse left or right to the point where it SHOULD be scrolling, Audition will crash instead. I have uninstalled and reinstalled it and no change.
Running
Audition 2014.1, Build 7.1.0.119
WIndows 7 Pro, SP1, 64-bit
Dell Latitude E6530:
CPU: i7, 2.70GHz
RAM: 16GB
Free Disk Space: 118GB
Video Card: Intel(R) HD Graphics 4000
I've created a DMP file and sent this all to audbugs@adobe.com just now
9. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
billysurfmartin Oct 22, 2014 9:03 AM (in response to Edcotty)Is there an update coming?
10. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
_durin_ Oct 24, 2014 12:34 PM (in response to billysurfmartin)Okay, I think we've found the reproduction steps now. Looks like it's related to High DPI Scaling. Is anyone who sees this problem running Windows at 100% icon/text scaling?
11. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
billysurfmartin Oct 24, 2014 1:00 PM (in response to _durin_)I am on Windows using Medium (125%) scaling, but will test at 100 and 150.
12. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
billysurfmartin Oct 24, 2014 1:07 PM (in response to billysurfmartin)Ok - on 150 it still crashes, but at 100%, it's fine so far... I logged off and back on after each change. I start using this new update (was using older version) and let you know if I have any problems.
13. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
_durin_ Oct 24, 2014 1:34 PM (in response to billysurfmartin)Thanks. That helps with the confirmation. I'll share it with the engineers.
14. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
Scott.Couchman Oct 27, 2014 9:36 AM (in response to _durin_)On mine, it is working on both 150% and 100%. Only at 125% is when it will crash.
15. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
HERHIL@MAIL.RU Oct 30, 2014 2:55 AM (in response to _durin_)You are absolutely right. I had the same problem, when the scale was 125%, but after reduction to 100%, the problem disappeared.
16. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
billysurfmartin Oct 30, 2014 5:52 AM (in response to HERHIL@MAIL.RU)Yes - I have been using for days now at 100% with zero crashes.
17. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
Paul Moon Oct 31, 2014 9:45 PM (in response to Edcotty)This is completely insane. I'm not going to change my entire Windows environment to accommodate this bug that never existed before the recent update to Audition. What's the time frame? I'm paying for my Creative Cloud subscription that is broken by this severe bug.
18. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
HERHIL@MAIL.RU Nov 2, 2014 6:26 AM (in response to Paul Moon)I am confident that this minor error will be quickly corrected. Mistakes happen at all , but I think you should not do out of molehills .
19. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
Edcotty Nov 6, 2014 3:39 AM (in response to Edcotty)Okay, I think we've found the reproduction steps now. Looks like it's related to High DPI Scaling. Is anyone who sees this problem running Windows at 100% icon/text scaling?
Seems til an update this will stop it from crashing! Thank you all for the input!
I am going to mark this as correct answer just for ease of access and in case some people don't scroll down -
20. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
_durin_ Nov 6, 2014 8:16 AM (in response to Edcotty)Thanks for marking the answer - it's useful for other users and prioritizes those posts over others for support and search purposes. I hope to have information on an update patch to fix this issue soon.
21. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
jwarren891 Nov 10, 2014 8:25 AM (in response to _durin_)I see the problem at 100% scaling in the Waveform editor. It reliably crashes at the instant that the waveform display should begin scrolling during playback. I opened a report on this a while back but have no resolution. It's crashing in the Microsoft runtime library - MSVCR110.dll. System is Win 7 Pro SP1 with an Nvidia GTX560 display card.
When I submitted the report before, Support said not to provide a dump - that they already thought they had enough.
22. Re: Issue with Audition CC build 7.1.0.119 crashing on moving the play head back
_durin_ Nov 10, 2014 10:37 AM (in response to jwarren891)The cause of this issue has been identified, and the code is being corrected to prevent the crash. Once that's done, the fix needs to be tested and validated along with other bug fixes before an update patch can be released. Unfortunately, I cannot provide specific dates at this time.
