1. Re: Black window is open in background every time I open a new file
JJMack Nov 3, 2014 5:30 AM (in response to SamNAP)I do not use a Mac but I do use floating windows on a PC. I also know that there is some way to turn off Photoshop's main windows frame on a Mac. That frame may be what you see as the black window. Try turning off Photoshop's frame.
To have Photoshop Open new and existing documents from Photoshop's are 100% you need to set up a open event and have ir use an Action or Script the will set view actual pixels 100% zoom. Look a menu File>scripts>Script Events Manager.... that is where you enable events and set up their handlers.
2. Re: Black window is open in background every time I open a new file
SamNAP Nov 3, 2014 5:31 AM (in response to JJMack)Thanks for That JJMack, would you be able to be a little more specific in both instances?
For the scripts, I can see "Open Document" but I cant see set at 100% zoom option.
3. Re: Black window is open in background every time I open a new file
JJMack Nov 3, 2014 6:27 AM (in response to SamNAP) -
4. Re: Black window is open in background every time I open a new file
SamNAP Nov 10, 2014 3:08 AM (in response to JJMack)Thanks for that JJMack.
I am able to replicate the dropdown selection in your screenshot, but and not able to do anything else after that.
5. Re: Black window is open in background every time I open a new file
R_Kelly Nov 10, 2014 3:30 PM (in response to SamNAP)You can turn off the Application Frame by going Window>Application Frame in photoshop cs6
Also, are you using dual monitors?
