My question, using coldfusion 11 enterprise datasource gui,
how do you connect to oracle 12c multitenant database,
when you need to log into a pluggable database, beneath
the container database?
What's the connection string, or is it even possible to connect(?) because earlier versions of oracle
didn't use multitenant architecture, you just make a user/password,
grant connect privileges, and connect.
Using Oracle Linux 6.5 64bit.
This is assuming I can connect to the oracle CDB (container database) and PDB (pluggable database) from the shell using sqlplus.
<!------------------------ I can tsnping the pluggable database name pdb1 ---------------------------------------------->
[oracle@localhost ~]$ tnsping pdb1
TNS Ping Utility for Linux: Version 12.1.0.1.0 - Production on 27-JUN-2014 12:13:12
Copyright (c) 1997, 2013, Oracle. All rights reserved.
Used parameter files:
/u01/app/oracle/product/12.1.0/dbhome_1/network/admin/sqlnet.ora
Used TNSNAMES adapter to resolve the alias
Attempting to contact (DESCRIPTION = (ADDRESS = (PROTOCOL = TCP)(HOST = localhost.localdomain)(PORT = 1521)) (CONNECT_DATA = (SERVER = DEDICATED) (SERVICE_NAME = pdb1.localhost.localdomain)))
OK (0 msec)
<!------------------------------ I can connect to pdb1 using sqlplus shell ---------------------------------------------------->
[oracle@localhost ~]$ sqlplus user1/password20@pdb1
SQL*Plus: Release 12.1.0.1.0 Production on Fri Jun 27 12:21:06 2014
Copyright (c) 1982, 2013, Oracle. All rights reserved.
Last Successful login time: Fri Jun 27 2014 09:45:05 -07:00
Connected to:
Oracle Database 12c Enterprise Edition Release 12.1.0.1.0 - 64bit Production
With the Partitioning, OLAP, Advanced Analytics and Real Application Testing options
SQL>
Having the same issue, can't get the connection string right with the PDB?
Anyone out there? Kurrttt, did you ever get this figured out?
