Is there a way to insert a hidden field using cfform, cfgrid, and cfgridupdate?
It is unclear to me what you mean. Insert into into what? You could just declare the type of an input field in a form to be 'hidden'.
I don't think using a hidden field will work with cfgrid and cfgridupdate. It's not working for me, but maybe I'm missing something.
Again, what do you mean? What is the context?
You could just use a hidden form field next to the cfgrid, like this
<cfform>
<cfgrid>
</cfgrid>
<cfinput type="hidden">
</cfform>
I did exactly what you show, and it doesn't insert the hidden field when using Insert a Row.
<!---Save Grid --->
<cfif IsDefined("form.factsEntered") is True>
<cfgridupdate grid="FactsGrid" Keyonly="true"
datasource="#application.dsn#"
tablename="pmspProductionFacts" >
<!---Output Grid---> |
<cfform> |
<cfgrid name = "PrioritiesGrid" |
query = "priorities" |
width="100%"
insert = "yes" | ||
delete = "yes" | ||
rowHeaders = "No" |
rowHeight="25"
colHeaderBold = "Yes" | ||
selectMode = "EDIT" | ||
insertButton = "Insert a Row" deleteButton = "Delete selected row" sort="yes" > |
<cfgridcolumn name="pmsppriorityid" display="false">
<cfgridcolumn name="pesttypeid" header="Pest Type" display="yes" width="100" valuesdisplay="#variables.pesttypes#" values="#variables.pesttypesid#" valuesdelimiter=",">
<cfgridcolumn name="prioritytypeid" header="Priority Type" display="yes" valuesdisplay="#variables.prioritytypes#" values="#variables.prioritytypesid#" valuesdelimiter="," width="100">
<cfgridcolumn name="cropstageid" header="Stage" display="yes" width="300" valuesdisplay="#variables.cropstages#" values="#variables.cropstageids#" valuesdelimiter=",">
<cfgridcolumn name="prioritynumber" header="Priority Number" display="yes" width="100">
<cfgridcolumn name="criticalneed" header="Critical Need" display="yes" valuesdisplay="True,False" values="true,false" valuesdelimiter=",">
<cfgridcolumn name="priority" header="Priority" display="yes" width="1500">
</cfgrid><br />
<cfinput type="hidden" name="pmspid" value="#url.pmspid#">
<div align="center"><cfinput type="submit" name="prioritiesEntered" value="Save Priorities"></div> | ||
</cfform> |
