quote:
<!--- establish default values --->
<cfparam name="output" default="">
<cfparam name="catNameOutput" default="">
<cfparam name="indent" default="">
<cffunction name="GenerateCategories" access="public" returntype="string">
<!--- this holds the outermost parent value being passed to the function --->
<cfargument name="GenCatParent" type="uuid" required="yes" default=0 >
<!--- this holds the nested level we are on --->
<cfargument name="level" type="numeric" required="yes" default=0 >
<!--- this holds the output_type we need for display purposes --->
<cfargument name="output_type" type="numeric" required="yes" default=0 >
<!--- grab the children of the received category --->
<cfquery name="rsCategoryChildren" datasource="webdsn">
SELECT * FROM dbo.BlogCategories
WHERE catParent = '#GenCatParent#'
ORDER BY catName ASC
</cfquery>
<cfloop query="rsCategoryChildren">
<!--- keep track of the indentation needed depending on which level we are at --->
<cfloop from="0" to="#arguments.level#" index="i">
<cfset indent = indent & " ">
</cfloop>
<!--- if the nest is being used in the dropdown on the category manage page, we need to use option tags --->
<cfif arguments.output_type EQ 1>
<cfset catNameOutput = "<option value='" & catPK & "'>" & indent & Trim(catName) & "</option>">
</cfif>
<!--- if the nest is being used in the table on the category manage page, we need to use table row tags --->
<cfif arguments.output_type EQ 2>
<cfset catNameOutput = "<tr> <td>edit</td> <td>delete</td> <td>" & indent & Trim(catName) & "</td> </tr>">
</cfif>
<cfset output = output & catNameOutput>
<!--- reset the indentation --->
<cfset indent = "">
<!--- check for children of this child --->
<cfquery name="checkForKids" datasource="webdsn">
WHERE catParent = '#rsCategoryChildren.catPK#'
</cfquery>
<!--- if there are any, call this function recursively --->
<cfif checkForKids.recordcount GT 0>
<cfset GenerateCategories(genCatParent=catPK, level = level +1, output_type = arguments.output_type)>
</cfif>
</cfloop>
<cfreturn output>
</cffunction>
<cfquery name="rsCategoryParents" datasource="webdsn">
WHERE catParent IS NULL
</cfquery>
quote:
<table width="100%" class="managementtable">
<tr bgcolor="#F6F6F6">
<td> </td>
<td> </td>
<td>Category Name</td>
</tr>
<cfloop query="rsCategoryParents">
<cfoutput><tr> <td>edit</td> <td>delete</td> <td>#Trim(catName)#</td> </tr></cfoutput>
<cfset recursivecats = GenerateCategories(genCatParent=catPK,level=0,output_type=2)>
<cfoutput>#recursivecats#</cfoutput>
</cfloop>
</table>
<select name="select">
<option>None</option>
<cfoutput query="rsCategoryParents">
<option value="#catPK#">#Trim(catName)#</option>
<cfset recursivecats = GenerateCategories(genCatParent=catPK,level=0,output_type=1)>
#recursivecats#
</cfoutput>
</select>
