I have downloaded and installed Adobe Digital Edition V4 and cannot download my purchased ebook. Am also getting error "Error - Check Activation". Can anyone pls help?
I hope you remember the authorization credentials. If yes, then try following steps:
Launch ADE 4.0
In library mode,
Help ->Erase authorization.
Help -> Authorize computer.
Enter the credentials and activate ADE.
Now try to download the book
ADE forced me to update yesterday from whatever version I was using (2?), having postponed this as long as possible (I'm from the "if it ain't broke, don't fix it" school of thought). Well, guess what, now it's broken.
When I try to download a book (acsm), ADE says "Error! Check Activation."
I have tried the above suggestion but erasing the authorization doesn't work. I get "Unable to Erase Authentication. Please try after some time." Lovely error message! What is "some time"? Minutes, days, years? I tried last night, waited an hour, tried again, went to bed, got up this morning, tried again. Same thing every time.
If I ask for Authorization Information, it tells me that I am authorized and has the correct Adobe ID.
I am stuck and I am getting somewhat annoyed at Adobe and all the publishers that insist on relying on a single element in the tool chain.
Thank you.
PS - I am using Windows 7.
If due to some reason, you are unable to deauthorize ADE, follow the below steps:
Windows:
Choose Start > Run.
In the Open text box, type regedit and then press Enter. The Registry Editor opens.
In the left pane of the Registry Editor, locate the following registry key:
HKEY_CURRENT_USER\Software\Adobe\Adept
Right-click the Adept key and choose Delete.
In the Confirm Key Delete dialog, click OK.
Your authorization will be deleted.
ADE will be deauthorized now.
Now Authorize ADE again.
Thank you. This has worked. and I have now been able to re-authorise ADE and download my book.
I wished I saw this in the troubling shooting section of the installed document. I had to google for the problem .
thank you.
this totally worked thankyou, was losing the will to live :-))))
is there a way to print out your answer? I have same problem as Eric.
This worked for me too! Back to reading on the go again! Thank you!!!!
I tried too because I have the same problem but it doesn't work, It say "impossible to destroy all values". I don't know what to do I'm desperate...
