Hi There,
Tried to follow the link http://www.adobe.com/devnet/captivate/articles/store_cpresults.html but I get a "page not found" I am looking for a PHP script to store results to a mysql table.
An example would be great!
Thanks..
This page,
http://help.adobe.com/en_US/captivate/cp/using/WS365a66ad37c9f510-326cdb51265c9c0730-8000.html
says this,
"internalServerReporting.php is the sample PHP that is available in the Adobe Captivate installation folder"
Is that a solution for you to find the script?
Likely here:
(InstallDirectory)/Adobe Captivate (x)/Templates/Publish/
Yeah I know exactly where the example script is to be found, my question was as originally stated "I am looking for a PHP script to store results to a mysql table."
Thanks.
Ah, gotcha. I don't see that file anywhere myself, but here are some possible alternatives:
http://www.adobe.com/devnet-archive/captivate/articles/store_cpresults.html
Seems to be what you wanted but at its new URL?
http://blogs.adobe.com/captivate/2010/08/reporting-the-quiz-results-to-a-local-server.html
The main part talks about what I thought you were asking for, with quick lipservice to later SQL instructions (which I've not been able to find). BUT if you scroll into the comments, there seems to be a wealth of assistance and sample scripts there.
This is cool, but ASP:
http://ian.meinertfamily.us/2011/04/publishing-captivate-to-sql-using-asp-part-i/
http://ian.meinertfamily.us/2011/04/publishing-captivate-to-sql-using-asp-part-ii/
http://ian.meinertfamily.us/2011/04/publishing-captivate-to-sql-using-asp-part-iii/
Thanks for the pointers, should be enough to get me going. Can't believe there aint a PHP/Mysql example, but hey, that's life! I will post back a solution for PHP/Mysql once I have it.
Thanks again for the pointers!
Hi Ludo,
Did you or anyone else work this out..............I am trying to get he quiz results into a mysql database I am using internalServerReporting.php to generate results on-line but would like to get the results directly in mysql without running an import function.
Any example scripts would be very gratefully received
regards
Bernie
Hi Bernie,
I'm also looking for the same thing..
Did you find something?
Sounds like a lot of people are after this, but couldn't find anything online.
best,
Check this thread
Quiz Results Analyzer w/Internal Server
There seems to be a lot there, including sample scripts.
Unfortunately I can't find anything that says "here's a sample script you can use!"
So it'll take a little work
