Hi all I'm having great difficulty getting ColdFusion10 to work under Apache with OS X 10.10 Yosemite.
Here is a description of what I've faced and a little of what I've done to solve my problem
Problem 1
Apache httpd.conf file gets messed up
Solution: copy original httpd.conf file from /etc/apache2/original/ to /etc/apache2/
Problem 2
No Java Virtual Machine is installed!
Solution: install Java (version 6 or 7 is better) you may only be able to install version 8
Problem 3
ColdFusion doesn't know where your Java installation is so find and update your ColdFusion configuration files
/Applications/ColdFusion10/cfusion/bin/jvm.config
/Applications/ColdFusion10/cfusion/bin/coldfusion
/Applications/ColdFusion10/cfusion/runtime/bin/wsconfig_jvm.config
change the source to whatever your current Java is and where it's located
for example if you have version 7 installed:
/Library/Java/JavaVirtualMachines/jdk1.7.0_45.jdk/Contents/Home
if you have version 8 installed:
/Library/Java/JavaVirtualMachines/jdk1.8.0_25.jdk/Contents/Home
Problem 4
INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: YOUR PATH HERE!
Solution:Still working on this one!
