4 Replies Latest reply: Nov 5, 2014 3:48 PM by MoncyMelb RSS
    ColdFusion 10 Enterprise Lincese
    MoncyMelb Community Member
      Hi
      I would like to migrate me ColdFusion 10 Enterprise 2CPU license to a new VMware server. The issue is VMware doesn't support multi core processors, so the server built with 8 processors.
      Am I allowed to migrate this ColdFusion license to the new server? Do I need to upgrade my ColdFusion License?
      Thanks for your help
      Regards
      MA
        • 1. Re: ColdFusion 10 Enterprise Lincese
          vishu#13 Community Member
          Hi MA
          You will be able to do so. Check ColdFusion 10 End User License Agreement : http://labs.adobe.com/technologies/eula/coldfusion10.html
          VJ
          • 2. Re: ColdFusion 10 Enterprise Lincese
            Carl Von Stetten MeganK
            Can you clarify this?  Assuming you are using VMware vSphere, you can specify number of virtual sockets (roughly equal to a physical CPU) and number of cores per socket (also about equal to physical cores) when you create or modify a virtual machine.  So that shouldn't be an issue.  The real issue is that the EULA has different limitations with what you can do on physical and virtual servers.
            • 3. Re: ColdFusion 10 Enterprise Lincese
              Thanks VJ,
              The clause 3.1.1  explains about the CPU numbers.  The license is directly depend upon the number of CPUs.
              As an example,  one  2 CPU  license is  required for a computer with 2 processors (each 4 cores). The issue with VMware that it maps all cores as separate processors! Means the same server will be identified as a 8 processor machine, so requires to obtain a 8 CPU license.  The license agreement doesn't say anything about VMware installations!
              Any other thoughts?
              MA
              3.1.1 Adobe grants Licensee a license to install and use the Software as Production Software on a per-CPU basis as provided in a separate writing. The total number of CPUs of all of the Computers on which the Software operates may not exceed the total number of CPUs separately licensed. For purposes of this License Metric, (a) all CPUs on a Computer on which the Software is installed shall be deemed to operate the Software unless Licensee configures that Computer (using a reliable and verifiable means of hardware or software partitioning) such that the total number of CPUs that actually operate the Software is less than the total number on that Computer, and (b) a CPU shall mean a single, physical chip with the capability of housing multiple processor cores. If Licensee purchases a 2-CPU Production Software license, then each CPU to which it applies such license must reside in the same Computer. In the event that Licensee desires to apply 2-CPU Production Software licenses to Virtual Machines, then (c) for the Standard version of the Software, the number of 2-CPU licenses required shall be the greater of the number of available physical CPUs for all instances of the Software divided by two (any fractions shall be rounded up for purposes of this provision), or (ii) the total number of Virtual Machines on all Computers on which the Software is installed, and (d) for the Enterprise version of the Software, the number of 2-CPU licenses required shall be the number of physical CPUs on which the Software operates divided by two (any fractions shall be rounded up for purposes of this provision).
              • 4. Re: ColdFusion 10 Enterprise Lincese
                Thanks Carl,
                Looks interesting. I checked forum and it support your arguments (supports cores per socket). I will check with the server team and get back to the forum.
                Regards
                MA
