1. Re: Can I export a video from an HD timeline directly to SD video without the black spaces at the top and bottom?
shooternz Nov 5, 2014 8:21 PM (in response to OE2727)It all depends on the Broadcasters delivery Spec.
If they want SD FHA...change the PAR to anamorphic
You do this from an HD Sequence.
Why are you zooming stuff?
2. Re: Can I export a video from an HD timeline directly to SD video without the black spaces at the top and bottom?
OE2727 Nov 5, 2014 8:33 PM (in response to shooternz)Thanks, I said I zoom in the video after I bring the HD video into a NTSC timeline, not exactly zoom in (my bad) but adjust the video to be on full frame
Where do I change the PAR? on the export settings I don't find that option
3. Re: Can I export a video from an HD timeline directly to SD video without the black spaces at the top and bottom?
shooternz Nov 5, 2014 8:43 PM (in response to OE2727)It all depends on the Broadcasters delivery Spec.
You need to know this and I need to know it to offer advice.
4. Re: Can I export a video from an HD timeline directly to SD video without the black spaces at the top and bottom?
OE2727 Nov 5, 2014 9:03 PM (in response to shooternz)"SD NTSC video, we are not HD yet" ... thats all the instructions/spec I got directly from them
FHA you mean SD widescreen right? no they won't take widescreen, just standard SD, the one that is almost square and where I will be cutting the edges of the HD video
I tried changing the sequence settings to anamorphic as you advised, doesn't really work out
5. Re: Can I export a video from an HD timeline directly to SD video without the black spaces at the top and bottom?
shooternz Nov 5, 2014 11:57 PM (in response to OE2727)All you can do is edit your HD footage in an SD Sequence eg DV NTSC
Use Motion to Fit the HD vertically. The side crop will occur automatically.
Set your Graphics for what ever the broadcaster calls Safe Title
EXPORT DV NTSC
