3 Replies Latest reply: Nov 7, 2014 1:00 AM by Mauro Marenzi RSS
    Director Stage - HD Video performance, need Help !
    Mauro Marenzi Community Member
      Hi all,
      im using Director for 3D projects but now i have a client who want to create some multimedia kiosks.
      Is the first time i'm creating projector to play videos, and im having very big problems playing videos on the stage ..
      The videos im playing are in 1920x1080 ( fullHd ), and i have a lot of troubles with performance.
      i add a link to download ( .dir + .exe + .f4v )
      http://www.360map.eu/test/test_video.zip
      Unfortunatly i tried many video format and compressions, DTS on or off... but all seems to be the same.
      Is there a way to improve video quality and smoothness performance ?
      Im playing them on my I5 + NVidia gcard, but the videos , even if im not adding lingo code in my "projector.exe", are not smooth as they should be !!
      i hope this forum could help me, thanks!
      Mauro
        • 1. Re: Director Stage - HD Video performance, need Help !
          Shylock74 Community Member
          On windows machines ONLY MP4.
          • 2. Re: Director Stage - HD Video performance, need Help !
            in my example im using f4v, put ALSO using MP4 H264 i have exactly the same problem !
            No differences!
            Mauro
            • 3. Re: Director Stage - HD Video performance, need Help !
              Hi all,
              i found a solution, maybe somebody with the same trouble could use it, btw if somebody have simpler solutions please let me know
              my solution:
              im using DirectOs Xtra ( www.directxtras.com ) to launch "VLC.exe" video player with a simple configuration that:
              1) quit when video is finished
              2) don't show windows interface
              3) fullscreen always even after a double click
              4) no message error window from VLC after closing
              then im using another function of DirectOs Xtra to check if the "Windows task bar" is visible , and if YES the program is hiding it.
              the simple example code:
              on beginSprite
                dosRegister ("yourSerialNumber")
              end
              on mouseUp
                _programPath = "C:\Program Files (x86)\VideoLAN\VLC\vlc.exe "  -- last character is a SPACE " "
              -- last character is a SPACE " ", very important: the name should not have SPACE charactes, for example:
              _videoPath = "D:\CARLO CRIVELLI.mp4 " -- this is NOT correct
              _videoPath = "D:\CARLO_CRIVELLI.mp4 " -- this is correct
              -- command line using VLC command line config help
                _commandLine = "--fullscreen --quiet where --width=0 --height=0 --video-x=0 --video-y=0 --no-video-deco --no-embedded-video vlc://quit --no-video-title"
                dosLaunchApp( _programPath & _videoPath & _commandLine, "Normal", 0 )
              end
              -- check if the taskBar is visible, if yes this function will hide it
              on exitFrame
                TopWindows = dosGetTopWindowIDs()
                TaskBarFound = false
                repeat with i=1 to count (TopWindows)
                  CurrWindow = GetAt (TopWindows, i)
                  if (dosGetWindowClassName (CurrWindow) = "Shell_TrayWnd") then
                    TaskBarFound = true
                    -- close taskbar
                    if dosGetWindowState (CurrWindow, "Hidden") then
                      Success = dosSetWindowState (CurrWindow, "Normal")
                    else
                      Success = dosSetWindowState (CurrWindow, "Hidden")
                    end if
                    if (not Success) then
                      put "Can't show or hide the taskbar, error # "&dosGetLastError()
                    end if
                    exit repeat
                  end if
                end repeat
              end
              I'm also playing with VLC preference menu', to hide " error message window " and to use a different Skin interface ( using VLCSkinEditor )
              Mauro
