1. Re: Invalid signing error
Neil Enns - Adobe Nov 5, 2014 3:18 PM (in response to PatriciaGagnon)I've branched this to a new discussion since your error is different from the thread you posted to. The error in your case is telling you what's wrong: you've used a certificate to sign the app, but the .mobileprovision file uses a different certificate. You need to make sure you use a matched set.
Neil
2. Re: Invalid signing error
PatriciaGagnon Nov 6, 2014 9:06 AM (in response to Neil Enns - Adobe)Well, is it possible that I deleted the right certicate and that I cannot do the right .mobileprovision file anymore...?
3. Re: Invalid signing error
Neil Enns - Adobe Nov 6, 2014 9:15 AM (in response to PatriciaGagnon)Yes, that’s possible. You’ll need to go into iTunes Developer Portal and generate a new .mobileprovision file.
Neil
4. Re: Invalid signing error
PatriciaGagnon Nov 6, 2014 10:45 AM (in response to Neil Enns - Adobe)I went into developer.apple.com to create new .mobileprovision files (dev + distrib) and used them in DPS App Builder.
It's still doesn't work.
When I tried to update my app in the first time, I had to make new certificate because the one I used before were expired.
Does it has something to do with my problem?
Also, I changed computer since the first time I sent the app. Does it has something to do with my problem?
Can I have online support? I don't think I can troubleshoot this myself.
5. Re: Invalid signing error
PatriciaGagnon Nov 6, 2014 12:24 PM (in response to PatriciaGagnon)Ok. Well, I got help from a developer. He made me revoke all my certificates (in developer.apple.com) and also in my keychain. Then I reacreate the new certificates (dev+distrib), made the p12 certificates, regenerate the new provision files and add them to Xcode (with iPhone Configuration Utility that I download, because I cannot see my Provision files in Xcode anymore).
Then I sent my .zip file to Application Loader and it worked.
Thanks for you help.
6. Re: Invalid signing error
Neil Enns - Adobe Nov 6, 2014 1:10 PM (in response to PatriciaGagnon)Glad you got it sorted out!
Neil
