How can I remove the Powered by message in the output (HTML) in RoboHelp10?
Don’t select the option in your SSL
Hi Jeff,
Sorry but where do I find the Option in the SSL? Please help.
It’s on the Navigation page – it’s the “Add About Box” field
Thank you!
Hi there
Note that you do have a significant amount of control if you want. For example, you can substitute your own image to replace the Powered By image. Perhaps your company logo? And when the image is clicked, another little window pops up and you are also able to customize that by supplying other images and information. And if you REALLY want to go rogue, you can create your own HTML page that opens when the user clicks the toolbar icon.
Cheers...Rick
Hi Rick,
Where can I add my own logo to that? Is it in the Navigation page as well?
Hello again
You change the image using the Skin editor. Click View > Pods > Project Set-up, then expand the Skins folder and double-click the skin you are using for the project.
Select About. then click the Pencil icon and you finally use the file folder icon to browse to and select the image.
Cheers... Rick
Excellent...Thank you!
