はじめまして、3日程前よりPs、Aiのアイコン表示が上手く表示されない為、昨夜アンインストール後、再度インストールしたのですができません。ちなみにWindows7、Adobe Creative Suite5.5 Design premiumを利用しています。エラーコードは以下の表示がなされます。対応策を教えてくださいExit Code: 7
Nov 06, 2014 Nov 06, 2014
Ps,Ai共に再度インストールするのですがDLできません。対応方法を教えてください
PC  windows7
ソフト Adbe Creative Suite5.5 Design Premium
エラーコード Code:7
Exit Code: 7
-------------------------------------- Summary --------------------------------------
- 1 fatal error(s), 10 error(s), 8 warning(s)
WARNING: DW024: The payload: Adobe Photoshop CS5.1 Core  {08EF22BC-43B2-4B4E-BA12-52B18F418F38} requires a UI parent with following specification:
    Family: Photoshop
    ProductName: Adobe Photoshop CS5.1 Core_x64
    This parent relationship is not satisfied, because this payload is not present in this session.
ERROR: DW025: The payload with AdobeCode:  {857CC5F0-040E-1016-A173-D55ADD80C260} has required dependency on:
    Family: InDesign
    ProductName: Adobe InDesign CS5.5 Icon Handler x64
    MinVersion: 0.0.0.0
    This dependency is not satisfied, because this payload is x64 and is not supported on this machine.
    Removing this dependency from list. Product may function improperly.
WARNING: DW025: The payload with AdobeCode:  {857CC5F0-040E-1016-A173-D55ADD80C260} has recommended dependency on:
    Family: Adobe Web Suite CS5.5
    ProductName: Adobe Media Encoder CS5.5 X64
    MinVersion: 0.0.0.0
    Removing this payload from the dependency list.
WARNING: DW025: The payload with AdobeCode:  {D8CCCF4C-C227-427C-B4BE-736657D2AB7E} has recommended dependency on:
    MinVersion: 0.0.0.0
ERROR: DW025: The payload with AdobeCode:  {D97AF04B-B70A-4862-BC25-31E6D9C4A529} has required dependency on:
    Family: CoreTech
    ProductName: Adobe Player for Embedding x64 3.1
    MinVersion: 0.0.0.0
    Family: Shared Technology
    ProductName: Photoshop Camera Raw (64 bit)
    MinVersion: 0.0.0.0
    Family: CoreTech
    ProductName: AdobeCMaps x64 CS5
    MinVersion: 0.0.0.0
    Family: CoreTech
    ProductName: Adobe Linguistics CS5 x64
    MinVersion: 0.0.0.0
    Family: CoreTech
    ProductName: AdobePDFL x64 CS5
    MinVersion: 0.0.0.0
    Family: CoreTech
    ProductName: AdobeTypeSupport x64 CS5
    MinVersion: 0.0.0.0
    Family: CoreTech
    ProductName: Adobe WinSoft Linguistics Plugin CS5 x64
    MinVersion: 0.0.0.0
WARNING: DW025: The payload with AdobeCode:  {D97AF04B-B70A-4862-BC25-31E6D9C4A529} has recommended dependency on:
    MinVersion: 0.0.0.0
WARNING: DW031: Payload:{2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 3.0.0.0 has been updated and has been selected for repair. The patch {42774483-D33C-46F7-8B20-FD0B1A3DAC25} Adobe XMP Panels CS5_3.1_AdobeXMPPanelsAll 3.1.0.0 will be uninstalled now.
WARNING: DW034: Warning: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer 6.0.0.0 will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
WARNING: DW034: Warning: {4058E728-84D8-45CE-8E2D-5F35BD6659A1} Adobe Extension Manager CS5.5 5.5.0.0 will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
WARNING: DW034: Warning: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw 6.0.0.0 will not be repaired, due to updated patch of the payload and one of the top level payload is being installed.
ERROR: DW020: Found payload conflicts and errors:
ERROR: DW020:  - Adobe Flash CS5.5 depends on Adobe Flash Player 10 ActiveX to be installed.
FATAL: DW020: Conflicts were found in the selected payloads. Halting installation.
403
インストーラーの破損や読み取り不良が考えられますので、
一旦インストーラーの内容をPCにコピーしてからインストールを行うか、
下記ページよりインストーラーをダウンロードして実行してみてください。
CS5.5製品のダウンロード
念のため、Exit Code:7に関する技術文書も提示しておきます。
Creative Suite 5.x 製品のインストールが「Exit Code: 6 」または「Exit Code: 7 」で失敗する
「インストールに問題があります」エラーの対処方法(Creative Suite 5, 5.5)
ありがとうございます。インストラーが壊れていたようです。再度インストしたらDLできました。
「インストールに問題があります」エラーの対処方法(Creative Suite 5, 5.5)に原因と対処方法が掲載されています。
こちらをご覧いただき、システムからの再インストールもしくはフォルダ・ファイルの削除を実行してみてください。
ありがとうございます。何とかインストできました。
