1. Re: Can't play audio
SteveG(AudioMasters) Nov 6, 2014 1:42 AM (in response to georginasmith)Sorry, nowhere near enough information here. We'd either need to see an example of a file that doesn't open, or at the very least, a lot more information about it.
2. Re: Can't play audio
georginasmith Nov 6, 2014 5:19 PM (in response to SteveG(AudioMasters))Thank you Steve, what more information do you need?
3. Re: Can't play audio
georginasmith Nov 6, 2014 5:28 PM (in response to georginasmith)The file is 1411 kbs, 12.7MB, and plays fine in media playback. But when I put it in adobe, it looks blank, and I can't play it back. When I amplify the file it says "The selected file has no output channels available," and asks if I want to check hardware, then I say yes and it says: The device settings could not be applied for the following reason: MME device internal error. The last valid settings will be used. Then it says: "The last device settings could not be used. Please check your hardware."
4. Re: Can't play audio
SteveG(AudioMasters) Nov 7, 2014 1:37 AM (in response to georginasmith)There are two things to talk about here:
Can you tell me what type of file this is? As in MP3, Wav, etc. Any file that opens and looks blank is a bit suspect...
This sounds as though you have a fundamental problem with your computer's hardware, or at least the driver for it. One question though - does Audition play any files correctly?
5. Re: Can't play audio
georginasmith Nov 7, 2014 4:04 AM (in response to georginasmith)Hi Steve,
Thanks very much for answering - I've had an Adobe person look at it and it's fixed - the problem was a hardware malfunction with the drivers, you were right! Thanks again.
