When I click the Next button in the Print Document General - Printed Documentation Wizard, RH10 stops working.
It allows me to Save and Generate but does not allow to click Next.
I get the same error in sample projects too..
Attached is the screenshot showing the crash.
Can somebody tell me what causes this crash?
Have you ever been able to produce Printed Documentation? What version of Word are you using? Or could the macro security settings in Word have been changed. See the Word Issues section of the following link helps.
Thanks for the response. I had compatibility issues for RH10 and downgrading to Word 2010 solved the problem. I have been generating PDF outputs. All of a sudden, I get this crashing error.
I use Word 2010 and macros are enabled.
What happens if you click Save and Generate rather than Next in that dialog? If that doesn't work, try creating a new TOC and selecting that in the Table of Contents drop down.
If I click Save and Generate, I'm able to generate the word documnet.
If I click Save and Generate, I'm able to generate the word document. But in order to make changes, I click Next and it hangs.
I added some new topics to an existing project. I created a new TOC and generated the word doc. But the new topics were not included in the doc. That's when I clicked Next to check whether those new topics are included while generating the word doc and it hangs. I don't get any malformed topics error.
I tried creating PDF for review and I could find all the topics in the review PDF.
Only in the Printed Documentation wizard I have this issue. I need the word doc to make some changes. Any solution please?
