I have issues where I create a form with the web-form tool, go to a page and embed the form as a module, everything works as described. Then, after several days, I need to add/change/delete a field. I go to the web-form tool, make my changes and update. The embedded module doesn't reflect the changes to the form. So far the only way I can get this to work is to copy the form, make changes on the new form, and then delete the previous embed module code and embed the new (copied) form. This isn't the way that BC says the embed form module is suppose to work. What is the issue?
