Im having the same issue log files below
2012-09-30 08:40:19 +0000 ---------- log start ----------
2012-09-30 08:40:19 +0000 All install checks pass
2012-09-30 08:40:35 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-09-30 08:40:50 +0000 [install started]
installer: Package name is PlugIn
installer: Installing at base path /
installer: The install was successful.
sudo: no tty present and no askpass program specified
2012-09-30 08:40:56 +0000 [install completed]
2012-09-30 08:40:56 +0000 [install succeeded]
2012-09-30 08:41:03 +0000 ---------- log end ----------
2012-09-30 08:41:02 +0000 Changing update mode to 0
2012-10-17 20:55:45 +0000 ---------- log start ----------
2012-10-17 20:55:45 +0000 All install checks pass
2012-10-17 20:55:57 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-10-17 20:56:02 +0000 [install started]
installer: Upgrading at base path /
installer: The upgrade was successful.
2012-10-17 20:56:07 +0000 [install completed]
2012-10-17 20:56:07 +0000 [install succeeded]
2012-10-17 20:56:13 +0000 ---------- log end ----------
2012-10-17 20:56:13 +0000 Changing update mode to 0
2012-11-12 06:35:37 +0000 ---------- log start ----------
2012-11-12 06:35:37 +0000 580
2012-11-12 06:37:42 +0000 16875066
2012-11-12 06:37:42 +0000 verifySignatureWithData : Message Verified!
2012-11-12 06:37:47 +0000 ---------- log end ----------
2012-11-12 06:37:52 +0000 ---------- log start ----------
2012-11-12 06:37:52 +0000 All install checks pass
2012-11-12 06:38:05 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-11-12 06:38:23 +0000 [install started]
dyld: DYLD_ environment variables being ignored because main executable (/var/folders/nq/51mz5r2n1ddb5zhm2ybh9h1m0000gn/T/FPInstallHelper) is setuid or setgid
dyld: DYLD_ environment variables being ignored because main executable (/System/Library/PrivateFrameworks/Install.framework/Resources/runner) is setuid or setgid
2012-11-12 06:38:29 +0000 [install completed]
2012-11-12 06:38:29 +0000 [install succeeded]
2012-11-12 06:38:33 +0000 ---------- log end ----------
2012-11-12 06:38:33 +0000 Changing update mode to 0
2012-12-13 06:06:25 +0000 ---------- log start ----------
2012-12-13 06:06:25 +0000 580
2012-12-13 06:44:35 +0000 16881565
2012-12-13 06:44:35 +0000 verifySignatureWithData : Message Verified!
2012-12-13 06:44:39 +0000 ---------- log end ----------
2012-12-13 06:44:43 +0000 ---------- log start ----------
2012-12-13 06:44:43 +0000 All install checks pass
2012-12-13 06:45:01 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2012-12-13 10:37:47 +0000 ---------- log end ----------
2013-01-10 08:10:06 +0000 ---------- log start ----------
2013-01-10 08:10:06 +0000 580
2013-01-10 08:10:07 +0000 580
2013-01-10 10:19:48 +0000 ---------- log end ----------
2013-02-08 07:24:47 +0000 ---------- log start ----------
2013-02-08 07:24:47 +0000 580
2013-02-08 07:25:01 +0000 16881352
2013-02-08 07:25:01 +0000 verifySignatureWithData : Message Verified!
2013-02-08 07:25:05 +0000 ---------- log end ----------
2013-02-08 07:25:22 +0000 ---------- log start ----------
2013-02-08 07:25:22 +0000 All install checks pass
2013-02-08 07:25:38 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-02-10 10:03:25 +0000 ---------- log end ----------
2013-02-08 09:16:47 +0000 [install started]
2013-02-08 09:16:58 +0000 [install completed]
2013-02-08 09:16:59 +0000 ---------- log end ----------
2013-02-15 12:40:58 +0000 ---------- log start ----------
2013-02-15 12:40:58 +0000 1214
2013-02-15 12:41:16 +0000 16931999
2013-02-15 12:41:17 +0000 verifySignatureWithData : Message Verified!
2013-02-15 12:41:21 +0000 ---------- log end ----------
2013-02-15 12:41:26 +0000 ---------- log start ----------
2013-02-15 12:41:26 +0000 All install checks pass
2013-02-15 12:41:38 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-02-17 01:47:44 +0000 [install started]
2013-02-17 01:47:57 +0000 [install completed]
2013-02-17 01:47:57 +0000 [install succeeded]
2013-02-17 01:48:00 +0000 ---------- log end ----------
2013-02-17 01:48:00 +0000 Changing update mode to 0
2013-03-06 06:24:38 +0000 ---------- log start ----------
2013-03-06 06:24:38 +0000 All install checks pass
2013-03-06 06:24:51 +0000 User has 1 process that needs to be closed before the Flash Player can be installed.
2013-03-06 06:25:02 +0000 [install started]
2013-03-06 07:25:04.446 installer[39219:5503] -[IFRunnerProxy makeDirectory:attributes:withKey:]: unrecognized selector sent to instance 0x7fdce4301440
installer: The upgrade failed (The Installer encountered an error that caused the installation to fail. Contact the software manufacturer for assistance.)
2013-03-06 06:25:08 +0000 [install completed]
2013-03-06 06:25:08 +0000 [install failed]
2013-03-06 06:25:16 +0000 ---------- log end ----------
2013-03-06 06:25:16 +0000 Changing update mode to 0
2013-03-06 06:25:21 +0000 ---------- log start ----------
2013-03-06 06:25:21 +0000 All install checks pass
2013-03-06 06:25:29 +0000 User does not have any processes that need to be closed before the Flash Player can be installed.
2013-03-06 06:25:29 +0000 [install started]
2013-03-06 06:25:35 +0000 [install completed]
2013-03-06 06:25:35 +0000 [install succeeded]
2013-03-06 06:25:37 +0000 ---------- log end ----------
2013-03-06 06:25:37 +0000 Changing update mode to 0
2013-03-16 15:30:01 +0000 ---------- log start ----------
2013-03-16 15:30:01 +0000 1214
2013-03-20 07:01:17 +0000 ---------- log end ----------
2013-04-14 06:20:14 +0000 ---------- log start ----------
2013-04-14 06:20:14 +0000 1214
2013-04-14 06:20:19 +0000 ---------- log end ----------
2013-04-14 06:24:53 +0000 ---------- log start ----------
2013-04-14 06:24:53 +0000 All install checks pass
2013-04-14 06:24:54 +0000 ---------- log end ----------
2013-04-14 07:13:22 +0000 ---------- log start ----------
2013-04-14 07:13:22 +0000 All install checks pass
2013-04-14 07:13:23 +0000 [install started]
2013-04-14 07:13:34 +0000 [install completed]
2013-04-14 07:13:35 +0000 ---------- log end ----------
2013-05-28 00:13:52 +0000 ---------- log start ----------
2013-05-28 00:13:53 +0000 1214
2013-05-28 00:13:55 +0000 1214
2013-05-28 00:13:58 +0000 ---------- log end ----------
2013-07-15 00:39:26 +0000 ---------- log start ----------
2013-07-15 00:39:26 +0000 1213
2013-07-15 00:39:43 +0000 ---------- log end ----------
2013-07-24 04:56:51 +0000 ---------- log start ----------
2013-07-24 04:56:52 +0000 1213
2013-07-24 04:56:56 +0000 ---------- log end ----------
2013-07-24 05:19:27 +0000 ---------- log start ----------
2013-07-24 05:19:27 +0000 All install checks pass
2013-07-24 05:19:32 +0000 [install started]
2013-07-24 05:19:44 +0000 [install succeeded]
2013-07-24 05:19:44 +0000 ---------- log end ----------
2013-09-14 22:19:40 +0000 ---------- log start ----------
2013-09-14 22:19:40 +0000 1214
2013-09-14 22:19:41 +0000 1214
2013-09-14 22:20:23 +0000 ---------- log end ----------
2013-11-18 06:24:19 +0000 ---------- log start ----------
2013-11-18 06:24:19 +0000 1389
2013-11-18 06:24:20 +0000 1389
2013-11-18 06:24:23 +0000 ---------- log end ----------
2013-11-25 06:24:29 +0000 ---------- log start ----------
2013-11-25 06:24:29 +0000 1389
2013-11-25 06:24:33 +0000 ---------- log end ----------
2013-12-02 06:52:23 +0000 ---------- log start ----------
2013-12-02 06:52:23 +0000 1389
2013-12-02 08:35:19 +0000 ---------- log end ----------
2013-12-09 06:53:20 +0000 ---------- log start ----------
2013-12-09 06:53:20 +0000 1389
2013-12-10 02:46:51 +0000 ---------- log end ----------
2013-12-16 06:54:10 +0000 ---------- log start ----------
2013-12-16 06:54:10 +0000 1389
2013-12-16 06:54:14 +0000 ---------- log end ----------
2013-12-23 08:17:40 +0000 ---------- log start ----------
2013-12-23 08:17:40 +0000 1389
2013-12-23 18:52:41 +0000 18417494
2013-12-23 18:52:41 +0000 verifySignatureWithData : Message Verified!
2013-12-23 18:52:46 +0000 ---------- log end ----------
2013-12-23 18:52:49 +0000 ---------- log start ----------
2013-12-23 18:52:49 +0000 All install checks pass
2013-12-23 18:53:00 +0000 User has 2 processes that need to be closed before the Flash Player can be installed.
2013-12-23 19:09:01 +0000 ---------- log end ----------
2013-12-31 01:28:51 +0000 ---------- log start ----------
2013-12-31 01:28:51 +0000 1389
2013-12-31 01:28:55 +0000 ---------- log end ----------
2014-01-21 02:56:32 +0000 ---------- log start ----------
2014-01-21 02:56:32 +0000 1386
2014-01-21 02:56:37 +0000 ---------- log end ----------
2014-01-28 02:56:34 +0000 ---------- log start ----------
2014-01-28 02:56:34 +0000 1386
2014-01-28 02:56:39 +0000 ---------- log end ----------
2014-01-27 17:02:44 -1000 IM: ---------- log start ----------
2014-01-27 17:02:44 -1000 IM: All install checks pass
2014-01-27 17:02:54 -1000
2014-01-27 17:02:54 -1000 IM: ---------- log end ----------
2014-02-04 03:21:41 +0000 ---------- log start ----------
2014-02-04 03:21:41 +0000 1386
2014-02-09 18:04:50 +0000 ---------- log end ----------
2014-02-09 08:10:27 -1000 IM: ---------- log start ----------
2014-02-09 08:10:27 -1000 IM: All install checks pass
2014-02-09 08:10:29 -1000 IM: User does not have any processes that need to be closed.
2014-02-09 08:10:29 -1000 IM: [install started]
2014-02-09 08:10:33 -1000 FIN: [finalizer started]
2014-02-09 08:10:33 -1000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-02-09 08:10:33 -1000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-02-09 08:10:35 -1000 FIN: [finalizer succeeded]
installer: Package name is Adobe Flash Player
2014-02-09 08:10:41 -1000 IM: [install succeeded]
2014-02-09 08:10:41 -1000 IM: ---------- log end ----------
2014-02-09 09:05:46 -1000
2014-02-09 10:05:45 -1000
2014-02-09 11:05:45 -1000
2014-02-09 12:05:45 -1000
2014-02-10 16:05:45 -1000
2014-02-10 17:05:39 -1000
2014-02-10 18:05:39 -1000
2014-02-10 19:05:39 -1000
2014-02-10 20:05:39 -1000
2014-02-10 21:05:39 -1000
2014-02-11 17:12:52 -1000
2014-02-11 18:12:52 -1000
2014-02-11 19:12:52 -1000
2014-02-11 20:12:52 -1000
2014-02-11 21:12:52 -1000
2014-02-11 23:22:52 -1000
2014-02-12 14:29:04 -1000
2014-02-12 15:29:01 -1000
2014-02-12 20:20:50 -1000
2014-02-12 21:20:50 -1000
2014-02-13 09:59:44 -1000
2014-02-13 10:59:44 -1000
2014-02-13 11:59:44 -1000
2014-02-13 12:59:44 -1000
2014-02-13 20:02:03 -1000
2014-02-13 21:02:03 -1000
2014-02-13 22:02:03 -1000
2014-02-14 14:51:03 -1000
2014-02-14 15:51:03 -1000
2014-02-14 16:50:57 -1000
2014-02-14 17:50:57 -1000
2014-02-14 18:50:57 -1000
2014-02-14 19:50:57 -1000
2014-02-14 20:50:56 -1000
2014-02-14 21:50:56 -1000
2014-02-14 22:50:56 -1000
2014-02-14 23:50:56 -1000
2014-02-15 00:50:56 -1000
2014-02-15 01:50:56 -1000
2014-02-15 08:44:29 -1000
2014-02-15 09:44:29 -1000
2014-02-15 12:14:20 -1000
2014-02-15 13:14:17 -1000
2014-02-15 19:31:07 -1000
2014-02-15 20:31:07 -1000
2014-02-15 21:31:07 -1000
2014-02-15 22:31:07 -1000
2014-02-15 23:31:07 -1000
2014-02-16 08:22:57 -1000
2014-02-16 09:22:57 -1000
2014-02-16 10:22:57 -1000
2014-02-16 11:22:57 -1000
2014-02-16 12:22:57 -1000
2014-02-16 13:22:57 -1000
2014-02-16 14:22:57 -1000
2014-02-16 15:22:56 -1000
2014-02-16 16:22:56 -1000
2014-02-16 17:22:56 -1000
2014-02-16 18:22:54 -1000
2014-02-16 19:22:54 -1000
2014-02-16 20:22:54 -1000
2014-02-16 21:22:53 -1000
2014-02-17 07:13:44 -1000
2014-02-17 10:30:26 -1000
2014-02-17 11:30:26 -1000
2014-02-17 15:04:19 -1000
2014-02-17 16:04:18 -1000
2014-02-17 17:04:18 -1000
2014-02-17 18:04:18 -1000
2014-02-17 19:04:18 -1000
2014-02-17 20:04:17 -1000
2014-02-17 21:04:18 -1000
2014-02-18 04:33:28 -1000
2014-02-18 17:33:42 -1000
2014-02-18 18:33:41 -1000
2014-02-18 19:33:41 -1000
2014-02-19 15:11:29 -1000
2014-02-19 17:22:15 -1000
2014-02-19 18:22:14 -1000
2014-02-19 19:22:14 -1000
2014-02-19 20:22:14 -1000
2014-02-20 15:02:14 -1000
2014-02-20 17:49:21 -1000
2014-02-20 18:49:20 -1000
2014-02-20 19:49:20 -1000
2014-02-21 16:27:59 -1000
2014-02-21 18:15:05 -1000
2014-02-22 15:52:43 -1000
2014-02-22 16:52:43 -1000
2014-02-22 17:52:43 -1000
2014-02-22 19:30:38 -1000
2014-02-22 20:30:38 -1000
2014-02-22 21:30:39 -1000
2014-02-22 22:30:39 -1000
2014-02-23 16:25:38 -1000
2014-02-23 17:25:38 -1000
2014-02-23 18:25:38 -1000
2014-02-23 19:55:38 -1000
2014-02-23 22:36:35 -1000
2014-02-24 16:36:14 -1000
2014-02-24 17:36:14 -1000
2014-02-24 19:47:30 -1000 IM: ---------- log start ----------
2014-02-24 19:47:31 -1000 IM: 1386
2014-02-24 20:02:58 -1000
2014-02-24 21:02:55 -1000
2014-02-25 17:13:34 -1000
2014-02-25 18:13:34 -1000
2014-02-25 20:09:21 -1000
2014-02-25 21:09:21 -1000
2014-02-25 22:09:21 -1000
2014-02-26 16:57:49 -1000 IM: ---------- log end ----------
2014-02-26 17:01:39 -1000
2014-02-26 18:01:37 -1000
2014-02-26 19:14:02 -1000
2014-02-26 20:14:02 -1000
2014-02-26 21:14:02 -1000
2014-02-27 09:42:50 -1000
2014-02-27 16:24:39 -1000
2014-02-27 19:37:05 -1000
2014-02-27 20:36:59 -1000
2014-02-28 14:28:06 -1000
2014-03-01 08:31:44 -1000
2014-03-01 09:31:44 -1000
2014-03-01 10:31:44 -1000
2014-03-01 11:31:44 -1000
2014-03-01 21:09:42 -1000
2014-03-01 22:09:55 -1000 IM: ---------- log start ----------
2014-03-01 22:09:55 -1000 IM: All install checks pass
2014-03-01 22:09:55 -1000 IM: [install started]
2014-03-01 22:09:59 -1000 FIN: [finalizer started]
2014-03-01 22:09:59 -1000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-03-01 22:09:59 -1000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-03-01 22:10:01 -1000
2014-03-01 22:10:02 -1000 IM: [install succeeded]
2014-03-01 22:10:02 -1000 IM: ---------- log end ----------
2014-03-03 19:48:21 -1000 IM: ---------- log start ----------
2014-03-03 19:48:21 -1000 IM: 1386
2014-03-03 19:48:27 -1000 IM: ---------- log end ----------
2014-03-03 20:45:14 -1000
2014-03-04 17:04:40 -1000
2014-03-04 18:04:40 -1000
2014-03-04 19:04:40 -1000
2014-03-04 20:04:40 -1000
2014-03-05 17:04:26 -1000
2014-03-05 18:04:22 -1000
2014-03-05 19:04:21 -1000
2014-03-05 20:04:21 -1000
2014-03-06 01:48:59 -1000
2014-03-06 17:36:04 -1000
2014-03-06 18:36:04 -1000
2014-03-06 19:36:04 -1000
2014-03-06 20:36:04 -1000
2014-03-06 21:36:04 -1000
2014-03-06 22:36:03 -1000
2014-03-07 15:34:37 -1000
2014-03-07 16:34:37 -1000
2014-03-07 17:34:37 -1000
2014-03-07 23:15:09 -1000
2014-03-08 06:57:51 -1000
2014-03-08 07:57:52 -1000
2014-03-08 09:46:14 -1000
2014-03-08 10:46:14 -1000
2014-03-08 11:46:14 -1000
2014-03-08 12:46:13 -1000
2014-03-08 18:06:26 -1000
2014-03-08 19:06:26 -1000
2014-03-08 20:06:26 -1000
2014-03-09 08:23:37 -1000
2014-03-09 10:49:03 -1000
2014-03-09 15:41:37 -1000
2014-03-10 17:40:16 -1000
2014-03-10 18:40:15 -1000
2014-03-10 19:40:15 -1000
2014-03-10 20:40:15 -1000
2014-03-11 17:48:02 -1000
2014-03-11 18:48:02 -1000
2014-03-11 20:01:40 -1000
2014-03-11 21:01:39 -1000
2014-03-12 16:58:39 -1000
2014-03-12 19:29:51 -1000
2014-03-12 20:29:51 -1000
2014-03-13 16:40:56 -1000
2014-03-13 17:40:56 -1000
2014-03-13 18:40:52 -1000
2014-03-13 19:40:52 -1000
2014-03-13 20:40:52 -1000
2014-03-14 17:22:45 -1000
2014-03-14 18:22:45 -1000
2014-03-14 19:30:13 -1000
2014-03-14 23:25:21 -1000
2014-03-15 07:59:16 -1000
2014-03-15 12:56:21 -1000
2014-03-15 14:20:21 -1000
2014-03-15 15:25:51 -1000
2014-03-15 16:25:51 -1000
2014-03-15 17:25:50 -1000
2014-03-15 18:35:28 -1000
2014-03-15 19:35:27 -1000
2014-03-15 20:35:27 -1000
2014-03-15 21:35:27 -1000
2014-03-15 22:35:27 -1000
2014-03-15 23:35:26 -1000
2014-03-16 07:51:13 -1000
2014-03-16 12:58:10 -1000
2014-03-16 13:58:10 -1000
2014-03-16 14:58:10 -1000
2014-03-16 15:58:10 -1000
2014-03-16 19:22:07 -1000
2014-03-16 20:22:07 -1000
2014-03-16 21:22:06 -1000
2014-03-16 22:22:06 -1000
2014-03-17 17:31:37 -1000
2014-03-17 18:31:37 -1000
2014-03-17 19:52:43 -1000
2014-03-17 20:14:29 -1000 IM: ---------- log start ----------
2014-03-17 20:14:29 -1000 IM: 1386
2014-03-17 20:52:43 -1000
2014-03-18 17:28:05 -1000
2014-03-18 18:28:04 -1000
2014-03-18 19:28:04 -1000
2014-03-18 20:28:04 -1000
2014-03-18 21:28:04 -1000
2014-03-19 17:50:10 -1000
2014-03-19 18:50:10 -1000
2014-03-19 19:50:10 -1000
2014-03-20 16:53:49 -1000 IM: ---------- log start ----------
2014-03-20 16:53:49 -1000 IM: All install checks pass
2014-03-20 16:53:49 -1000 IM: [install started]
2014-03-20 16:53:52 -1000 FIN: [finalizer started]
2014-03-20 16:53:52 -1000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-03-20 16:53:52 -1000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-03-20 16:53:54 -1000
2014-03-20 16:53:56 -1000 IM: [install succeeded]
2014-03-20 16:53:56 -1000 IM: ---------- log end ----------
2014-03-22 19:01:35 -1000
2014-03-22 20:01:35 -1000
2014-03-22 21:01:35 -1000
2014-03-22 22:01:35 -1000
2014-03-22 23:01:35 -1000
2014-03-23 09:50:06 -1000
2014-03-23 10:50:06 -1000
2014-03-23 11:50:13 -1000
2014-03-23 12:50:13 -1000
2014-03-23 17:17:39 -1000
2014-03-23 18:18:38 -1000
2014-03-23 19:18:37 -1000
2014-03-23 20:18:37 -1000
2014-03-24 16:47:38 -1000
2014-03-24 17:47:38 -1000
2014-03-24 19:59:04 -1000
2014-03-24 20:59:04 -1000
2014-03-25 18:02:38 -1000
2014-03-27 09:15:00 -1000
2014-03-27 11:59:07 -1000
2014-03-27 13:42:18 -1000
2014-03-27 19:17:48 -1000
2014-03-27 20:17:48 -1000
2014-03-27 21:17:47 -1000
2014-03-28 16:04:29 -1000
2014-03-28 17:04:29 -1000
2014-03-28 18:04:28 -1000
2014-03-28 19:53:10 -1000
2014-03-28 20:53:09 -1000
2014-03-28 21:53:09 -1000
2014-03-29 07:57:53 -1000
2014-03-29 08:57:53 -1000
2014-03-29 09:57:53 -1000
2014-03-29 10:57:52 -1000
2014-03-29 11:57:52 -1000
2014-03-29 12:57:52 -1000
2014-03-29 13:57:52 -1000
2014-03-29 14:57:52 -1000
2014-03-29 22:05:05 -1000
2014-03-30 08:36:21 -1000
2014-03-30 09:36:20 -1000
2014-03-30 11:20:27 -1000
2014-03-30 12:20:27 -1000
2014-03-30 13:20:27 -1000
2014-03-30 14:20:27 -1000
2014-03-30 15:20:27 -1000
2014-03-30 16:20:26 -1000
2014-03-30 19:20:04 -1000
2014-03-30 20:20:03 -1000
2014-03-30 21:20:03 -1000
2014-03-31 16:00:44 -1000
2014-03-31 17:00:45 -1000
2014-03-31 18:00:45 -1000
2014-03-31 19:00:44 -1000
2014-03-31 20:00:44 -1000
2014-03-31 21:00:45 -1000
2014-04-01 17:40:46 -1000
2014-04-01 19:27:38 -1000
2014-04-01 20:39:14 -1000
2014-04-01 21:39:13 -1000
2014-04-02 17:02:07 -1000
2014-04-02 18:02:06 -1000
2014-04-02 19:02:06 -1000
2014-04-02 20:02:06 -1000
2014-04-02 21:02:06 -1000
2014-04-02 22:02:06 -1000
2014-04-03 16:54:45 -1000
2014-04-03 17:54:45 -1000
2014-04-03 18:54:45 -1000
2014-04-03 19:54:45 -1000
2014-04-04 15:51:55 -1000
2014-04-04 16:51:51 -1000
2014-04-04 17:51:52 -1000
2014-04-04 23:20:33 -1000
2014-04-05 00:20:33 -1000
2014-04-05 01:20:33 -1000
2014-04-05 08:20:12 -1000
2014-04-05 09:20:12 -1000
2014-04-05 10:20:12 -1000
2014-04-05 11:20:12 -1000
2014-04-05 12:20:11 -1000
2014-04-05 13:20:11 -1000
2014-04-05 14:30:40 -1000
2014-04-05 15:30:40 -1000
2014-04-05 16:30:40 -1000
2014-04-05 17:30:40 -1000
2014-04-05 18:30:40 -1000
2014-04-05 19:30:40 -1000
2014-04-05 20:30:39 -1000
2014-04-05 21:30:40 -1000
2014-04-05 22:30:39 -1000
2014-04-05 23:30:39 -1000
2014-04-06 00:30:39 -1000
2014-04-06 06:59:40 -1000
2014-04-06 09:45:29 -1000
2014-04-06 16:17:25 -1000
2014-04-06 17:17:25 -1000
2014-04-06 18:49:36 -1000
2014-04-06 19:49:36 -1000
2014-04-06 20:49:36 -1000
2014-04-06 21:49:36 -1000
2014-04-06 22:49:35 -1000
2014-04-07 17:23:30 -1000
2014-04-07 18:23:30 -1000
2014-04-07 19:44:19 -1000
2014-04-07 20:44:19 -1000
2014-04-08 16:55:46 -1000
2014-04-08 17:55:46 -1000
2014-04-08 19:21:49 -1000
2014-04-08 20:21:49 -1000
2014-04-08 21:21:49 -1000
2014-04-09 17:30:38 -1000
2014-04-09 18:30:38 -1000
2014-04-09 20:07:09 -1000
2014-04-09 21:07:08 -1000
2014-04-10 06:59:49 -1000
2014-04-10 19:16:52 -1000
2014-04-10 20:16:52 -1000
2014-04-10 21:16:52 -1000
2014-04-11 14:57:04 -1000
2014-04-11 15:57:04 -1000
2014-04-11 16:57:04 -1000
2014-04-11 17:57:03 -1000
2014-04-11 18:57:03 -1000
2014-04-12 08:53:54 -1000
2014-04-12 15:55:55 -1000
2014-04-12 16:55:55 -1000
2014-04-12 18:09:42 -1000
2014-04-12 19:09:42 -1000
2014-04-12 22:29:35 -1000
2014-04-12 23:29:35 -1000
2014-04-13 07:39:52 -1000
2014-04-13 08:39:52 -1000
2014-04-13 09:39:52 -1000
2014-04-13 11:00:15 -1000
2014-04-13 12:00:15 -1000
2014-04-13 13:15:09 -1000
2014-04-13 14:46:25 -1000
2014-04-13 15:46:25 -1000
2014-04-13 17:09:20 -1000
2014-04-13 18:09:21 -1000
2014-04-13 19:33:45 -1000
2014-04-13 20:33:45 -1000
2014-04-13 21:33:45 -1000
2014-04-14 17:26:32 -1000
2014-04-14 18:53:19 -1000
2014-04-14 19:53:18 -1000
2014-04-14 20:47:57 -1000 IM: ---------- log start ----------
2014-04-14 20:47:57 -1000 IM: 1387
2014-04-14 20:48:01 -1000 IM: ---------- log end ----------
2014-04-14 20:53:18 -1000
2014-04-15 14:03:04 -1000
2014-04-15 15:03:04 -1000
2014-04-15 16:03:06 -1000
2014-04-15 17:03:04 -1000
2014-04-15 18:03:03 -1000
2014-04-15 19:36:48 -1000
2014-04-16 05:48:35 -1000
2014-04-16 17:51:41 -1000
2014-04-16 18:51:40 -1000
2014-04-16 19:51:40 -1000
2014-04-16 20:51:39 -1000
2014-04-16 21:51:39 -1000
2014-04-16 22:51:39 -1000
2014-04-16 23:51:39 -1000
2014-04-17 00:51:39 -1000
2014-04-17 01:51:36 -1000
2014-04-17 02:51:36 -1000
2014-04-17 03:51:36 -1000
2014-04-17 04:51:37 -1000
2014-04-17 05:51:35 -1000
2014-04-17 19:04:19 -1000
2014-04-17 20:04:19 -1000
2014-04-17 21:04:18 -1000
2014-04-17 22:04:18 -1000
2014-04-17 23:04:17 -1000
2014-04-18 00:04:17 -1000
2014-04-18 01:04:17 -1000
2014-04-18 02:04:17 -1000
2014-04-18 03:04:17 -1000
2014-04-18 04:04:17 -1000
2014-04-18 05:04:16 -1000
2014-04-18 06:04:16 -1000
2014-04-18 14:10:39 -1000
2014-04-18 15:10:38 -1000
2014-04-18 16:10:38 -1000
2014-04-18 17:10:38 -1000
2014-04-18 18:10:38 -1000
2014-04-18 19:10:38 -1000
2014-04-18 20:10:38 -1000
2014-04-18 21:10:37 -1000
2014-04-19 05:41:40 -1000
2014-04-19 06:41:40 -1000
2014-04-19 07:41:39 -1000
2014-04-19 08:41:39 -1000
2014-04-19 09:41:39 -1000
2014-04-19 10:41:39 -1000
2014-04-19 11:41:39 -1000
2014-04-19 17:27:57 -1000
2014-04-19 18:51:22 -1000
2014-04-19 19:51:21 -1000
2014-04-19 20:51:21 -1000
2014-04-19 21:51:21 -1000
2014-04-19 22:51:21 -1000
2014-04-19 23:51:21 -1000
2014-04-20 00:51:21 -1000
2014-04-20 07:00:13 -1000
2014-04-20 08:00:13 -1000
2014-04-20 09:40:31 -1000
2014-04-20 11:34:49 -1000
2014-04-20 12:34:48 -1000
2014-04-20 13:34:48 -1000
2014-04-20 14:34:48 -1000
2014-04-20 15:35:01 -1000 IM: ---------- log start ----------
2014-04-20 15:35:01 -1000 IM: All install checks pass
2014-04-20 15:35:01 -1000 IM: [install started]
2014-04-20 15:35:04 -1000 FIN: [finalizer started]
2014-04-20 15:35:04 -1000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-20 15:35:04 -1000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-20 15:35:05 -1000
2014-04-20 15:35:06 -1000
2014-04-20 15:35:08 -1000 IM: [install succeeded]
2014-04-20 15:35:08 -1000 IM: ---------- log end ----------
2014-04-21 17:09:21 -1000
2014-04-21 18:09:19 -1000
2014-04-21 19:09:19 -1000
2014-04-21 20:09:18 -1000
2014-04-21 21:09:18 -1000
2014-04-21 22:09:18 -1000
2014-04-21 22:23:16 -1000 IM: ---------- log start ----------
2014-04-21 22:23:17 -1000 IM: 1387
2014-04-21 22:46:31 -1000 IM: ---------- log end ----------
2014-04-23 17:31:10 -1000
2014-04-23 20:23:18 -1000
2014-04-24 12:14:16 -1000
2014-04-24 15:13:58 -1000
2014-04-24 17:46:40 -1000
2014-04-24 19:05:55 -1000
2014-04-24 20:05:55 -1000
2014-04-24 21:05:55 -1000
2014-04-25 11:40:56 -1000
2014-04-25 12:40:56 -1000
2014-04-25 16:32:41 -1000
2014-04-25 17:32:40 -1000
2014-04-25 18:32:40 -1000
2014-04-25 19:32:40 -1000
2014-04-25 20:32:40 -1000
2014-04-25 21:32:40 -1000
2014-04-25 22:32:40 -1000
2014-04-25 23:32:40 -1000
2014-04-26 00:32:38 -1000
2014-04-26 08:10:06 -1000
2014-04-26 09:10:05 -1000
2014-04-26 10:10:05 -1000
2014-04-26 11:10:05 -1000
2014-04-26 12:17:34 -1000
2014-04-26 14:46:00 -1000
2014-04-26 15:46:00 -1000
2014-04-26 16:46:00 -1000
2014-04-26 17:46:00 -1000
2014-04-26 19:56:26 -1000
2014-04-26 21:26:25 -1000
2014-04-27 07:35:26 -1000
2014-04-27 08:35:26 -1000
2014-04-27 14:26:42 -1000
2014-04-27 15:52:39 -1000
2014-04-27 17:44:11 -1000
2014-04-27 19:17:05 -1000
2014-04-28 12:49:03 -1000
2014-04-28 14:15:46 -1000
2014-04-28 19:05:11 -1000
2014-04-28 20:05:11 -1000
2014-04-28 21:05:11 -1000
2014-04-28 22:05:11 -1000
2014-04-28 22:23:50 -1000 IM: ---------- log start ----------
2014-04-28 22:23:51 -1000 IM: 1387
2014-04-28 22:24:03 -1000 IM: 15715106
2014-04-28 22:24:08 -1000 IM: ---------- log end ----------
2014-04-28 22:24:14 -1000 IM: ---------- log start ----------
2014-04-28 22:24:14 -1000 IM: All install checks pass
2014-04-28 22:24:32 -1000
2014-04-29 05:27:44 -1000
2014-04-29 16:45:10 -1000
2014-04-29 17:45:10 -1000
2014-04-29 18:45:10 -1000
2014-04-29 19:45:08 -1000
2014-04-29 20:45:08 -1000
2014-04-29 21:45:18 -1000 IM: ---------- log start ----------
2014-04-29 21:45:18 -1000 IM: All install checks pass
2014-04-29 21:45:18 -1000 IM: [install started]
2014-04-29 21:45:21 -1000 FIN: [finalizer started]
2014-04-29 21:45:21 -1000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-04-29 21:45:21 -1000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-04-29 21:45:22 -1000
2014-04-29 21:45:25 -1000 IM: [install succeeded]
2014-04-29 21:45:25 -1000 IM: ---------- log end ----------
2014-04-29 22:56:41 -1000 IM: ---------- log end ----------
2014-05-01 16:55:41 -1000
2014-05-02 16:27:40 -1000
2014-05-02 17:30:32 -1000
2014-05-02 23:21:59 -1000
2014-05-03 00:21:59 -1000
2014-05-03 01:21:58 -1000
2014-05-03 08:28:02 -1000
2014-05-03 09:28:01 -1000
2014-05-03 10:28:54 -1000
2014-05-03 11:28:54 -1000
2014-05-03 12:28:54 -1000
2014-05-03 16:43:20 -1000
2014-05-03 17:43:20 -1000
2014-05-03 18:43:20 -1000
2014-05-03 19:43:19 -1000
2014-05-03 22:36:17 -1000
2014-05-05 15:39:46 -1000
2014-05-05 16:39:46 -1000
2014-05-05 17:39:46 -1000
2014-05-05 18:39:46 -1000
2014-05-05 19:39:45 -1000
2014-05-05 20:39:46 -1000
2014-05-05 21:39:45 -1000
2014-05-06 15:59:19 -1000
2014-05-06 16:59:07 -1000
2014-05-06 17:59:06 -1000
2014-05-06 18:59:07 -1000
2014-05-06 19:59:06 -1000
2014-05-06 20:59:06 -1000
2014-05-07 07:12:22 -1000
2014-05-07 11:28:42 -1000
2014-05-07 12:38:25 -1000
2014-05-07 13:38:25 -1000
2014-05-07 14:38:25 -1000
2014-05-07 15:38:24 -1000
2014-05-07 16:42:13 -1000
2014-05-07 17:42:13 -1000
2014-05-07 18:42:13 -1000
2014-05-07 20:26:03 -1000
2014-05-07 21:26:03 -1000
2014-05-08 16:00:03 -1000
2014-05-08 17:00:00 -1000
2014-05-08 17:59:59 -1000
2014-05-08 19:00:00 -1000
2014-05-08 19:59:59 -1000
2014-05-08 20:59:59 -1000
2014-05-08 21:59:59 -1000
2014-05-09 10:25:58 -1000
2014-05-09 16:02:17 -1000
2014-05-09 17:02:17 -1000
2014-05-09 18:34:47 -1000
2014-05-09 19:34:47 -1000
2014-05-09 20:34:47 -1000
2014-05-09 21:34:46 -1000
2014-05-09 22:34:46 -1000
2014-05-10 15:12:28 -1000
2014-05-10 16:34:09 -1000
2014-05-10 17:34:10 -1000
2014-05-10 18:34:09 -1000
2014-05-10 19:34:09 -1000
2014-05-10 22:13:34 -1000
2014-05-10 23:13:34 -1000
2014-05-11 00:13:34 -1000
2014-05-11 07:17:16 -1000
2014-05-11 08:27:41 -1000
2014-05-11 09:27:41 -1000
2014-05-11 10:27:42 -1000
2014-05-11 11:27:40 -1000
2014-05-11 12:27:40 -1000
2014-05-11 13:27:40 -1000
2014-05-11 14:53:53 -1000
2014-05-11 15:53:53 -1000
2014-05-11 16:53:53 -1000
2014-05-11 17:53:53 -1000
2014-05-11 18:53:52 -1000
2014-05-12 10:11:13 -1000
2014-05-12 15:29:50 -1000
2014-05-12 16:29:49 -1000
2014-05-12 17:29:48 -1000
2014-05-12 18:29:48 -1000
2014-05-13 16:35:19 -1000 IM: ---------- log start ----------
2014-05-13 16:35:20 -1000 IM: 1387
2014-05-13 16:35:29 -1000 IM: 15723551
2014-05-13 16:35:33 -1000 IM: ---------- log end ----------
2014-05-13 16:35:37 -1000 IM: ---------- log start ----------
2014-05-13 16:35:37 -1000 IM: All install checks pass
2014-05-13 16:35:50 -1000
2014-05-13 22:20:32 -1000
2014-05-14 19:21:06 -1000
2014-05-14 20:34:35 -1000
2014-05-15 20:09:37 -1000
2014-05-16 09:24:22 -1000
2014-05-16 17:03:36 -1000
2014-05-16 19:31:31 -1000
2014-05-16 20:47:46 -1000
2014-05-17 06:53:41 -1000 IM: ---------- log end ----------
2014-05-17 14:28:18 -1000
2014-05-17 15:28:18 -1000
2014-05-17 21:10:48 -1000
2014-05-18 09:39:52 -1000
2014-05-18 19:48:58 -1000
2014-05-18 20:48:58 -1000
2014-05-18 21:48:58 -1000
2014-05-18 22:48:58 -1000
2014-05-18 23:48:58 -1000
2014-05-19 00:48:58 -1000
2014-05-19 01:48:58 -1000
2014-05-19 02:48:58 -1000
2014-05-19 03:48:58 -1000
2014-05-19 08:55:56 -1000
2014-05-19 18:05:27 -1000
2014-05-19 19:05:26 -1000
2014-05-19 21:19:08 -1000
2014-05-20 20:38:44 -1000 IM: ---------- log start ----------
2014-05-20 20:38:44 -1000 IM: 1387
2014-05-20 21:22:18 -1000 IM: 15723551
2014-05-20 21:22:22 -1000 IM: ---------- log end ----------
2014-05-20 21:54:05 -1000
2014-05-21 17:41:30 -1000
2014-05-21 19:19:53 -1000
2014-05-21 20:22:25 -1000
2014-05-21 21:22:25 -1000
2014-05-23 07:15:05 -1000
2014-05-23 08:29:49 -1000
2014-05-23 14:42:56 -1000
2014-05-24 09:41:57 -1000
2014-05-24 10:41:54 -1000
2014-05-24 18:04:26 -1000
2014-05-24 19:10:59 -1000
2014-05-24 20:54:45 -1000
2014-05-24 21:54:45 -1000
2014-05-25 08:20:23 -1000
2014-05-25 10:29:22 -1000
2014-05-25 11:29:22 -1000
2014-05-25 14:58:08 -1000
2014-05-25 17:12:26 -1000
2014-05-25 18:49:09 -1000
2014-05-25 19:49:09 -1000
2014-05-26 12:02:22 -1000
2014-05-26 14:41:25 -1000
2014-05-26 15:41:25 -1000
2014-05-26 16:41:25 -1000
2014-05-26 17:43:33 -1000
2014-05-26 20:37:51 -1000
2014-05-26 21:43:15 -1000
2014-05-26 22:52:04 -1000
2014-05-26 23:52:04 -1000
2014-05-27 11:14:11 -1000
2014-05-27 13:40:34 -1000
2014-05-27 14:40:34 -1000
2014-05-27 16:15:13 -1000
2014-05-27 18:25:17 -1000
2014-05-27 23:33:02 -1000 IM: ---------- log start ----------
2014-05-27 23:33:02 -1000 IM: 1387
2014-05-27 23:33:03 -1000 IM: 1387
2014-05-28 00:31:44 -1000
2014-05-29 11:12:26 -1000 IM: 15723551
2014-05-29 11:12:30 -1000 IM: ---------- log end ----------
2014-05-29 11:12:36 -1000 IM: ---------- log start ----------
2014-05-29 11:12:36 -1000 IM: All install checks pass
2014-05-29 11:12:48 -1000
2014-05-29 11:13:00 -1000 IM: [install started]
2014-05-29 11:13:03 -1000 FIN: [finalizer started]
2014-05-29 11:13:03 -1000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-05-29 11:13:03 -1000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-05-29 11:13:05 -1000 FIN: [finalizer succeeded]
2014-05-29 11:13:07 -1000 IM: [install completed]
2014-05-29 11:13:07 -1000 IM: [install succeeded]
2014-05-29 11:13:09 -1000 IM: ---------- log end ----------
2014-05-29 20:35:50 -1000
2014-05-30 20:35:04 -1000
2014-05-31 20:53:18 -1000
2014-06-01 13:34:19 -1000
2014-06-01 15:04:02 -1000
2014-06-02 08:53:05 -1000
2014-06-02 09:53:04 -1000
2014-06-03 08:14:47 -1000
2014-06-03 10:22:14 -1000
2014-06-03 11:22:14 -1000
2014-06-03 13:17:22 -1000
2014-06-03 14:17:22 -1000
2014-06-03 15:20:58 -1000
2014-06-03 16:20:57 -1000
2014-06-03 17:30:12 -1000
2014-06-03 19:39:09 -1000
2014-06-03 22:27:17 -1000
2014-06-03 23:27:17 -1000
2014-06-04 08:06:04 -1000
2014-06-04 09:06:04 -1000
2014-06-04 10:06:04 -1000
2014-06-04 11:06:03 -1000
2014-06-04 12:06:03 -1000
2014-06-04 19:55:06 -1000
2014-06-04 22:28:51 -1000
2014-06-04 23:28:51 -1000
2014-06-05 00:28:51 -1000
2014-06-05 01:58:41 -1000
2014-06-05 08:03:58 -1000
2014-06-05 09:03:58 -1000
2014-06-05 10:17:35 -1000
2014-06-05 12:26:52 -1000
2014-06-05 13:26:52 -1000
2014-06-05 14:26:52 -1000
2014-06-05 15:26:52 -1000
2014-06-05 16:26:52 -1000
2014-06-06 21:38:28 -1000
2014-06-06 22:38:28 -1000
2014-06-07 07:15:18 -1000
2014-06-07 11:32:49 -1000
2014-06-07 12:32:49 -1000
2014-06-07 16:49:31 -1000
2014-06-07 17:49:31 -1000
2014-06-07 18:49:31 -1000
2014-06-07 19:49:31 -1000
2014-06-07 20:49:31 -1000
2014-06-07 21:49:31 -1000
2014-06-07 22:49:31 -1000
2014-06-07 23:49:30 -1000
2014-06-08 00:49:30 -1000
2014-06-08 07:25:21 -1000
2014-06-08 08:25:21 -1000
2014-06-08 15:01:45 -1000
2014-06-08 16:01:44 -1000
2014-06-08 17:18:32 -1000
2014-06-08 18:18:32 -1000
2014-06-08 19:18:32 -1000
2014-06-08 20:18:31 -1000
2014-06-08 21:18:32 -1000
2014-06-08 22:18:31 -1000
2014-06-09 05:48:40 -1000
2014-06-09 16:45:48 -1000
2014-06-09 19:06:34 -1000
2014-06-09 20:18:49 -1000
2014-06-09 21:18:49 -1000
2014-06-10 16:27:01 -1000
2014-06-10 17:27:01 -1000
2014-06-10 18:47:12 -1000
2014-06-10 19:47:10 -1000
2014-06-11 00:30:23 -1000
2014-06-11 17:15:20 -1000 IM: ---------- log start ----------
2014-06-11 17:15:20 -1000 IM: 1387
2014-06-11 17:15:21 -1000 IM: 1387
2014-06-11 17:53:46 -1000
2014-06-11 18:53:46 -1000
2014-06-11 20:56:34 -1000
2014-06-11 21:56:34 -1000
2014-06-11 22:07:23 -1000 IM: ---------- log end ----------
2014-06-12 19:13:07 -1000
2014-06-12 20:13:07 -1000
2014-06-12 21:13:07 -1000
2014-06-12 22:13:07 -1000
2014-06-12 23:13:07 -1000
2014-06-13 03:05:15 -1000
2014-06-13 05:16:05 -1000
2014-06-13 19:38:55 -1000
2014-06-13 20:38:55 -1000
2014-06-13 21:38:55 -1000
2014-06-14 07:26:39 -1000
2014-06-14 08:26:39 -1000
2014-06-14 09:26:38 -1000
2014-06-14 17:54:59 -1000
2014-06-14 18:54:58 -1000
2014-06-14 19:54:58 -1000
2014-06-14 20:54:58 -1000
2014-06-14 21:54:58 -1000
2014-06-14 22:54:58 -1000
2014-06-14 23:54:58 -1000
2014-06-15 00:54:58 -1000
2014-06-15 01:54:57 -1000
2014-06-15 02:54:57 -1000
2014-06-15 03:54:57 -1000
2014-06-15 04:54:58 -1000
2014-06-15 05:54:57 -1000
2014-06-15 06:54:57 -1000
2014-06-15 07:54:57 -1000
2014-06-15 13:26:50 -1000
2014-06-15 17:16:06 -1000
2014-06-15 20:11:08 -1000
2014-06-15 21:11:08 -1000
2014-06-16 16:30:14 -1000
2014-06-16 17:30:13 -1000
2014-06-16 19:06:58 -1000
2014-06-16 20:06:57 -1000
2014-06-16 21:06:57 -1000
2014-06-16 22:06:57 -1000
2014-06-17 16:42:50 -1000
2014-06-17 17:42:50 -1000
2014-06-17 18:52:45 -1000
2014-06-17 19:52:45 -1000
2014-06-17 20:53:15 -1000
2014-06-17 21:52:47 -1000
2014-06-17 22:52:46 -1000
2014-06-17 23:52:47 -1000
2014-06-18 00:52:46 -1000
2014-06-18 01:52:46 -1000
2014-06-18 02:52:46 -1000
2014-06-18 03:52:46 -1000
2014-06-18 04:52:46 -1000
2014-06-18 05:52:45 -1000
2014-06-18 14:58:38 -1000
2014-06-19 17:05:38 -1000
2014-06-19 17:56:58 -1000 IM: ---------- log start ----------
2014-06-19 17:56:58 -1000 IM: 1387
2014-06-19 18:05:35 -1000
2014-06-19 20:24:17 -1000
2014-06-19 21:24:16 -1000
2014-06-20 16:18:26 -1000 IM: ---------- log end ----------
2014-06-20 18:11:51 -1000
2014-06-20 19:11:50 -1000
2014-06-20 20:11:51 -1000
2014-06-20 21:11:51 -1000
2014-06-21 05:36:55 -1000
2014-06-21 06:36:54 -1000
2014-06-21 07:36:53 -1000
2014-06-21 18:08:14 -1000
2014-06-21 19:08:13 -1000
2014-06-21 20:08:13 -1000
2014-06-21 21:08:13 -1000
2014-06-21 22:08:13 -1000
2014-06-21 23:08:13 -1000
2014-06-22 07:54:37 -1000
2014-06-22 08:54:37 -1000
2014-06-22 09:54:36 -1000
2014-06-22 10:54:36 -1000
2014-06-22 11:54:37 -1000
2014-06-22 12:54:36 -1000
2014-06-22 13:54:36 -1000
2014-06-22 14:54:37 -1000
2014-06-22 15:54:37 -1000
2014-06-22 16:54:36 -1000
2014-06-22 17:54:36 -1000
2014-06-22 18:54:36 -1000
2014-06-22 19:54:37 -1000
2014-06-22 20:54:37 -1000
2014-06-22 21:54:36 -1000
2014-06-22 22:54:36 -1000
2014-06-23 13:11:14 -1000
2014-06-23 14:11:14 -1000
2014-06-23 15:11:14 -1000
2014-06-23 16:11:13 -1000
2014-06-23 17:11:13 -1000
2014-06-23 18:11:14 -1000
2014-06-23 19:11:13 -1000
2014-06-23 20:57:04 -1000
2014-06-23 21:57:05 -1000
2014-06-24 14:57:11 -1000
2014-06-24 15:57:10 -1000
2014-06-24 16:57:10 -1000
2014-06-24 17:57:09 -1000
2014-06-24 18:57:09 -1000
2014-06-24 20:17:01 -1000
2014-06-24 21:17:01 -1000
2014-06-24 22:17:02 -1000
2014-06-25 16:34:51 -1000
2014-06-25 18:19:12 -1000
2014-06-25 19:19:12 -1000
2014-06-25 20:19:12 -1000
2014-06-25 21:19:12 -1000
2014-06-26 05:18:01 -1000
2014-06-26 06:18:01 -1000
2014-06-26 07:18:00 -1000
2014-06-26 08:18:00 -1000
2014-06-26 09:18:00 -1000
2014-06-26 10:18:00 -1000
2014-06-26 11:18:01 -1000
2014-06-26 12:39:17 -1000
2014-06-26 13:39:18 -1000
2014-06-26 14:39:17 -1000
2014-06-26 20:56:56 -1000
2014-06-26 21:56:56 -1000
2014-06-26 22:26:57 -1000 IM: ---------- log start ----------
2014-06-26 22:26:57 -1000 IM: 1387
2014-06-26 22:27:03 -1000 IM: ---------- log end ----------
2014-06-26 22:30:59 -1000 IM: ---------- log start ----------
2014-06-26 22:30:59 -1000 IM: All install checks pass
2014-06-26 22:31:43 -1000
2014-06-26 22:31:43 -1000 IM: ---------- log end ----------
2014-06-26 22:32:27 -1000 IM: ---------- log start ----------
2014-06-26 22:32:27 -1000 IM: All install checks pass
2014-06-26 22:32:57 -1000 IM: User does not have any processes that need to be closed.
2014-06-26 22:32:57 -1000 IM: [install started]
2014-06-26 22:33:01 -1000 FIN: [finalizer started]
2014-06-26 22:33:01 -1000 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-06-26 22:33:01 -1000 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-06-26 22:33:03 -1000 FIN: [finalizer succeeded]
2014-06-26 22:33:09 -1000 IM: [install succeeded]
2014-06-26 22:33:09 -1000 IM: ---------- log end ----------
2014-06-26 22:56:56 -1000
2014-06-27 00:26:39 -1000
2014-06-27 01:26:39 -1000
2014-06-27 02:26:39 -1000
2014-06-27 03:26:39 -1000
2014-06-27 04:26:39 -1000
2014-06-27 05:26:39 -1000
2014-06-28 08:03:24 -1000
2014-06-28 09:03:23 -1000
2014-06-28 10:03:24 -1000
2014-06-29 13:11:58 -1000
2014-06-29 14:11:57 -1000
2014-06-29 15:11:52 -1000
2014-06-29 16:11:52 -1000
2014-06-29 17:11:52 -1000
2014-06-29 20:46:46 -1000
2014-07-01 18:44:14 -1000
2014-07-02 22:55:26 +0300
2014-07-03 21:24:52 +0300
2014-07-03 23:13:05 +0300
2014-07-04 23:33:04 +0300
2014-07-05 22:38:12 +0300
2014-07-07 21:47:00 +0300
2014-07-07 22:47:00 +0300
2014-07-08 07:24:59 +0300
2014-07-08 09:24:44 +0300
2014-07-08 10:24:45 +0300
2014-07-08 11:24:45 +0300
2014-07-08 12:24:45 +0300
2014-07-08 13:24:45 +0300
2014-07-08 14:24:45 +0300
2014-07-08 15:24:45 +0300
2014-07-08 16:24:44 +0300
2014-07-08 17:24:44 +0300
2014-07-08 18:24:44 +0300
2014-07-08 19:24:44 +0300
2014-07-08 20:24:43 +0300
2014-07-08 21:24:44 +0300
2014-07-08 22:24:43 +0300
2014-07-09 22:01:11 +0300
2014-07-09 23:01:11 +0300
2014-07-10 22:50:27 +0300
2014-07-11 22:06:10 +0300
2014-07-12 14:23:31 +0300
2014-07-12 16:40:08 +0300
2014-07-12 18:48:48 +0300
2014-07-12 20:51:17 +0300
2014-07-12 21:52:42 +0300 IM: ---------- log start ----------
2014-07-12 21:52:43 +0300 IM: 1387
2014-07-12 22:02:51 +0300
2014-07-12 23:02:51 +0300
2014-07-13 00:13:33 +0300
2014-07-13 21:46:52 +0300 IM: 16326619
2014-07-13 21:47:07 +0300 IM: ---------- log end ----------
2014-07-13 21:47:13 +0300 IM: ---------- log start ----------
2014-07-13 21:47:13 +0300 IM: All install checks pass
2014-07-13 21:47:29 +0300
2014-07-13 21:47:53 +0300 IM: [install started]
2014-07-13 21:47:56 +0300 FIN: [finalizer started]
2014-07-13 21:47:56 +0300 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-07-13 21:47:56 +0300 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-07-13 21:47:58 +0300 FIN: [finalizer succeeded]
2014-07-13 21:48:00 +0300 IM: [install completed]
2014-07-13 21:48:00 +0300 IM: [install succeeded]
2014-07-13 21:48:05 +0300 IM: ---------- log end ----------
2014-07-13 22:15:09 +0300
2014-07-14 22:18:28 +0300
2014-07-14 23:18:28 +0300
2014-07-15 21:56:52 +0300
2014-07-16 21:07:05 +0300
2014-07-16 22:07:04 +0300
2014-07-16 23:07:04 +0300
2014-07-17 00:07:04 +0300
2014-07-17 01:37:46 +0300
2014-07-17 02:37:46 +0300
2014-07-17 03:37:46 +0300
2014-07-17 04:37:46 +0300
2014-07-17 05:37:46 +0300
2014-07-17 06:37:46 +0300
2014-07-17 07:37:46 +0300
2014-07-17 08:37:37 +0300
2014-07-17 09:37:37 +0300
2014-07-17 10:37:37 +0300
2014-07-17 11:37:37 +0300
2014-07-17 12:37:37 +0300
2014-07-17 13:37:36 +0300
2014-07-17 17:07:10 +0300
2014-07-17 19:07:02 +0300
2014-07-17 20:07:02 +0300
2014-07-17 21:07:02 +0300
2014-07-17 22:07:02 +0300
2014-07-17 23:07:02 +0300
2014-07-18 21:55:39 +0300
2014-07-21 22:51:48 +0300
2014-07-22 22:40:43 +0300
2014-07-23 22:23:42 +0300
2014-07-23 23:23:42 +0300
2014-07-24 15:45:08 +0300
2014-07-24 16:45:08 +0300
2014-07-24 17:45:08 +0300
2014-07-24 22:54:39 +0300
2014-07-24 23:54:39 +0300
2014-07-25 07:51:02 +0300
2014-07-25 22:32:09 +0300
2014-07-26 08:09:37 +0300
2014-07-26 09:09:37 +0300
2014-07-26 10:09:36 +0300
2014-07-26 11:09:35 +0300
2014-07-26 12:09:35 +0300
2014-07-26 13:09:35 +0300
2014-07-26 14:09:35 +0300
2014-07-26 15:09:35 +0300
2014-07-26 16:09:35 +0300
2014-07-26 17:09:35 +0300
2014-07-26 18:09:34 +0300
2014-07-26 19:09:34 +0300
2014-07-26 20:09:34 +0300
2014-07-26 21:09:34 +0300
2014-07-26 22:09:34 +0300
2014-07-26 23:09:34 +0300
2014-07-27 00:09:34 +0300
2014-07-27 01:09:33 +0300
2014-07-27 02:09:33 +0300
2014-07-27 03:09:33 +0300
2014-07-27 04:09:33 +0300
2014-07-27 05:09:33 +0300
2014-07-27 06:09:33 +0300
2014-07-27 07:09:33 +0300
2014-07-27 08:09:33 +0300
2014-07-27 09:09:32 +0300
2014-07-27 10:09:32 +0300
2014-07-27 11:09:32 +0300
2014-07-27 12:09:32 +0300
2014-07-27 13:09:32 +0300
2014-07-27 14:09:33 +0300
2014-07-27 15:09:32 +0300
2014-07-27 16:09:32 +0300
2014-07-27 17:09:31 +0300
2014-07-27 18:09:31 +0300
2014-07-27 19:09:31 +0300
2014-07-27 20:09:31 +0300
2014-07-27 21:09:31 +0300
2014-07-27 22:09:31 +0300
2014-07-27 23:09:31 +0300
2014-07-28 21:36:34 +0300
2014-07-28 22:36:33 +0300
2014-07-30 00:05:23 +0300
2014-07-30 23:13:04 +0300
2014-07-31 09:43:16 +0300
2014-07-31 10:43:16 +0300
2014-07-31 11:43:16 +0300
2014-07-31 12:43:16 +0300
2014-07-31 13:43:15 +0300
2014-07-31 14:43:15 +0300
2014-07-31 15:43:15 +0300
2014-07-31 16:43:15 +0300
2014-07-31 17:43:15 +0300
2014-07-31 18:43:14 +0300
2014-07-31 19:43:14 +0300
2014-07-31 20:43:14 +0300
2014-07-31 21:43:14 +0300
2014-07-31 22:43:14 +0300
2014-08-01 21:52:06 +0300
2014-08-02 22:08:28 +0300
2014-08-03 21:46:32 +0300
2014-08-03 22:46:28 +0300
2014-08-04 13:05:32 +0300
2014-08-04 22:19:58 +0300
2014-08-04 23:19:57 +0300
2014-08-05 22:07:24 +0300
2014-08-06 22:23:21 +0300
2014-08-06 23:24:13 +0300
2014-08-07 22:20:49 +0300
2014-08-07 23:20:49 +0300
2014-08-08 22:30:37 +0300
2014-08-08 23:30:38 +0300
2014-08-09 22:30:48 +0300
2014-08-09 23:30:49 +0300
2014-08-10 22:07:12 +0300
2014-08-10 23:07:12 +0300
2014-08-12 14:51:36 +0300
2014-08-12 15:51:25 +0300
2014-08-12 17:33:22 +0300
2014-08-12 18:33:21 +0300
2014-08-12 21:09:18 +0300
2014-08-13 22:13:39 +0300
2014-08-13 23:13:39 +0300
2014-08-14 22:19:59 +0300
2014-08-14 23:19:59 +0300
2014-08-15 22:28:12 +0300
2014-08-15 23:30:15 +0300
2014-08-16 22:37:58 +0300
2014-08-16 23:00:14 +0300 IM: ---------- log start ----------
2014-08-16 23:00:14 +0300 IM: 1407
2014-08-16 23:00:15 +0300 IM: 1407
2014-08-16 23:37:58 +0300
2014-08-17 22:26:53 +0300
2014-08-18 22:06:21 +0300
2014-08-18 23:06:18 +0300
2014-08-19 22:11:03 +0300
2014-08-19 23:11:03 +0300
2014-08-20 22:10:46 +0300
2014-08-20 23:10:46 +0300
2014-08-21 01:41:18 +0300
2014-08-21 04:40:58 +0300
2014-08-21 07:40:45 +0300
2014-08-21 11:40:37 +0300 IM: ---------- log end ----------
2014-08-21 11:46:19 +0300
2014-08-21 21:06:06 +0300
2014-08-21 22:06:06 +0300
2014-08-21 23:06:06 +0300
2014-08-22 22:43:09 +0300
2014-08-23 20:43:28 +0300
2014-08-23 22:29:30 +0300
2014-08-23 23:29:30 +0300
2014-08-24 00:29:30 +0300
2014-08-25 18:27:30 +0300
2014-08-25 19:27:29 +0300
2014-08-25 21:14:04 +0300
2014-08-25 22:14:03 +0300
2014-08-25 23:14:03 +0300
2014-08-26 21:16:02 +0300 IM: ---------- log end ----------
2014-08-26 22:46:55 +0300
2014-08-26 23:50:12 +0300
2014-08-27 22:47:45 +0300
2014-08-27 23:47:45 +0300
2014-08-28 13:11:36 +0300
2014-08-28 14:11:36 +0300
2014-08-28 15:21:24 +0300
2014-08-28 22:15:21 +0300
2014-08-28 23:15:21 +0300
2014-08-29 21:25:05 +0300
2014-08-29 23:03:04 +0300
2014-08-30 22:40:54 +0300
2014-08-30 23:04:24 +0300 IM: ---------- log start ----------
2014-08-30 23:04:25 +0300 IM: 1407
2014-08-31 12:17:59 +0300
2014-08-31 13:17:59 +0300
2014-08-31 14:17:59 +0300
2014-08-31 21:46:10 +0300
2014-08-31 22:09:11 +0300 IM: ---------- log end ----------
2014-08-31 22:46:09 +0300
2014-09-01 22:05:42 +0300
2014-09-01 23:05:42 +0300
2014-09-02 22:10:08 +0300
2014-09-02 23:10:08 +0300
2014-09-03 22:04:28 +0300
2014-09-03 23:04:28 +0300
2014-09-04 22:38:19 +0300
2014-09-05 11:33:06 +0300
2014-09-05 12:33:06 +0300
2014-09-05 22:18:29 +0300
2014-09-05 23:18:29 +0300
2014-09-06 21:40:28 +0300
2014-09-06 22:40:28 +0300
2014-09-06 23:05:00 +0300 IM: ---------- log start ----------
2014-09-06 23:05:01 +0300 IM: 1407
2014-09-06 23:05:02 +0300 IM: 1407
2014-09-07 10:45:23 +0300 IM: ---------- log end ----------
2014-09-07 11:46:46 +0300
2014-09-07 12:46:46 +0300
2014-09-07 13:46:46 +0300
2014-09-07 15:02:44 +0300
2014-09-07 21:22:32 +0300
2014-09-07 22:56:05 +0300
2014-09-08 10:08:04 +0300
2014-09-08 11:08:02 +0300
2014-09-08 12:08:02 +0300
2014-09-09 09:58:55 +0300
2014-09-09 10:58:56 +0300
2014-09-09 11:58:56 +0300
2014-09-09 12:58:55 +0300
2014-09-09 17:35:56 +0300
2014-09-09 18:35:55 +0300
2014-09-09 19:35:55 +0300
2014-09-09 20:35:55 +0300
2014-09-09 21:46:08 +0300
2014-09-09 22:46:08 +0300
2014-09-09 23:46:09 +0300
2014-09-10 06:31:00 +0200
2014-09-10 07:31:00 +0200
2014-09-10 13:14:43 +0200
2014-09-10 14:40:17 +0200
2014-09-10 15:40:17 +0200
2014-09-11 06:23:10 +0200
2014-09-11 07:23:10 +0200
2014-09-11 08:23:10 +0200
2014-09-11 09:23:10 +0200
2014-09-11 10:23:09 +0200
2014-09-11 11:23:09 +0200
2014-09-11 12:23:09 +0200
2014-09-11 13:23:09 +0200
2014-09-11 14:23:10 +0200
2014-09-11 15:23:09 +0200
2014-09-12 07:00:40 +0200
2014-09-12 13:02:33 +0200
2014-09-12 14:02:33 +0200
2014-09-12 15:02:33 +0200
2014-09-12 16:02:33 +0200
2014-09-13 06:44:10 +0200
2014-09-13 07:44:10 +0200
2014-09-14 05:56:38 +0200 IM: ---------- log start ----------
2014-09-14 05:56:38 +0200 IM: 1407
2014-09-14 05:59:23 +0200 IM: 15607108
2014-09-14 05:59:27 +0200 IM: ---------- log end ----------
2014-09-14 05:59:32 +0200 IM: ---------- log start ----------
2014-09-14 05:59:32 +0200 IM: All install checks pass
2014-09-14 05:59:43 +0200
2014-09-14 05:59:55 +0200 IM: [install started]
2014-09-14 05:59:58 +0200 FIN: [finalizer started]
2014-09-14 05:59:58 +0200 FIN: Compression Output Path: '/Library/Internet Plug-Ins/Flash Player.plugin'.
2014-09-14 05:59:58 +0200 FIN: Compression Input Path: '/Library/Internet Plug-Ins/Flash Player.plugin.lzma'.
2014-09-14 05:59:59 +0200 FIN: [finalizer succeeded]
2014-09-14 06:00:01 +0200 IM: [install completed]
2014-09-14 06:00:01 +0200 IM: [install succeeded]
2014-09-14 06:00:08 +0200 IM: ---------- log end ----------
2014-09-14 06:55:33 +0200
2014-09-14 07:55:31 +0200
2014-09-14 08:55:31 +0200
2014-09-14 17:40:41 +0200
2014-09-14 19:53:47 +0200
2014-09-14 20:53:47 +0200
2014-09-14 21:53:47 +0200
2014-09-14 22:53:46 +0200
2014-09-14 23:53:46 +0200
2014-09-15 00:53:46 +0200
2014-09-15 01:53:46 +0200
2014-09-15 02:53:46 +0200
2014-09-15 03:53:46 +0200
2014-09-15 04:53:45 +0200
2014-09-15 05:53:46 +0200
2014-09-15 15:28:09 +0200
2014-09-16 07:15:00 +0200
2014-09-16 08:15:00 +0200
2014-09-16 09:15:00 +0200
2014-09-17 06:24:55 +0200
2014-09-17 07:24:59 +0200
2014-09-17 08:24:59 +0200
2014-09-17 09:24:59 +0200
2014-09-17 10:24:59 +0200
2014-09-18 06:28:35 +0200
2014-09-18 07:28:35 +0200
2014-09-18 08:28:35 +0200
2014-09-19 03:27:10 +0200
2014-09-19 04:27:10 +0200
2014-09-19 05:27:10 +0200
2014-09-19 06:27:10 +0200
2014-09-19 07:27:10 +0200
2014-09-19 08:27:10 +0200
2014-09-19 09:27:09 +0200
2014-09-20 05:17:19 +0200
2014-09-20 06:32:52 +0200
2014-09-20 07:32:52 +0200
2014-09-20 08:32:52 +0200
2014-09-20 09:32:52 +0200
2014-09-20 10:32:52 +0200
2014-09-20 11:32:51 +0200
2014-09-20 16:03:25 +0200
2014-09-20 17:08:24 +0200
2014-09-20 18:08:24 +0200
2014-09-20 19:23:14 +0200
2014-09-20 20:23:14 +0200
2014-09-20 21:27:36 +0200
2014-09-20 22:27:36 +0200
2014-09-20 23:27:36 +0200
2014-09-21 00:28:35 +0200
2014-09-21 01:27:35 +0200
2014-09-21 02:27:35 +0200
2014-09-21 03:27:35 +0200
2014-09-21 04:27:35 +0200
2014-09-21 11:46:17 +0200
2014-09-21 12:46:17 +0200
2014-09-22 08:05:59 +0300
2014-09-23 05:37:38 +0300
2014-09-23 06:37:38 +0300
2014-09-23 16:33:31 +0300
2014-09-23 17:33:35 +0300
2014-09-23 23:25:41 +0300
2014-09-24 20:41:46 +0300
2014-09-24 21:41:47 +0300
2014-09-24 22:41:47 +0300
2014-09-24 23:41:46 +0300
2014-09-25 15:21:49 +0300
2014-09-25 16:21:48 +0300
2014-09-25 17:21:47 +0300
2014-09-25 18:21:47 +0300
2014-09-26 14:37:57 +0300
2014-09-26 15:37:57 +0300
2014-09-26 16:38:05 +0300
2014-09-26 17:38:00 +0300
2014-09-26 18:37:58 +0300
2014-09-26 19:37:56 +0300
2014-09-26 20:37:56 +0300
2014-09-26 21:37:56 +0300
2014-09-26 22:37:55 +0300
2014-09-26 23:37:55 +0300
2014-09-27 00:37:55 +0300
2014-09-27 01:37:55 +0300
2014-09-27 05:21:00 +0300
2014-09-27 06:21:00 +0300
2014-09-27 07:21:44 +0300
2014-09-27 08:21:00 +0300
2014-09-27 09:21:00 +0300
2014-09-27 10:42:43 +0300
2014-09-27 11:42:42 +0300
2014-09-27 12:42:43 +0300
2014-09-27 13:42:42 +0300
2014-09-27 14:42:47 +0300
2014-09-27 15:42:43 +0300
2014-09-28 13:06:43 +0300
2014-09-28 14:06:43 +0300
2014-09-28 15:06:43 +0300
2014-09-28 16:06:42 +0300
2014-09-28 17:06:42 +0300
2014-09-28 18:06:42 +0300
2014-09-28 19:06:46 +0300
2014-09-28 20:06:46 +0300
2014-09-28 21:06:40 +0300
2014-09-28 22:06:39 +0300
2014-09-29 05:33:03 +0300
2014-09-29 06:33:02 +0300
2014-09-29 21:58:37 +0300
2014-09-29 22:58:35 +0300
2014-09-30 22:07:59 +0300
2014-10-01 21:30:57 +0300
2014-10-01 22:30:55 +0300
2014-10-01 23:30:57 +0300
2014-10-02 00:30:52 +0300
2014-10-02 21:33:49 +0300
2014-10-02 22:33:48 +0300
2014-10-03 21:59:12 +0300
2014-10-04 19:54:30 +0300
2014-10-04 20:54:28 +0300
2014-10-04 21:54:27 +0300
2014-10-05 20:14:14 +0300
2014-10-05 21:14:12 +0300
2014-10-05 23:23:28 +0300
2014-10-06 14:26:43 +0300
2014-10-06 18:35:19 +0300
2014-10-06 20:05:47 +0300
2014-10-06 21:30:33 +0300
2014-10-06 22:30:31 +0300
2014-10-07 08:09:41 +0300
2014-10-08 13:34:40 +0300
2014-10-08 14:34:39 +0300
2014-10-08 15:34:37 +0300
2014-10-08 16:34:35 +0300
2014-10-08 17:34:33 +0300
2014-10-08 18:34:31 +0300
2014-10-08 19:34:30 +0300
2014-10-08 20:34:28 +0300
2014-10-09 19:40:48 +0200
2014-10-09 22:34:23 +0200
2014-10-10 07:14:05 +0200
2014-10-11 17:20:03 +0200
2014-10-11 22:18:54 +0200
2014-10-11 23:18:51 +0200
2014-10-12 00:18:49 +0200
2014-10-12 01:18:47 +0200
2014-10-12 10:40:40 +0200
2014-10-12 11:40:38 +0200
2014-10-12 12:41:36 +0200
2014-10-12 13:44:29 +0200
2014-10-12 15:20:13 +0200
2014-10-12 16:21:11 +0200
2014-10-12 17:21:22 +0200
2014-10-12 18:21:23 +0200
2014-10-12 20:22:22 +0200
2014-10-12 21:47:47 +0200
2014-10-13 22:45:10 +0200
2014-10-13 23:45:09 +0200
2014-10-14 00:45:06 +0200
2014-10-14 23:30:41 +0200
2014-10-15 21:20:26 +0200
2014-10-15 22:20:33 +0200
2014-10-16 19:27:53 +0200
2014-10-16 22:02:45 +0200
2014-10-16 23:03:46 +0200
2014-10-17 22:17:49 +0200
2014-10-17 23:17:58 +0200
2014-10-18 00:17:41 +0200
2014-10-19 00:58:18 +0200
2014-10-19 09:00:26 +0200
2014-10-19 10:00:25 +0200
2014-10-19 11:00:42 +0200
2014-10-19 12:00:25 +0200
2014-10-19 17:40:59 +0200
2014-10-19 21:18:26 +0200 IM: ---------- log start ----------
2014-10-19 21:18:26 +0200 IM: 1407
2014-10-19 22:06:58 +0200
2014-10-19 23:06:58 +0200
2014-10-20 00:07:57 +0200
2014-10-20 17:55:43 +0200
2014-10-20 18:47:54 +0200 IM: ---------- log end ----------
2014-10-20 22:30:27 +0200
2014-10-20 23:30:27 +0200
2014-10-21 00:30:26 +0200
2014-10-21 22:21:10 +0200
2014-10-21 23:21:08 +0200
2014-10-22 00:22:08 +0200
2014-10-22 13:49:17 +0200
2014-10-22 14:49:16 +0200
2014-10-22 22:36:13 +0200
2014-10-22 23:36:14 +0200
2014-10-23 16:44:38 +0200
2014-10-23 17:44:18 +0200
2014-10-23 21:54:18 +0200
2014-10-23 22:54:16 +0200
2014-10-24 10:59:39 +0200
2014-10-24 14:00:50 +0200
2014-10-24 15:29:33 +0200
2014-10-24 20:22:19 +0200
2014-10-24 21:22:17 +0200
2014-10-24 22:24:48 +0200
2014-10-25 09:24:16 +0200
2014-10-25 10:24:13 +0200
2014-10-25 11:24:12 +0200
2014-10-25 12:34:32 +0200
2014-10-25 15:25:34 +0200
2014-10-25 16:45:50 +0200
2014-10-27 21:52:51 +0100 IM: ---------- log start ----------
2014-10-27 21:52:52 +0100 IM: 1387
2014-10-27 21:58:54 +0100
2014-10-28 19:54:43 +0100 IM: ---------- log end ----------
2014-10-28 20:35:07 +0100
2014-10-28 22:12:18 +0100
2014-10-28 23:12:14 +0100
2014-10-29 16:08:59 +0100
2014-10-29 17:08:56 +0100
2014-10-29 18:08:56 +0100
2014-10-29 19:09:01 +0100
2014-10-30 11:13:35 +0100
2014-10-30 12:13:35 +0100
2014-10-30 13:13:35 +0100
2014-10-30 14:13:34 +0100
2014-10-30 15:13:35 +0100
2014-10-30 16:13:35 +0100
2014-10-30 17:13:36 +0100
2014-10-30 18:13:36 +0100
2014-10-30 19:13:37 +0100
2014-10-30 21:00:30 +0100
2014-10-30 22:00:34 +0100
2014-10-31 19:07:10 +0100
2014-10-31 20:07:10 +0100
2014-10-31 21:07:10 +0100
2014-10-31 22:07:07 +0100
2014-10-31 23:07:07 +0100
2014-11-01 03:13:15 +0100
2014-11-01 09:39:32 +0100
2014-11-01 10:39:32 +0100
2014-11-01 11:39:32 +0100
2014-11-02 00:37:40 +0100
2014-11-02 01:37:41 +0100
2014-11-02 10:40:06 +0100
2014-11-02 13:13:17 +0100
2014-11-02 14:13:17 +0100
2014-11-02 15:13:18 +0100
2014-11-02 16:13:18 +0100
2014-11-02 17:13:19 +0100
2014-11-02 18:13:19 +0100
2014-11-02 19:13:19 +0100
2014-11-02 20:13:20 +0100
2014-11-02 21:13:20 +0100
2014-11-02 22:13:21 +0100
2014-11-02 23:13:21 +0100
2014-11-03 00:13:21 +0100
2014-11-03 01:13:22 +0100
2014-11-04 00:03:54 +0100 IM: ---------- log start ----------
2014-11-04 00:03:54 +0100 IM: 1387
2014-11-04 00:03:55 +0100 IM: 1387
2014-11-04 00:20:47 +0100
2014-11-04 01:20:47 +0100
2014-11-04 02:20:47 +0100
2014-11-05 01:02:20 +0100
2014-11-05 02:02:20 +0100
2014-11-05 03:02:16 +0100
2014-11-05 10:47:53 +0100 IM: ---------- log start ----------
2014-11-05 10:47:53 +0100 IM: All install checks pass
2014-11-05 10:47:54 +0100
2014-11-05 10:47:54 +0100 IM: ---------- log end ----------
2014-11-06 00:03:27 +0100 IM: ---------- log start ----------
2014-11-06 00:03:27 +0100 IM: All install checks pass
2014-11-06 00:03:27 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:03:27 +0100 IM: [install started]
installer: Certificate used to sign package is not trusted. Use -allowUntrusted to override.
2014-11-06 00:03:29 +0100
2014-11-06 00:03:29 +0100 IM: ---------- log end ----------
2014-11-06 00:04:48 +0100 IM: ---------- log start ----------
2014-11-06 00:04:48 +0100 IM: All install checks pass
2014-11-06 00:04:48 +0100 IM: ---------- log end ----------
2014-11-06 00:04:56 +0100 IM: ---------- log start ----------
2014-11-06 00:04:56 +0100 IM: All install checks pass
2014-11-06 00:04:56 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:04:56 +0100 IM: [install started]
2014-11-06 00:04:57 +0100
2014-11-06 00:04:57 +0100 IM: ---------- log end ----------
2014-11-06 00:05:41 +0100 IM: ---------- log start ----------
2014-11-06 00:05:41 +0100 IM: All install checks pass
2014-11-06 00:05:41 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:05:41 +0100 IM: [install started]
2014-11-06 00:05:42 +0100
2014-11-06 00:05:42 +0100 IM: ---------- log end ----------
2014-11-06 00:07:43 +0100 IM: ---------- log start ----------
2014-11-06 00:07:43 +0100 IM: All install checks pass
2014-11-06 00:07:43 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:07:43 +0100 IM: [install started]
2014-11-06 00:07:44 +0100
2014-11-06 00:07:44 +0100 IM: ---------- log end ----------
2014-11-06 00:13:49 +0100 IM: ---------- log start ----------
2014-11-06 00:13:49 +0100 IM: All install checks pass
2014-11-06 00:13:49 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:13:49 +0100 IM: [install started]
2014-11-06 00:13:50 +0100
2014-11-06 00:13:50 +0100 IM: ---------- log end ----------
2014-11-06 00:18:40 +0100 IM: ---------- log start ----------
2014-11-06 00:18:40 +0100 IM: All install checks pass
2014-11-06 00:18:40 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:18:40 +0100 IM: [install started]
2014-11-06 00:18:41 +0100
2014-11-06 00:18:41 +0100 IM: ---------- log end ----------
2014-11-06 00:24:15 +0100 IM: ---------- log start ----------
2014-11-06 00:24:15 +0100 IM: All install checks pass
2014-11-06 00:24:15 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:24:15 +0100 IM: [install started]
2014-11-06 00:24:17 +0100
2014-11-06 00:24:17 +0100 IM: ---------- log end ----------
2014-11-06 00:27:19 +0100 IM: ---------- log start ----------
2014-11-06 00:27:28 +0100
2014-11-06 00:27:46 +0100 IM: Uninstall Started
2014-11-06 00:27:46 +0100 IM: [uninstall start]
2014-11-06 00:27:46 +0100 IM: user authorized
2014-11-06 00:27:46 +0100 IM: [file removal start]
2014-11-06 00:27:47 +0100 IM: Did not find file '/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-11-06 00:27:47 +0100 IM: Removed file: '/Library/Internet Plug-Ins/Flash Player.plugin'
2014-11-06 00:27:47 +0100 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-11-06 00:27:47 +0100 IM: Did not find file '/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-11-06 00:27:47 +0100 IM: Removed file: '/Library/Internet Plug-Ins/flashplayer.xpt'
2014-11-06 00:27:47 +0100 IM: Did not find file '/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-11-06 00:27:47 +0100 IM: Did not find file '/Users/Alucard/Library/Internet Plug-Ins/Shockwave Flash NP-PPC' to remove.
2014-11-06 00:27:47 +0100 IM: Did not find file '/Users/Alucard/Library/Internet Plug-Ins/Flash Player.plugin' to remove.
2014-11-06 00:27:47 +0100 IM: Did not find file '/Users/Alucard/Library/Internet Plug-Ins/PepperFlashPlayer/PepperFlashPlayer.plugin' to remove.
2014-11-06 00:27:47 +0100 IM: Did not find file '/Users/Alucard/Library/Internet Plug-Ins/Flash Player Enabler.plugin' to remove.
2014-11-06 00:27:47 +0100 IM: Did not find file '/Users/Alucard/Library/Internet Plug-Ins/flashplayer.xpt' to remove.
2014-11-06 00:27:47 +0100 IM: Did not find file '/Users/Alucard/Library/Internet Plug-Ins/PepperFlashPlayer/manifest.json' to remove.
2014-11-06 00:27:47 +0100 IM: Removed file: '/Library/LaunchDaemons/com.adobe.fpsaud.plist'
2014-11-06 00:27:47 +0100 IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/fpsaud'
2014-11-06 00:27:47 +0100 IM: Removed file: '/Library/Application Support/Adobe/Flash Player Install Manager/FPSAUConfig.xml'
2014-11-06 00:27:47 +0100 IM: Did not find bundle receipt to remove.
2014-11-06 00:27:53 +0100 IM: Removed file: '/Library/PreferencePanes/Flash Player.prefPane'
2014-11-06 00:27:53 +0100 IM: Removed PrefPane preferences from within: ~/Library/Preferences/com.apple.systempreferences.plist
2014-11-06 00:27:53 +0100 IM: [file removal end]
2014-11-06 00:27:53 +0100 IM: [uninstall end]
2014-11-06 00:27:53 +0100 IM: Uninstall Ended
2014-11-06 00:27:57 +0100 IM: ---------- log end ----------
2014-11-06 00:28:49 +0100 IM: ---------- log start ----------
2014-11-06 00:28:49 +0100 IM: All install checks pass
2014-11-06 00:28:49 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:28:49 +0100 IM: [install started]
2014-11-06 00:28:50 +0100
2014-11-06 00:28:50 +0100 IM: ---------- log end ----------
2014-11-06 00:31:20 +0100 IM: ---------- log start ----------
2014-11-06 00:31:20 +0100 IM: All install checks pass
2014-11-06 00:31:20 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:31:20 +0100 IM: [install started]
2014-11-06 00:31:21 +0100
2014-11-06 00:31:21 +0100 IM: ---------- log end ----------
2014-11-06 00:38:59 +0100 IM: ---------- log start ----------
2014-11-06 00:38:59 +0100 IM: All install checks pass
2014-11-06 00:38:59 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:38:59 +0100 IM: [install started]
2014-11-06 00:39:00 +0100
2014-11-06 00:39:00 +0100 IM: ---------- log end ----------
2014-11-06 00:49:39 +0100 IM: ---------- log start ----------
2014-11-06 00:49:39 +0100 IM: All install checks pass
2014-11-06 00:49:39 +0100 IM: ---------- log end ----------
2014-11-06 00:49:47 +0100 IM: ---------- log start ----------
2014-11-06 00:49:47 +0100 IM: All install checks pass
2014-11-06 00:49:47 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:49:47 +0100 IM: [install started]
2014-11-06 00:49:48 +0100
2014-11-06 00:49:48 +0100 IM: ---------- log end ----------
2014-11-06 00:56:15 +0100 IM: ---------- log start ----------
2014-11-06 00:56:15 +0100 IM: All install checks pass
2014-11-06 00:56:15 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 00:56:15 +0100 IM: [install started]
2014-11-06 00:56:16 +0100
2014-11-06 00:56:16 +0100 IM: ---------- log end ----------
2014-11-06 01:05:28 +0100 IM: ---------- log start ----------
2014-11-06 01:05:28 +0100 IM: All install checks pass
2014-11-06 01:05:28 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 01:05:28 +0100 IM: [install started]
2014-11-06 01:05:29 +0100
2014-11-06 01:05:29 +0100 IM: ---------- log end ----------
2014-11-06 01:06:47 +0100 IM: ---------- log start ----------
2014-11-06 01:06:47 +0100 IM: All install checks pass
2014-11-06 01:06:47 +0100 IM: ---------- log end ----------
2014-11-06 01:07:13 +0100 IM: ---------- log start ----------
2014-11-06 01:07:13 +0100 IM: All install checks pass
2014-11-06 01:07:13 +0100 IM: User does not have any processes that need to be closed.
2014-11-06 01:07:13 +0100 IM: [install started]
2014-11-06 01:07:14 +0100
2014-11-06 01:07:14 +0100 IM: ---------- log end ----------
2014-11-07 00:51:53 +0100 IM: ---------- log start ----------
2014-11-07 00:51:53 +0100 IM: All install checks pass
2014-11-07 00:51:53 +0100 IM: User does not have any processes that need to be closed.
2014-11-07 00:51:53 +0100 IM: [install started]
2014-11-07 00:51:55 +0100
2014-11-07 00:51:55 +0100 IM: ---------- log end ----------
2014-11-07 00:58:42 +0100 IM: ---------- log start ----------
2014-11-07 00:58:42 +0100 IM: All install checks pass
2014-11-07 00:58:42 +0100 IM: ---------- log end ----------
2014-11-07 00:58:49 +0100 IM: ---------- log start ----------
2014-11-07 00:58:49 +0100 IM: All install checks pass
2014-11-07 00:58:49 +0100 IM: User does not have any processes that need to be closed.
2014-11-07 00:58:49 +0100 IM: [install started]
2014-11-07 00:58:50 +0100
2014-11-07 00:58:50 +0100 IM: ---------- log end ----------
2014-11-07 01:08:01 +0100 IM: ---------- log start ----------
2014-11-07 01:08:01 +0100 IM: All install checks pass
2014-11-07 01:08:01 +0100 IM: User does not have any processes that need to be closed.
2014-11-07 01:08:01 +0100 IM: [install started]
2014-11-07 01:08:03 +0100
2014-11-07 01:08:03 +0100 IM: ---------- log end ----------
2014-11-07 01:20:27 +0100 IM: ---------- log start ----------
2014-11-07 01:20:27 +0100 IM: All install checks pass
2014-11-07 01:20:27 +0100 IM: User does not have any processes that need to be closed.
2014-11-07 01:20:27 +0100 IM: [install started]
2014-11-07 01:20:29 +0100
2014-11-07 01:20:29 +0100 IM: ---------- log end ----------
I did notice the "Use -allowUntrusted to override" where do i find that because i already have it set to allow app from everyone
If what I just read and was able to understand Adobe used a bad certificate to sign the install pkg so my mac won't accept it as being legit right? Adobe
Hi Alucard,
Based on the contents of your log file, your issue is different than the issue on the thread you originally posted to (flash won't install on Mac 10.10) so I branched your comment into a new thread.
The Flash Player installers are properly signed. You can verify by running either 'spctl -avv --type install <path to installer .app or .pkg>' or 'pkgutil --check-signature <pathto installer .app or .pkg>' (without the quotes). The results will indicate the installer is correctly signed.
I haven't encountered this issue before and did a bit of searching on the error, and found it can indicate a missing Apple Root cert. See this forum thread, Problems with signing certificate for Adobe CC Applications, for a similar issue as you are reporting. I deleted the Apple Root CA on a test machine and was able to reproduce the error. I re-installed the root cert and installation completed successfully. Please check that you have the Apple Root CA in the Keychain. If not, you can install it from here, http://www.apple.com/certificateauthority/. If it's there, we'll need to investigate further why this is happening.
Maria
how do i check the certificates
The certificate is in the Keychain Access tool. You can search for Keychain using spotlight or go to /Applications/Utilities/Keychain Access
After opening the Keychain Access too, in the upper left, there's a section named 'Keychains' with 'System Roots'. Click on System Roots. Below that, in the 'Category' section, select 'Certificates'. A list of certs will display on the right site. Look for Apple ROOT CA (if it's there, check the Expiration date).
The Apple Root CA expires 09FEB2035.
