When converting RoboHelp HTML 9 files to RoboHelp HTML5 11 files, is it transparent and seamless or are there adjustments that need to be made to the output?
Nov 07, 2014 Nov 07, 2014
We are considering upgrading from RoboHelp HTML 9 to RoboHelp HTML5 11. With all of our output files accessible by our customers, we want to ensure our content is always available to address their questions. When doing an upgrade to RH 11 will opening and outputting the files be seamless or will the files need tweaks to get them ready for publication? How much time would it take to adjust one page, if it's needed?
Any insight/experience you have with this topic to share is most appreciated.
Thank you.
293
Community Expert , Nov 07, 2014 Nov 07, 2014
Easiest way to test is to take a non-production machine & load the trial on it, then run a copy of your RH8 project on it – watch what happens
Hi there
Normally the process is pretty straightforward. You just make a backup copy of your original project, then open one of them using RoboHelp 11.
Exactly what may need tweaking will depend on what has happened to the project before upgrading. Unfortunately there is no standard list of "always tweak this" or "always do that". You simply have to upgrade, then test to see what may or may not need tweaking.
Cheers... Rick
Thank you for your quick response, Rick. I understand the necessity of making a backup and opening the project to see what may have happened, then making adjustments accordingly.
I was hoping there were users out there who have gone through a conversion and would have had some practical things to look out for that they ran into when converting their documents. Has anyone had that experience? And what did you find?
Thank you for your insights,
Jane
You may want to pay attention to lists – those might be affected
Thanks, Jeff. So you're saying that 'lists' may be affected. I'll certainly make a note of that. Can you tell me more about how they are affected? Was it a matter of indention? Numbering; size of initial or final bullet; background old code that needed to be removed? I remember several years ago when converting some old MS Word documents into RoboHelp that there were the nasty kadavs that needed to be removed. That was quite time consuming. It wouldn't be anything like that would it?
Thanks for your input. I really appreciate it.
Jane
Great tip! Thank you, Jeff.
Nov 17, 2014 Nov 17, 2014
Thank you for the suggestion of downloading a Trial version of RH 11 and making a copy of the existing project, opening it in RH 11 to see how it displays and what the output looks like. I'm in the process of reviewing the files and output as I type. I appreciate your help. : )
Nov 09, 2014 Nov 09, 2014
There's information on my site about fixing any List issues.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
