29 Replies Latest reply: Nov 12, 2014 7:36 AM by tommybanana1967go RSS
    Flash CS6 Air to iOS "Edit Application Settings" menu not coming up.  No way to publish to iOS.
    bcvincent Community Member
      Using a freshly re-installed and updated Flash CS6 on a 64-bit Macbook OS X 10.9.4.   I've tried various combos of Air 3.2, 3.4, 14, and 15, since yesterday, and I'm getting the same result.  Just two days ago everything about this setup was working flawlessly.  I was compiling and pushing Air apps to my iPad for testing.  Early yesterday morning I tried this and got a message that I didn't save, but was something along the lines of "This installation is not setup for this process" or something.  Since then, when I click on the wrench to bring up the Edit Application Settings menu, nothing happens.  This is true if I click on it next to target in the properties pane, or if I go to Air to iOS Settings from the File dropdown menu.
      The other strange part of this is that if I open some older projects, I can get the menu to come up again. But on the project I was working on it doesn't.  And if I create a new, blank FLA file and go straight to settings, it also doesn't work.  And if I attempt it and it doesn't work, if I close the file that wasn't working it crashes Flash completely.
      It seems like some database or cache is corrupt but I did a full uninstall (using adobe cleaner) and reinstall, and it's still happening.  I found one old thread on google about this same problem, and the solution given was to delete Library/Application Support/iPadApp/Local Store/appDB.db, but I don't even have this file to delete.
      Pretty much can't produce my content like this so I'm a sitting duck.  Any info would be greatly appreciated.  This is my first post here so I apologize if I'm missing something.
