complicated question: dialog box-batch processing script
ojodegato Nov 8, 2014 2:26 PMI am adapting the working script I found on this forum.
Script: Open files as layers in Photoshop
https://forums.adobe.com/thread/1313579
The goal of the adaptation is to include a javascript Folder dialog to set the save folder destination at run time and
use this folder destination for the remaining script batch processing functions.
Presently, the script loads a Bridge stack as Photoshop layers and saves the layered tiff using the Folder dialog.
The folder dialog is manifesting every time the script encounters a Bridge stack.
The question is what is the correct script logic to set the destination folder once at run time and keep this destination
folder for the stack batch processing.
#target bridge
var stacks = app.document.stacks;
var stackCount = stacks.length;
for(var s = 0;s<stackCount;s++){
var stackFiles = getStackFiles( stacks[s] );
if(stackFiles.length> 1){
var bt = new BridgeTalk;
bt.target = "photoshop";
var myScript = ("var ftn = " + psRemote.toSource() + "; ftn("+stackFiles.toSource()+");");
bt.body = myScript;
bt.send(5);
function getStackFiles( stack ){
var files = new Array();
for( var f = 0; f<stack.thumbnails.length;f++){
files.push(stack.thumbnails[f].spec);
return files;
function psRemote(stackFiles){
app.bringToFront();
var thisDoc = open(File(stackFiles[0]));
var Name = decodeURI(app.activeDocument.name).slice(0,-4);
thisDoc.layers[0].name = decodeURI(Name);
for(var a = 1;a<stackFiles.length;a++){
open(File(stackFiles[a]));
activeDocument.activeLayer.duplicate(thisDoc);
app.activeDocument.close(SaveOptions.DONOTSAVECHANGES);
thisDoc.layers[0].name = Name;
var tifOptions = new TiffSaveOptions();
tifOptions.embedColorProfile = true;
tifOptions.imageCompression = TIFFEncoding.TIFFLZW;
tifOptions.alphaChannels = false;
tifOptions.byteOrder = ByteOrder.MACOS;
tifOptions.layers = true;
var theFolder = Folder.selectDialog ("Select Folder");
if (theFolder) {
var myFile = new File( theFolder + "/" + app.activeDocument.name);
app.activeDocument.saveAs(myFile, tifOptions, true);
