1 Reply Latest reply: Nov 9, 2014 4:19 AM by Peter Grainge RSS
    Recommended Fix for Broken Merged Index
    Dave-Ypsi Community Member
      After moving a set of merged projects and master project in SVN, the merged index is not displaying on any machine but my build machine.  From posts in ASA Designer, this is apparently a known bug.  A workaround to manually fix the master hhp by removing the path to create a relative after opening the Generate dialog works.  A fix is suggested to modify the cpd file in Access.  Is this your recommendation, or is there another known fix for the problem? I'm hesitant to start messing with the cpd file.
