4 Replies Latest reply: Nov 10, 2014 11:09 AM by scottsdale99 RSS
    PDF File Size Reduction
    scottsdale99 Community Member
      Currently, I am using Adobe Reader XI, but am looking for a version that allows for the reduction of the PDF file size.  This is especially useful when e-mailing documents.  Can anyone suggest the best version to keep the editing functions (ex. PDF to Word), but add the reduction capabilities?
      Thanks.
        • 1. Re: PDF File Size Reduction
          Amit Malik Community Member
          Hi ,
          Using Adobe Reader you cannot reduce the size of a file . You can go with the Adobe Acrobat 11 pro for this and many more stuff you can do with this product.
          • 2. Re: PDF File Size Reduction
            Bill@VT CommunityMVP
            As mentioned you can't reduce the file size with Reader. Your alternative might be to zip the file if you are not willing to get Acrobat. However, even Acrobat does not always reduce the file size well, with a lot depending on the structure of the PDF.
            • 3. Re: PDF File Size Reduction
              Amit-
              Thank you so much!
              I just needed a little direction as to the proper software.
              Much appreciated.
              Ed Perne
              Corporate Director, Human Resources & Risk Management
              11500 W. Olympic Boulevard, Suite 345
              Los Angeles, CA  90064
              (p) 310-235-2745, ext. 408
              (f) 310-943-1600
              • 4. Re: PDF File Size Reduction
                Bill-
                Thanks so much.
                I’ll take a look at upgrading to Acrobat and see if that will do the trick.
                I appreciate the response.
                Thanks again.
                Ed Perne
                (f) 310-943-1600
