Show 2 replies
1. Re: How to add a blank line/return!
Gilad D (try67) Nov 10, 2014 3:01 AM (in response to zengirluk)This type of edit should not be performed in the PDF. You need to edit the
original file and then create a new PDF.
If you can't do that then either export it or try to move all the text
"boxes" you see. There's no other way of doing it.
2. Re: How to add a blank line/return!
Bill@VT Nov 10, 2014 10:59 AM (in response to zengirluk)I agree that you should really do this in the original document, but sometimes you can use the text edit tool to add the carriage return. You may just as likely get a really messed up PDF, only the try will let you know for sure.
