7 Replies Latest reply: Nov 10, 2014 11:25 AM by A.T. Romano RSS
    I cannot hear the audio attached to video files.
    Halfbodied Jish Community Member
      When I load in a video file saved as a .avi format that has audio and video included I cannot hear the audio. All that is coming out is what sounds like a swamp wildlife soundtrack on every video (Which is really odd).
      How do I correct this problem for Adobe Premier Elements 13?
        • 1. Re: I cannot hear the audio attached to video files.
          A.T. Romano Community Member
          Half
          What computer operating system is your Premiere Elements 13 running on?
          What are the properties of this .avi file. "AVI" is just a wrapper/container format that wraps the
          video and audio of the file. Not all .avi are created equal and can be found with a variety of
          video and audio compression.
          If I had to take a wild guess at this, I would say you probably have a Xvid.avi file. If so, the situation
          affects Premiere Elements (any version). If this were the case, do not use Xvid files ever in
          But, the answers are in your details for which we will be watching.
          Thanks.
          ATR
          • 2. Re: I cannot hear the audio attached to video files.
            ATR
            The program is being run on a Windows 7 64 bit OS.
            Honestly I'm not sure what type of .avi file they are. It is the default file type that comes from bandicam if you know which one that is.
            The files can run the audio just fine outside of Adobe fine just not when they are played through it.
            Is it still the case that this file type cannot be used in Adobe?
            Thanks again.
            • 3. Re: I cannot hear the audio attached to video files.
              Half
              It is very important to sorting this out to know what know kind of avi you have.
              See if you can find what it is with GSpot or MediaInfo
              http://sourceforge.net/projects/mediainfo/
              GSpot Codec Information Appliance
              For now, I am calling it Xvid.avi based on this bandicam document
              Bandicam - Configuration - Video - Best Recording Software, Game Video Recorder
              You do not take Xvid.avi into Premiere Elements (any versions) without issues.
              Convert or determine if bandicam will allow you to customerize to another format.
              If available, do not select AVCHD.avi. That will not import at all from all reports.
              We will be watching for further developments.
              Thanks.
              ATR
              Add On...we ran into an audio issue like yours a while back...turned out to be due to use of Xvid.avi.
              But, let us see if we can know for sure what is going on in your situation.
              • 4. Re: I cannot hear the audio attached to video files.
                It is in fact an xvid.avi file.
                I did try a video converting program recently, but significantly gimped the qualityof said video. It's there a recommendation for the type needed to keep the file in 1920x1080?
                • 5. Re: I cannot hear the audio attached to video files.
                  Half
                  Thanks for that important information that you are dealing with a xvid.avi file in Premiere Elements. Bad news, for Premiere Elements (any version).
                  Do not convert to AVCHD.avi or H.264.avi - not supported by Premiere Elements.
                  Determine if you can convert to AVCHD.mp4 or H.264.mp4. Your converter should allow for a place to set frame width 1920 and frame height 1080 and frame rate as well as video compression (AVCHD or H.264). Under container/wrapper/file extension settings, look for the .mp4.
                  What video converter are you using?
                  We will be watching for further details.
                  Thank you.
                  ATR
                  • 6. Re: I cannot hear the audio attached to video files.
                    carl77finch Community Member
                    My problem with PrE13 seems similar to Halfbodied Jish's.  I record TV programs
                    with WinTV from a Hauppage TV tuner card in my computer (Win7, 64bit).  My
                    wish is to simply edit out the commercial breaks, leaving just the 20-minute "content"
                    of the typical half hour show. The file that WinTV creates (~3 GB) is an MPEG-2 with:
                    Video----
                      length = 00:29:37
                      frame = 1920x1080
                      rate = 29 fps
                      data rate = 24000 kbps
                      total bitrate = 24384 kbps
                    Audio----
                      bit rate = 384 kbps
                      channels = 6
                      audio sample rate = 48 kHz
                    (these are from Windows Explorer's properties display)
                    When I play the unedited file within PrE13 (trial version) or with VLC, all I hear is the
                    laugh track (and some of the commercials, but out-of-sync)!
                    • 7. Re: I cannot hear the audio attached to video files.
                      carl77finch
                      Please determine whether or not your recording device is recording with a variable frame rate.
                      To do that, take the file into a video audio properties readout program such as MediaInfo (Tree View). If you see 3 frames rates given
                      for the video, then your video was recorded with a variable frame rate. Premiere Elements often does not usually fare well in that type of
                      situation. If frame rate found as variable type, next step would be taking the video into HandBrake and converting it to a H.264.mp4 files with a constant frame rate of 29.97 frames per second rather than a variable frame rate.
                      https://handbrake.fr/
                      More on all this once we get some further details of your results.
                      Thank you.
                      ATR
                      Add On...MediaInfo is a free program and extremely useful, however its download and install can be flawed with unwanted carry along
                      software. Proceed with caution. If you can get your variable vs constant frame rate information from another source (like the manufacturer of your recording device) best do that. The following is listed as a safe download
                      http://mediainfo.en.softonic.com/
                      but I have not tested it. I am working with an older version of MediaInfo where this type of nuisance did not exist.
