2. Re: after adjusting photo there is still a white border around the photo wo i cant teel is i fixed it.This works in cs6 and not in cc ?
normfb Nov 10, 2014 12:15 PM (in response to kaliart)Since you have not yet responded to the request for more specific information, I will make a few assumptions: I guess you made a selection of an object on a white background and when you put that selected object on a separate layer (Cmd+J) it had an undesired fringe of white. If that is indeed the problem, three possible solutions are:
1. Go to the layer, do not make a selection. Choose Layer > Matting > Defringe
2. Go to the layer, select the object and choose to Select > Refine Edge > Shift Edge or other tools there
3. Go to the layer, select the object and choose Select > Modify > Contract to create a tighter selection. Then inverse and delete the fringe
There are other options, as well.
The choice of which of the above three might produce the most desired effect depends on the particular object and selection.
Good luck.
