1. Re: batch ,remove noise to several audio files
ryclark Nov 10, 2014 8:55 AM (in response to mantralightroom)When you record the Favorite it will use and store the settings of the Noise Footprint used at the time. It can't load new footprint's from a file. So provided all your audio files that you wish to Batch Process have the same Noise Footprint then you are OK.
2. Re: batch ,remove noise to several audio files
mantralightroom Nov 10, 2014 9:32 AM (in response to ryclark)It can't load new footprint's from a file
but the prev version can do it , even cool edit pro 2000
are you sure i can't save the noise print to a file and with favorite load
3. Re: batch ,remove noise to several audio files
ryclark Nov 10, 2014 2:38 PM (in response to mantralightroom)No, Audition was completely re-written for cross platform compatibility with Mac and PC. The Scripting functions that allowed you to do that has never been made available in the latest versions of Audition. Recording Favorites is a completely different function I'm afraid.
But you can certainly still save out a Noise Print and use that when you record your Favorite and the settings will be saved in the Favorite. But there is no way of recalling the file when you do your Batch processing, it will just use the NR settings saved in Favorite.
4. Re: batch ,remove noise to several audio files
mantralightroom Nov 10, 2014 11:14 PM (in response to ryclark)thanks
No, Audition was completely re-written for cross platform compatibility with Mac and PC.The Scripting functions that allowed you to do that has never been made available in the latest versions of Audition. Recording Favorites is a completely different function I'm afraid.
may i ask you this from version cs5 to cc ?
5. Re: batch ,remove noise to several audio files
ryclark Nov 11, 2014 4:43 AM (in response to mantralightroom)No, unfortunately the scripting function from Audition 3 and before hasn't yet made back into even the latest versions of Audition. Further improvements into the new method of recording favorites have been requested to make Batch Processing much more customisable.
